My Nest Thermostat card config using thermostat-dark-card
They are a complicated svg that I obtained by inspecting the Nest web UI and then applied via custom:card-mod CSS styling…
Mode:
        style: |
          ha-icon {
            background-image: url("data:image/svg+xml;charset=utf-8,%3Csvg xmlns='http://www.w3.org/2000/svg' width='24.1' height='24.1' viewBox='-282.6 655.7 611.9 511.8' fill='%23FFF'%3E%3Cpath d='M235.4 1039.5c-38.3 30.7-76.8 46.1-117.7 46.1-51.2 0-99.7-23-153.5-74.2-61.4-58.8-127.9-110-194.5-110-12.8 0-25.6 2.6-38.4 5.1-2.3.7-5.7 1-7.6-2.6-1.7-3.2 0-5.1 2.6-7.6 38.3-30.7 76.8-46.1 117.7-46.1 51.2 0 99.7 23 153.5 74.2 61.3 58.8 127.8 110 194.4 110 12.8 0 25.6-2.6 38.3-5.1 2.8-.5 5.9-1.2 7.6 2.6 1.6 3.3.1 5.1-2.4 7.6zM-194.5 991c38.3 0 76.8 18 115.2 56.3 46.1 43.5 97.2 84.4 145.9 84.4 10.2 0 20.5-2.6 28.2-5.1 2.6-.7 4.6.1 5.7 2.1 1.7 3.1-.6 5.6-.6 5.6-28.2 23-58.8 33.2-87 33.2-38.3 0-76.8-18-115.2-56.3-46.1-43.5-97.2-84.4-145.9-84.4-10.2 0-20.4 2.9-28.2 5.1-2.3.7-4.2.7-5.7-2.3-1.5-2.8.6-5.3.6-5.3 28.1-20.6 56.3-33.3 87-33.3zM327.4 799c-28.2 23-58.8 33.2-87 33.2-38.3 0-76.8-18-115.2-56.3-46-43.4-97.1-84.4-145.8-84.4-10.2 0-20.5 2.6-28.2 5.1-2.2.7-4.3.2-5.6-1.8-2.2-3.5.5-5.9.5-5.9 28.2-23 58.8-33.2 87-33.2 38.3 0 76.8 18 115.2 56.3 46.1 43.5 97.2 84.4 145.9 84.4 10.2 0 20.5-2.6 28.2-5.1 2.1-.8 4.3-1.1 5.7.7 1.5 2.1 1.9 4.5-.7 7zM81.9 811.9c61.4 58.8 127.9 110 194.5 110 12.8 0 25.6-2.6 38.3-5.1 2.6-.7 5.7-1.2 7.6 2.6 1.6 3.1 0 5.1-2.6 7.6-38.4 30.7-76.8 46-117.7 46-51.2 0-99.7-23-153.5-74.2-61.4-58.8-127.9-110-194.5-110-12.8 0-25.6 2.6-38.3 5.1-2.6.7-5.7.7-7.6-2.6-1.8-3.1 0-5.1 2.6-7.6 38.3-30.7 76.8-46.1 117.7-46.1 51.1 0 99.7 23.1 153.5 74.3z'/%3E%3C/svg%3E");
            background-position: 25%;
            background-position-x: 50%;
            background-position-y: center;
            background-repeat: no-repeat;
            height: 44px;
            margin: 0
            auto 3px;
            width: 26px;
I am still trying to figure out how to remove the two icons in the entity rows for inside humidity and outside temp
I changed the upper value for living_room_eco_temp
#Celsius:
      living_room_eco_temp:
        friendly_name: Living Room ECO Temperature Range
        value_template: >
          {% if 19.5 < state_attr('climate.living_room', 'temperature')|round(1,"half") < 24.5 %}
##Fahrenheit:
#      living_room_eco_temp:
#        friendly_name: Living Room ECO Temperature Range
#        value_template: >
#          {% if 67 < state_attr('climate.living_room', 'temperature')|round(1,"half") < 76 %}
To remove the icons use
icon: ‘HASS:none’
Then you get:
That is the easy answer which I already knew!
I’m trying to use card-mod to inject CSS to remove the space occupied by it…
This is awesome. Any updates to it?
I haven’t been able to remove the spacing for the empty icon but I have tweaked the popup for Mode
Let’s see if I can summarize…
I’ve added four new attributes to climate.living_room:
customize.yaml
  templates:
    hvac_off: if (state === 'off') return '✔'; else return ' ';
    hvac_heat: if (state === 'heat') return '✔'; else return ' ';
    hvac_cool: if (state === 'cool') return '✔'; else return ' ';
    hvac_auto: if (state === 'auto') return '✔'; else return ' ';
And the pop-up cards use those new attributes as the state:
    popup_cards:
      sensor.living_room_hvac_mode:
        type: 'custom:card-templater'
        title: Cancel
        card:
          type: entities
          show_header_toggle: false
          title: 'Set thermostat to:'
          style: |
            #main-title {
              font-size: 16px;
            .card-header {
              line-height: 20px;
            .card-header .name {
              font-size: 14px;
              color: gray;
          entities:
            - entity: climate.living_room
              attribute: hvac_heat
              type: 'custom:multiple-entity-row'
              image: /local/images/nest-mode-heat-200x200.png
              show_state: true
              icon: true
              styles:
                font-weight: bold
                width: 80px
                text-align: right
                color: '#25B1F6'
              tap_action:
                action: call-service
                service: climate.set_hvac_mode
                service_data:
                  entity_id: climate.living_room
                  hvac_mode: heat
              attribute: hvac_off
              image: /local/images/nest-mode-off-200x200.png
              show_state: true
              styles:
                font-weight: bold
                width: 40px
                text-align: right
                color: '#25B1F6'
              tap_action:
                service_data:
                  hvac_mode: 'off'
        entities:
          - entity: sensor.living_room_hvac_mode
            state_template: |
              {% if is_state('sensor.living_room_hvac_mode', 'heat') %}
      sensor.living_room_preset_mode:
        title: ' '
        card:
          style: |
            .card-header {
              line-height: 20px;
              font-size: 14px;
              white-space: normal;
              text-align: center;
              font-size: 14px;
              color: gray;
              white-space: normal !important;
              text-align: center;
          type: entities
          title: >-
            Save energy by using Eco Temperatures when no one's home. Or turn
            them on manually any time.
          entities:
            - type: button
              icon: 'mdi:leaf'
              action_name: START ECO
              tap_action:
                service: climate.set_preset_mode
                service_data:
                  preset_mode: eco
            - type: button
              icon: 'mdi:leaf-off'
              action_name: STOP ECO
              tap_action:
                service_data:
                  preset_mode: none
The images:
Others I have…
mode-heat
mode-off
mode
I’ve fixed the popup for schedule and the URL link to Nest for history:
  - path: environment
    title: Environment
    icon: 'hass:thermostat'
    theme: ''
    badges: []
    popup_cards:
        title: Cancel
        card:
          type: entities
          style: |
            #main-title {
              font-size: 16px;
            .card-header {
              line-height: 20px;
              font-size: 14px;
              color: gray;
          entities:
              show_state: true
              icon: true
              styles:
                font-weight: bold
                width: 80px
                text-align: right
                color: '#25B1F6'
              tap_action:
                service_data:
                  hvac_mode: heat
              attribute: hvac_off
              show_state: true
              styles:
                font-weight: bold
                width: 40px
                text-align: right
                color: '#25B1F6'
              tap_action:
                service_data:
                  hvac_mode: 'off'
        entities:
            state_template: |
        title: ' '
        card:
          style: |
            .card-header {
              line-height: 20px;
              font-size: 14px;
              text-align: center;
              font-size: 14px;
              color: gray;
              text-align: center;
          type: entities
          title: >-
          entities:
            - type: button
              icon: 'mdi:leaf'
              tap_action:
                service_data:
                  preset_mode: eco
            - type: button
              tap_action:
                service_data:
                  preset_mode: none
        title: Schedule
        card:
          type: 'custom:scheduler-card'
          title: Living Room Schedule
          include:
            - climate.living_room
    cards:
      - type: 'custom:vertical-stack-in-card'
        cards:
          - type: 'custom:thermostat-dark-card'
            chevron_size: 50
            step: 0.1
            pending: '1'
            idle_zone: '2'
            hvac:
              states:
                'off': 'off'
                cooling: cool
                heating: heat
            attribute: hvac_action
            away:
                sensor: sensor.living_room_eco_temp
            style: |
              ha-card {
                {% if is_state_attr('climate.living_room', 'hvac_action', 'heating') %}
                  background: #EB6D00;
                  border-bottom: 1pt solid #E65E00;
                  {% if is_state_attr('climate.living_room', 'hvac_action', 'cooling') %}
                    background: #0055FF ;
                    border-bottom: 1pt solid #00008B;
                    background: #373F48 ;
                    border-bottom: 1pt solid #2b333a;
                box-shadow: 0 0 20px;
               .dial_title {
                 color: white !important;
          - type: entities
            entities:
              - entity: sensor.living_room_humidity
                icon: 'mdi:none'
            style:
                ha-card {
                  color: white;
                  font-size: 1.1rem;
              $hui-sensor-entity-row$hui-generic-entity-row$: |
                state-badge {
                  display: none;
          - type: entities
            entities:
              - entity: sensor.openweathermap_temperature
                icon: 'mdi:none'
            style: |
              ha-card {
                color: white;
                box-shadow: 0 0 10px;
                font-size: 1.0rem;
          - type: horizontal-stack
            cards:
              - type: 'custom:button-card'
                show_name: true
                tap_action:
                  action: more-info
                color_type: icon
                state:
                  - operator: template
                    value: >
                      [[[ return states['climate.living_room'].state === 'off'
                    icon: 'mdi:none'
                    color: white
                    value: >
                      [[[ return states['climate.living_room'].state === 'heat'
                    icon: 'mdi:none'
                    color: 'rgb(239, 140, 0)'
                    value: >
                      [[[ return states['climate.living_room'].state === 'cool'
                    color: blue
                    icon: 'mdi:none'
                show_state: false
                style: |
                  ha-card {
                    font-size: 85% !important;
                    color: white;
                    background:
                      #EB6D00 ;
                        #0055FF ;
                        #373F48;
                    box-shadow: none;
                  ha-icon {
                    height: 44px;
                    margin: 0
                    auto 3px;
                    width: 26px;
                entity: sensor.living_room_preset_mode
                label: ECO
                tap_action:
                  action: more-info
                color_type: icon
                color: green
                icon: 'mdi:none'
                state:
                    value: >
                      [[[ return
                      states['climate.living_room'].attributes.preset_mode ==
                      'none' ]]]
                    icon: 'mdi:none'
                    color: white
                show_state: false
                show_name: true
                style: |
                  ha-card {
                    color: white;
                    background:
                      #EB6D00 !important;
                        #0055FF !important;
                        #373F48 !important;
                    box-shadow: none;
                  ha-icon {
                    background-image: url("data:image/svg+xml;charset=utf-8,%3Csvg xmlns='http://www.w3.org/2000/svg' width='24.1' height='24.1' viewBox='0 0 26 24' fill='%23FFF'%3E%3Cpath class='st0' d='M.8 20.7c6.3 4.5 13.1 4.7 19-1.7 6.1-6.5 6.4-14.5 6.2-19-3.3 4-9.5 2.2-18.2 5C1 7.2.1 15.3 0 18.7c1.6-1.7 4.6-4.5 8.5-5.9 6.2-2.3 8.9-2.3 12.6-5.1-2.3 2.6-5.3 4.1-11.1 6.2-4.2 1.5-7.9 5.3-9.2 6.8z'/%3E%3C/svg%3E");
                    height: 44px;
                    margin: 0
                    auto 3px;
                    width: 26px;
                action: url
                navigation_path: 'https://home.nest.com'
                color_type: card
                icon: none
                show_state: false
                show_name: true
                style: |
                  ha-card {
                    background:
                      #EB6D00 !important;
                        #0055FF !important;
                        #373F48 !important;
                    box-shadow: none;
                  }   ha-icon {
                    background-image: url("data:image/svg+xml;charset=utf-8,%3Csvg xmlns='http://www.w3.org/2000/svg' width='22' height='24.1' fill='%23FFF'%3E%3Cpath d='M17 24.5H5c-2.8 0-5-2.2-5-5v-12c0-2 1.2-3.8 3-4.6v1c0 1.4 1.1 2.6 2.5 2.6S8 5.3 8 3.9V2.5h6v1.4c0 1.4 1.1 2.6 2.5 2.6S19 5.3 19 3.9v-1c1.8.8 3 2.5 3 4.6v12c0 2.8-2.2 5-5 5zm-1.7-7.9l-3.8-2.2V9c0-.6-.4-1-1-1s-1 .4-1 1V15.6s0 .1.1.1l.1.1.1.1s.1 0 .1.1l4.3 2.5c.5.3 1.1.1 1.4-.4.4-.6.2-1.2-.3-1.5zM16.5 5c-.6 0-1-.4-1-1V1c0-.6.4-1 1-1s1 .4 1 1v3c0 .6-.4 1-1 1zm-11 0c-.6 0-1-.4-1-1V1c0-.6.4-1 1-1s1 .4 1 1v3c0 .6-.4 1-1 1z'/%3E%3C/svg%3E");
                    height: 44px;
                    margin: 0
                    auto 3px;
                    width: 26px;
                tap_action:
                  action: url
                  url_path: 'https://home.nest.com'
                color_type: card
                icon: 'mdi:none'
                show_state: false
                show_name: true
                style: |
                  ha-card {
                    font-size: 80% !important;
                    background:
                      #EB6D00 !important;
                        #0055FF !important;
                        #373F48 !important;
                    box-shadow: none;
                  }  ha-icon {
                    background-image: url("data:image/svg+xml;charset=utf-8,%3Csvg xmlns='http://www.w3.org/2000/svg' width='24' height='24' viewBox='0 0 26 24' fill='%23FFF' stroke='%23FFF'%3E%3Cpath stroke-width='.05' d='M12.5 24c-6.6 0-12-5.4-12-12s5.4-12 12-12c.6 0 1 .4 1 1s-.4 1-1 1C7 2 2.5 6.5 2.5 12s4.5 10 10 10 10-4.5 10-10c0-.6.4-1 1-1s1 .4 1 1c0 6.6-5.4 12-12 12zM22.9 8.4c-.5.2-1.1 0-1.3-.5-.2-.5 0-1.1.5-1.3.5-.2 1.1 0 1.3.5.2.5 0 1.1-.5 1.3zm-3.6-3.7c-.4-.4-.4-1 0-1.4s1-.4 1.4 0c.4.4.4 1 0 1.4-.4.4-1 .4-1.4 0zm-2.1 11.7l-5.2-3s-.1 0-.1-.1l-.1-.1-.1-.1-.1-.1v-.1-.1-.1-.1-.1-7.1c0-.6.4-1 1-1s1 .4 1 1v6.4l4.7 2.7c.5.3.6.9.4 1.4-.4.6-1 .7-1.5.5zm-1.1-14c-.5-.2-.8-.8-.5-1.3.2-.5.8-.8 1.3-.5.5.2.8.8.5 1.3-.2.5-.8.7-1.3.5z'/%3E%3C/svg%3E");
                    height: 44px;
                    margin: 0
                    auto 3px;
                    width: 26px;
I’m also using my own sensor for Eco mode for Dark Thermostat since Nest displays Eco mode based on temperature setpoint rather than Eco mode being On or Off. If Eco mode is On, the temperature setpoint is automatically in the Eco range. The two items are kind of unrelated yet not!. I.e. if you set your temperature to 15C, the leaf is displayed even if Eco mode is off…
        value_template: >
          {% if 19.5 < state_attr('climate.living_room', 'temperature')|float|round(1,"half") < 24.5 %}
            none
            eco
@dbrunt are you maintaining a GitHub with the updates so someone can come along and apply all the most recent changes?
No, but I have thought about doing that though.
Please do! As you continue to improve this and make it even closer to the actual Nest I think you could have wild popularity with this card.
Any chance you’ll make a GitHub? I have tried to set this up, but it’s hard to dig through all the posts to get the latest updates and right now clicking mode and eco are not working for me because I am missing something.
Yes, I will but have been busy with Xmas lights & decorations, Xmas shopping, Hyperion controlled LED back-lighting for my TV (smile), girlfriends (wink, wink) and…Work (Damn work, but it pays for my bills, hobbies, and BEER!)…
Can you post all related YAML settings?
PM’s work too since I get like ALMOST zero PM’s!
I had like 4 or cards in my Thermostat page where my primary focus one worked but a couple other older ones the mode and eco were not working. I can see where all of the above info could be confusing! I’ve deleted those so I’M NOT confused!!
The next few days will likely be even more time constrained but I will look at what you’ve got so far…
my name is Fabrizio and i needed help for the configuration using thermostat dark card.
,but don’t have the icon :mode,eco,schedule,history
That’s all that the custom:dark-thermostat-card by itself gives you…
The rest of the customization I constructed myself using browser-mod, card-mod, custom:vertical-stack-in-card and custom:button-card, in addition to custom-dark-thermostat-card…
My current configuration is now on Github…
Added two new sensors: nest_eco_low and nest_eco_high with unit of measurement set to °C so automatic conversion by HA to value in Fahrenheit will occur (if your system is set to Imperial). I tested by setting their value to Fahrenheit values and unit of measurement as °F and HA displayed the correct value for me in Celsius!
hey man, have two nest thermostats and want to apply your work to my lovelace.
So i got your repo files, set the sensors according to my climate.xxx thermostat name.
But sensors started working, so thats a nice start.
Secondary, i can’t understand where to put the lovelace-raw or lovelace.yaml file to make a card of it in my ui-lovelace.yaml config.
Just copy the code from lovelace_raw_config.yaml and add it your lovelace raw configuration.
Here is my thermostat card:
cards:
    chevron_size: 50
    step: 0.1
    pending: '1'
    idle_zone: '2'
    hvac:
      states:
        'off': 'off'
        cooling: cool
        heating: heat
    away:
        sensor: sensor.nest_eco_temp
    style: |
      ha-card {
       .dial_title {
  - type: entities
    entities:
      - entity: sensor.nest_humidity
        icon: 'mdi:none'
    style:
        ha-card {
          color: white;
          font-size: 1.1rem;
        state-badge {
          display: none;
  - type: entities
    entities:
      - entity: sensor.nest_outside_temperature
        icon: 'mdi:none'
    style:
        ha-card {
          color: white;
          font-size: 1.1rem;
        state-badge {
          display: none;
    cards:
        entity: sensor.nest_hvac_mode
        show_name: true
        tap_action:
          action: more-info
        color_type: icon
        state:
            value: |
              [[[ return states['climate.living_room'].state === 'off' ]]]
            icon: 'mdi:none'
            color: white
            value: |
              [[[ return states['climate.living_room'].state === 'heat' ]]]
            icon: 'mdi:none'
            value: |
              [[[ return states['climate.living_room'].state === 'cool' ]]]
            color: blue
            icon: 'mdi:none'
        show_state: false
        style: |
          ha-card {
            color: white;
            background:
              #EB6D00 ;
                #0055FF ;
                #373F48;
            box-shadow: none;
          ha-icon {
            height: 44px;
            margin: 0
            auto 3px;
            width: 26px;
        entity: sensor.nest_preset_mode
        label: ECO
        tap_action:
          action: more-info
        color_type: icon
        color: green
        icon: 'mdi:none'
        state:
            value: >
              [[[ return states['climate.living_room'].attributes.preset_mode ==
              'none' ]]]
            icon: 'mdi:none'
            color: white
        show_state: false
        show_name: true
        style: |
          ha-card {
            color: white;
            background:
              #EB6D00 !important;
                #0055FF !important;
                #373F48 !important;
            box-shadow: none;
          ha-icon {
            height: 44px;
            margin: 0
            auto 3px;
            width: 26px;
        action: url
        color_type: card
        icon: none
        show_state: false
        show_name: true
        style: |
          ha-card {
            background:
              #EB6D00 !important;
                #0055FF !important;
                #373F48 !important;
            box-shadow: none;
          }   ha-icon {
            height: 44px;
            margin: 0
            auto 3px;
            width: 26px;
        tap_action:
          action: url
        color_type: card
        icon: 'mdi:none'
        show_state: false
        show_name: true
        style: |
          ha-card {
            background:
              #EB6D00 !important;
                #0055FF !important;
                #373F48 !important;
            box-shadow: none;
          }  ha-icon {
            height: 44px;
            margin: 0
            auto 3px;
            width: 26px;
Use the UI and add an empty manual card and then highlight its yaml and replace with the above.
