I turned on the heating plant last night. In the living room it was 22 degrees and I set the central heating to 24 degrees to do the test.
The problem is that the time it takes to reach 24 degrees was 10 minutes and in the application it was 1 hour 30 minutes.
Where did I go wrong ?
The code is:
template:
- sensor:
- name: "Living Room Time to Temp"
unique_id: living_room_time_to_temp
icon: mdi:camera-timer
unit_of_measurement: 'minutes'
state: "{{ ((state_attr('climate.living_room','temperature')|float(0) - states('sensor.living_room_temperature')|float(0)) * state_attr('sensor.living_room_time_to_temp','rate_of_change')|float(0)/60)|abs|int }}"
attributes:
message: |
{% if states('sensor.living_room_time_to_temp')|float(0) < 10 %}
IN LESS THAN 10 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 16 %}
IN 15 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 21 %}
IN 20 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 26 %}
IN 25 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 31 %}
IN 30 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 36 %}
IN 35 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 41 %}
IN 40 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 46 %}
IN 45 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 51 %}
IN 50 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 56 %}
IN 55 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 61 %}
IN 1 HR
{% elif states('sensor.living_room_time_to_temp')|float(0) < 66 %}
IN 1 HR 5 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 71 %}
IN 1 HR 10 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 76 %}
IN 1 HR 15 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 81 %}
IN 1 HR 20 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 86 %}
IN 1 HR 25 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 191 %}
IN 1½ HR
{% else %}
IN 2+ HR
{% endif %}
dbrunt
(Daniel)
October 24, 2023, 2:58am
103
You seem to be missing most of the attributes for the sensor.living_room_time_to_temp
attributes:
message: |
{% if states('sensor.living_room_time_to_temp')|float(0) < 10 %} IN LESS THAN 10 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 16 %} IN 15 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 21 %} IN 20 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 26 %} IN 25 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 31 %} IN 30 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 36 %} IN 35 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 41 %} IN 40 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 46 %} IN 45 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 51 %} IN 50 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 56 %} IN 55 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 61 %} IN 1 HR
{% elif states('sensor.living_room_time_to_temp')|float(0) < 66 %} IN 1 HR 5 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 71 %} IN 1 HR 10 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 76 %} IN 1 HR 15 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 81 %} IN 1 HR 20 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 86 %} IN 1 HR 25 MIN
{% elif states('sensor.living_room_time_to_temp')|float(0) < 191 %} IN 1½ HR
{% else %} IN 2+ HR
{% endif %}
time_of_current_change_to_heating: >
{{ states('input_datetime.hvac_current_heat_started') }}
time_of_last_change_to_heating: >
{{ states('input_datetime.hvac_heat_started') }}
time_of_last_change_from_heating: >
{{ states('input_datetime.hvac_heat_ended') }}
elapsed_seconds: >
{{ as_timestamp(states('input_datetime.hvac_heat_ended')) - as_timestamp(states('input_datetime.hvac_heat_started')) }}
temp_at_last_change_to_heat: >
{{ states('input_number.hvac_heat_start_temp') }}
temp_at_last_change_from_heat: >
{{ states('input_number.hvac_heat_end_temp') }}
degrees_of_separation: >-
{{ (states('input_number.hvac_heat_end_temp')|float(0) - states('input_number.hvac_heat_start_temp')|float(0))|abs|round(1,"even",0) }}
rate_of_change: >
{% if state_attr('sensor.living_room_time_to_temp', 'degrees_of_separation')|float(0) > 0 %}
{{ state_attr('sensor.living_room_time_to_temp', 'elapsed_seconds')|float(0) / state_attr('sensor.living_room_time_to_temp', 'degrees_of_separation')|float(0) }}
{% else %}
0
{% endif %}
current_temp: >
{{ states('sensor.living_room_temperature') }}
target_temp: >
{{ state_attr('climate.living_room','temperature') }}
last_estimated_time_to_temp: >
{{ ((state_attr('sensor.living_room_time_to_temp','temp_at_last_change_from_heat')|float(0) - state_attr('sensor.living_room_time_to_temp','temp_at_last_change_to_heat')|float(0)) * state_attr('sensor.living_room_time_to_temp','rate_of_change')|float(0))|abs|timestamp_custom('%H:%M:%S', true) }}
johnesc
(JohnEsc)
November 7, 2023, 2:44pm
104
Hoping @dbrunt or someone else can provide guidance as to why the 4 icons do not appear on my thermostat card and also why the secondary card Nest Setpoint shows 160 degrees as opposed to 71 and Nest Temperature shows 159.8. I changed the Outside Temp on the thermostat card to use openweather temp instead of sensor.nest_outside_temperature cause it currently shows 142 degrees. Let me know what else I can provide to further assist with this issue.
dbrunt
(Daniel)
November 7, 2023, 11:49pm
105
You’ve got something amiss in your template sensors!
You’d have to check your yaml config for sensor.nest_setpoint
and sensor.nest_temperature
- name: "Nest Setpoint"
unique_id: nest_setpoint
device_class: temperature
unit_of_measurement: '°C'
state: "{{ state_attr('climate.living_room', 'temperature') }}"
- name: "Nest Temperature"
unique_id: nest_temperature
state: "{{ state_attr('climate.living_room','current_temperature')|round(1, 'half', default=0) }}"
What is the entity_id for your Nest thermostat?
johnesc
(JohnEsc)
November 8, 2023, 12:33am
106
dbrunt:
My Nest Thermostat is called: climate.living_room
I believe I had the same as you, but I copy & pasted over it just in case, here’s my code:
- name: "Nest Time to Temp Message"
unique_id: nest_time_to_temp_message
state: >
{% if state_attr('climate.living_room','hvac_action') == 'off' %} SYSTEM IS OFF
{% elif state_attr('climate.living_room','hvac_action') == 'idle' and states('climate.living_room') == 'heat' %} HEAT SET TO
{% elif state_attr('climate.living_room','hvac_action') == 'idle' and states('climate.living_room') == 'cool' %} COOLING SET TO
{% else %} {{ state_attr('sensor.living_room_time_to_temp','message') }}
{% endif %}
attributes:
hvac_action: "{{ state_attr('climate.living_room','hvac_action') }}"
dbrunt
(Daniel)
November 8, 2023, 4:43am
107
Well, if you truly have what you say, and you are still seeing 160 °F, then you must also being seeing 160 °F here in dev tools, and in the Nest app!
johnesc
(JohnEsc)
November 8, 2023, 2:30pm
108
No, in Dev Tools it shows the correct information as reported by the Nest Thermostat.
Would it be effected by another sensor that shows that correct temp but with different entity_ids such as:
sensor.living_room_setpoint: 71
sensor.living_room_temperature: 71
If I use these entities that show the correct numbers, would I have to change your code elsewhere?
dbrunt
(Daniel)
November 9, 2023, 3:28am
109
Okay, you appear to have climate.living_room
with attributes:
current_temperature: 71
temperature: 71
You appear to have
Therefore you should see…
{{ states('sensor.nest_setpoint') }}
as “71” and
{{ states('sensor.nest_temperature') }}
as “71”
and you should be seeing…
In Dev Tools → STATES you can filter the states of all entities to find the entity that is 160 °F and the one that is 159.8 °F (or whatever values you currently are seeing):
Whoa, wait a sec, I see the problem !!!
Change this:
To this:
unit_of_measurement: '°F'
johnesc
(JohnEsc)
November 9, 2023, 7:25pm
110
That did the trick, thank you! Any idea why the icons won’t appear on the Thermostat Card?
dbrunt
(Daniel)
November 10, 2023, 2:27am
111
Mine’s broke too! Until such time as I fix the svg+xml code I spents days (if not weeks) developing well over a year ago, or find a good alternative for it, here is a temporary solution using HA native mdi icons:
- type: horizontal-stack
card_mod:
style: |
ha-card {
border: none;
{% if is_state_attr('climate.living_room', 'hvac_action', 'heating') %}
background: #EB6D00;
border-bottom: 1pt solid #E65E00;
{% else %}
{% if is_state_attr('climate.living_room', 'hvac_action', 'cooling') %}
background: #0055FF ;
border-bottom: 1pt solid #00008B;
{% else %}
background: #373F48 ;
border-bottom: 1pt solid #2b333a;
{% endif %}
{% endif %}
cards:
- type: custom:button-card
entity: sensor.nest_hvac_mode
show_name: true
tap_action:
action: more-info
color_type: icon
state:
- operator: template
value: |
[[[ return states['climate.living_room'].state === 'off' ]]]
icon: mdi:waves
color: white
value: |
[[[ return states['climate.living_room'].state === 'heat' ]]]
icon: mdi:waves
color: white
value: |
[[[ return states['climate.living_room'].state === 'cool' ]]]
color: blue
icon: mdi:waves
show_state: false
card_mod:
style: |
ha-card {
color: white;
border: none;
font-size: .8rem !important;
{% else %}
{% else %}
{% endif %}
{% endif %}
entity: sensor.nest_preset_mode
label: ECO
tap_action:
action: more-info
color_type: icon
state:
value: >
[[[ return states['climate.living_room'].attributes.preset_mode ==
'none' ]]]
icon: mdi:leaf-off
color: white
value: >
'eco' ]]]
icon: mdi:leaf
color: white
show_state: false
show_name: true
card_mod:
style: |
ha-card {
color: white;
border: none;
{% else %}
{% else %}
{% endif %}
{% endif %}
entity: climate.living_room
tap_action:
action: more-info
color_type: icon
icon: mdi:calendar-clock-outline
color: white
show_state: false
show_name: true
card_mod:
style: |
ha-card {
color: white;
border: none;
{% else %}
{% else %}
{% endif %}
{% endif %}
tap_action:
action: url
url_path: https://home.nest.com/thermostat/02AA01AC28140A0G
color_type: icon
icon: mdi:history
color: white
show_state: false
show_name: true
card_mod:
style: >
ha-card {
color: white;
border: none;
{% else %}
{% else %}
{% endif %}
{% endif %}
johnesc
(JohnEsc)
November 10, 2023, 3:41am
112
Thanks for all your help!
rseidler01
(Robert Seidler)
January 10, 2024, 9:26pm
113
Hi Daniel, can you tell me what this sensor is used for? I don’t see it referenced anywhere else…
- name: “Nest Heating Runtime”
unique_id: nest_heat_runtime
unit_of_measurement: ‘seconds’
state: “{{state_attr(‘climate.living_room’,‘elapsed_seconds’)|float(0) }}”
rseidler01
(Robert Seidler)
January 10, 2024, 9:38pm
114
Also, should 191% be 91%?
{% elif states('sensor.dining_room_time_to_temp')|float(0) < 86 %} In 1 Hour 25 Minutes
{% elif states('sensor.dining_room_time_to_temp')|float(0) < 191 %} In 1½ Hour
Seems like all other time increment in 5% …
dbrunt
(Daniel)
January 11, 2024, 7:48am
116
I’ve no idea now! It’s not referenced anywhere else in my config either!
Novan007
(Novan007)
July 21, 2024, 5:51pm
118
hello
can someone help me I have the thermostat working but wen i click to schedule i don’t receive a schedule but a thermostat? Is there something i can do to receive the schedule ?
dbrunt
(Daniel)
August 14, 2024, 11:16pm
119
You need to have the Scheduler
integration installed.
