It’s keep restarting and web ui show “502 Bad Gateway nginx”
Flow inside my node-red including
1.Call state of entity
2.Capture mqtt from broker
3.Send data from hassio to influxdb
4.Some HTTP request
What make it restart loop like this
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 6.0.3
You are running the latest version of this add-on.
System: HassOS 3.8 (armv7 / raspberrypi3)
Home Assistant version: 0.104.3
Supervisor version: 195
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
patching file nodes/ui_base.html
Hunk #1 succeeded at 1243 (offset 712 lines).
audited 72 packages in 3.966s
found 5 vulnerabilities (1 moderate, 4 high)
run `npm audit fix` to fix them, or `npm audit` for details
[cont-init.d] node-red.sh: exited 0.
[cont-init.d] user.sh: executing...
[cont-init.d] user.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[14:04:24] INFO: Starting Node-RED...
> hassio-addon-node-red@ start /opt
> node $NODE_OPTIONS node_modules/node-red/red.js "--settings" "/etc/node-red/config.js"
31 Jan 14:04:28 - [info]
Welcome to Node-RED
31 Jan 14:04:28 - [info] Node-RED version: v1.0.3
31 Jan 14:04:28 - [info] Node.js version: v12.14.0
31 Jan 14:04:28 - [info] Linux 4.19.93-v7 arm LE
31 Jan 14:04:29 - [info] Loading palette nodes
31 Jan 14:04:37 - [info] Dashboard version 2.19.3 started at /endpoint/ui
31 Jan 14:04:38 - [info] Settings file : /etc/node-red/config.js
31 Jan 14:04:38 - [info] Context store : 'default' [module=memory]
31 Jan 14:04:38 - [info] User directory : /config/node-red/
31 Jan 14:04:38 - [warn] Projects disabled : editorTheme.projects.enabled=false
31 Jan 14:04:38 - [info] Flows file : /config/node-red/flows.json
31 Jan 14:04:38 - [info] Server now running at http://127.0.0.1:46836/
31 Jan 14:04:38 - [info] Starting flows
[14:04:38] INFO: Starting NGinx...
nginx: [alert] detected a LuaJIT version which is not OpenResty's; many optimizations will be disabled and performance will be compromised (see https://github.com/openresty/luajit2 for OpenResty's LuaJIT or, even better, consider using the OpenResty releases from https://openresty.org/en/download.html)
31 Jan 14:04:40 - [error] [twitter out:Tweet] missing twitter credentials
31 Jan 14:04:40 - [info] Started flows
31 Jan 14:04:40 - [info] [mqtt-broker:a96e8f4a.34c398] Connected to broker: mqtt://192.168.1.7:1883
[14:04:43] INFO: Starting Node-RED...
31 Jan 14:04:46 - [info]
Welcome to Node-RED
31 Jan 14:04:46 - [info] Node-RED version: v1.0.3
31 Jan 14:04:46 - [info] Node.js version: v12.14.0
31 Jan 14:04:46 - [info] Linux 4.19.93-v7 arm LE
31 Jan 14:04:47 - [info] Loading palette nodes
31 Jan 14:04:55 - [info] Dashboard version 2.19.3 started at /endpoint/ui
31 Jan 14:04:56 - [info] Settings file : /etc/node-red/config.js
31 Jan 14:04:56 - [info] Context store : 'default' [module=memory]
31 Jan 14:04:56 - [info] User directory : /config/node-red/
31 Jan 14:04:56 - [warn] Projects disabled : editorTheme.projects.enabled=false
31 Jan 14:04:56 - [info] Flows file : /config/node-red/flows.json
31 Jan 14:04:56 - [info] Server now running at http://127.0.0.1:46836/
31 Jan 14:04:56 - [info] Starting flows
31 Jan 14:04:57 - [error] [twitter out:Tweet] missing twitter credentials
31 Jan 14:04:58 - [info] Started flows
31 Jan 14:04:58 - [info] [mqtt-broker:a96e8f4a.34c398] Connected to broker: mqtt://192.168.1.7:1883
[14:05:00] INFO: Starting Node-RED...
31 Jan 14:05:04 - [info]
Welcome to Node-RED
31 Jan 14:05:04 - [info] Node-RED version: v1.0.3
31 Jan 14:05:04 - [info] Node.js version: v12.14.0
31 Jan 14:05:04 - [info] Linux 4.19.93-v7 arm LE
31 Jan 14:05:05 - [info] Loading palette nodes
