Unfortunately this is beyond my skill level. I’ve been watching the link @ggoldfingerd has posted above.
It looks like the fix was merged to upstream openzwave and slated for 91.2 but that mile-stone was removed yesterday. Hopefully this makes it in for 91.3.
I think now it’s up to HA developers to merge the fix into homeassistant-pyozw. I tried upgrading to 91.2 and it still did not work
I also tried to update to 91.2 yesterday. I was expecting it to be fixed because the milestone was in 91.2. However I had the same issue as @troy and @Dayve67. The changes were rolled into homeassistant-pyozw==0.1.4 so we have to wait until HA starts using that version.
Update and workaround on the z-wave issue. 91.3 is still using homeassistant-pyozw==0.1.3
However homeassistant-pyozw==0.1.4 does install successfully
Temporary workaround is to manually edit zwave/__init__.py to use pyozw==0.1.4.
We’ll have to do this every homeassistant update until they bump the version but it seems to work without any issues. To be clear this is a workaround. This is working fine on my system so I wanted to share but use at your own risk
First upgrade to latest homeassistant. As of today that’s 91.3
Next edit zwave/__init__.py
iocage console homeassistant
service homeassistant stop
ee /srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/zwave/__init__.py
On line 40 you will see: REQUIREMENTS = ['pydispatcher==2.0.5', 'homeassistant-pyozw==0.1.3']
Change this to : REQUIREMENTS = ['pydispatcher==2.0.5', 'homeassistant-pyozw==0.1.4']
@Gabriel
I’m really sorry but I don’t think I can offer much help. I’m just completely unfamiliar with docker so I have no ideas for troubleshooting.
You say hass.io is running well? I assume you have internet inside your Ubuntu VM? That’s the first place I would start. If your VM is OK I don’t think this would be a FreeNAS issue but rather a general question for anyone using a VM running Ubuntu to host hass.io. I think you can just start a general topic and ask about the issues your having.
You would probably get better help making a separate topic. I don’t think many people not using FreeNAS would be reading this topic to offer assistance. But please do tag me. I would like to follow along with your experience and see you get this working 100%.
I do have internet inside of the VM. As a matter of fact, in that VM I run under Ubuntu Server Hass.io and Ombi. It is probably a permissions issue.
Anyways, I will try to make a new post on the FreeNAS forums.
Really helpful guide, I am trying to get my pulse eight CEC usb adaptor to work via this. I have had it working in a previous version of FreeNAS but I can’t for the life of me remember how I did it.
I see the adaptor under FreeNAS as uhid0 I have forwarded this via the method you used for Zwave but it still cant connect in the jail
I get the below error when connected and nothing when the adaptor is discounted
ERROR: [ 3380]
error opening serial port ‘/dev/ttyU0’: No such file or directory
Since the release of 0.81 or something around that z-wave stopped working for, there was a bug with freebsd systems, it was supposed to be fixed in 8.2, but I have since not been able to get my aeonlabs z-wave stick to work, anyone here that has it working with latest version of hass?
Welcome! I have zwave working in the latest homeassistant release, 93.2.
You are correct, there have been a few issues that have come and gone but as of today zwave should be working without any additional fixes or workarounds related to Home Assistant. What version of Home Assistant are you currently running?
There was also a change in FreeNAS at some point, which now requires a custom devfs_ruleset to be created on the FreeNAS host and then the Home Assistant jail must be set to use it. Without this, your jail will not be able to see your USB zwave controller. What version of FreeNAS are you running? Have you created the custom_devfs?
Not working can mean a lot of things? Can you please describe the zwave issues your having?
Do your Home Assistant logs shown any errors related to zwave? What do they say?
Assuming something is not physically wrong with zwave device we should be able to help get you back and running.
Hi, when I setup the jail a while back I did not follow your recommendation and opened all the devices for the jail to see.
I am running 0.93.2, updated today.
When I try to add the z-wave device I get the following error: “Unknown error” in the integration view, when looking in the logs I see this:
Error handling request
File “/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_protocol.py”, line 418, in start
resp = await task
File “/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_app.py”, line 458, in _handle
resp = await handler(request)
File “/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
return await handler(request)
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py”, line 33, in real_ip_middleware
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/ban.py”, line 68, in ban_middleware
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/auth.py”, line 216, in auth_middleware
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/view.py”, line 115, in handle
result = await result
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/config/config_entries.py”, line 154, in post
return await super().post(request, flow_id)
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/data_validator.py”, line 46, in wrapper
result = await method(view, request, *args, **kwargs)
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/data_entry_flow.py”, line 86, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/data_entry_flow.py”, line 80, in async_configure
flow, step_id, user_input)
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/data_entry_flow.py”, line 98, in _async_handle_step
result = await getattr(flow, method)(user_input) # type: Dict
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/zwave/config_flow.py”, line 50, in async_step_user
user_path=self.hass.config.config_dir)
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/srv/homeassistant/lib/python3.6/site-packages/openzwave/option.py”, line 82, in init
libopenzwave.PyOptions.init(self, config_path=config_path, user_path=user_path, cmd_line=cmd_line)
File “src-lib/libopenzwave/libopenzwave.pyx”, line 690, in libopenzwave.PyOptions.init
libopenzwave.LibZWaveException: “LibOpenZwave Generic Exception : Can’t autoconfigure path to config”
I’m not really a fan of these automatic discovery integrations, they usually give me headaches as well. I just assume we are a very small portion of users on FreeNAS so they can not always take us into consideration.
I just add thing to my configuration the old way. Everything works much better that way and zwave is no exception. The End of your errors look like zwave can’t find it’s own configuration which was something that always needed to set manually as long as I’ve been using HA on NAS
If you remove the automatic integration and setup zwave to your configuration.yaml, you can set this yourself and will hopefully start working. Either Way this should at least be the first step to get started.
I don’t know if you already have or even need a network_key but just in case… I used the following command from inside the jail (won’t work from FreeNAS host) to generate my network_key.
cat /dev/urandom | tr -dc '0-9A-F' | fold -w 32 | head -n 1 | sed -e 's/\(..\)/0x\1, /g'
Well thank you again, so yeah, the only way that worked (for me) was to add it manually to the config.yaml file as explaiined above, now i cand find the stick, lets try and pair some z-wave units now
I’m stuck at the point of mounting a dataset inside the fail. I keep getting the error that resulting directory does not exist. I looked inside the jail and could not find /home/hass myself
Below is what I entered and what I get I get in return.
% sudo iocage fstab -a homeassistant “/mnt/disk1/user/hass /home/hass nullfs rw 0 0”
Destination: /mnt/disk1/iocage/jails/homeassistant/root/home/hass does not exist or is not a directory.
I tired to work around this by creating the directory myself then running the command which worked but at the end of the install none of the preconfigured yaml files loaded. They were all the barebones stock ones.
I also tried after the install copying the files out of that directory creating the Mount and then copying them back in. This also produced the stock yaml files.
Not sure what I am missing I’m a week into all this (Linux, FreeNas, Home Assistant) so I’m not sure what I’m doing wrong.
Thank you for making this guide and all the help you’ve provided others and myself. Do you have a donations page or patreon for all the work you’ve done you deserve something.
So in Home Assistant can you can confirm what directory it is looking for your configuration files.
It should be /home/hass/homeassistant. You can easily see this in the HA gui
Let me know were that leaves you. Keep in mind if your trying to use use appdaemon or the configurator I have not give any commands to copy those files so this is only for HA. If this much works then the same process can be used to also copy appdaemon and the configurator but lets start with HA and go from there.
