hello, I’m new here.
My name is Gerben and i have a homey connected to my raspberry pi 3
with hassio.
Now i have a set of icons local i wanna use for the devices.
but it doesn’t work.
i have a folder called www
in the folder are te icons with png extension.
But nothing happens.
is your www in the config folder? Also what I do for icons is i put /local/icon.png if i put icon.png in the www folder. There is probably a better way but I hope this helps.
Edit: also welcome im sort of new but i still dont know how to do really anything
The www folder is were my yamfiles are
When i try in the config ui edit my sensor
The part with icon and place there the text: /config/kwh.png and i reboot
Then the base icon is away but there is no new icon
Place kwh.png into www folder. As @nickrout said, accessing it will be /local/kwh.png
Second, if you are using customize.yaml, then you need to place the png location in the entity_picture field, not the icon. Icon is used for built-in mdi icons only.
Its not working for me, but I do get the question mark icon, so the JS is being read. What svg types work, what size, etc are proven to work? Well done for working on this, I hope to use it for a few icons I’ve got.
The Icons from the Hue Icon Pack (which also the question mark icon is part of) work fine for me. Have not tried others as i primarily wanted to use the hue icons.
have a look at https://github.com/arallsopp/hass-hue-icons if you’re interested in the Hue icons, @arallsopp is actively updating this resource, and the icons are beautiful
Hey! Thanks @Mariusthvdb. There are over 200 icons in the pack now, including more than 140 custom icons created especially for the HA community. Always good to hear it being used.
I have tried a lot, but it does not work. Can enybody help me?
This is what is in my configuration.yaml
homeassistant:
entity_picture: /local/nibe-logo.png```
nibe-logo.png is in the config/www directory.
This is what I get back:
expected a dictionary for dictionary value @ data['customize']
What do I wrong?
Invalid config for [panel_custom]: [entity_picture] is an invalid option for [panel_custom]. Check: panel_custom->panel_custom->0->entity_picture. (See /config/configuration.yaml, line 178).
