At Notifications I receive the message
Login attempt failed
Login attempt or request with invalid authentication from 109.x.y.47 (109.x.y.47). See the log for details.
I have installed Duck DNS add-on. The log is fine and the IP address is registered correctly and dynamically.
I have configured in my configuration.yaml:
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: true
login_attempts_threshold: 5
homeassistant:
name: Lavender name Hill
latitude: 42.x
longitude: 18.y
elevation: 250
country: ME
unit_system: metric
currency: EUR
external_url: "https://domain.duckdns.org:8123"
internal_url: "https://domain.duckdns.org:8123"
time_zone: "Europe/Amsterdam"
Now and then I had issues, but now it’s completely giving a problem as in the file ip_bans.yaml every hour my own IP address 109.x.y.47 is registered. The iPad at the wall (it’s a rental) I cannot get it working from a distance. I have full access to it, so I hope I can fix this issue from my own home.
By the way, I have installed 5 sites, all based on the same recipe. This house is the only one having this issue. The others not and they are identical.
