It just wont boot up again it seems. If I unplug the SSD and flash it with a new HA install will the Pi boot from the SSD?
If that works then it seems fairly easy and I can just get it done. Have been trying to get it to boot in safe mode for a few hours now and this time it doesn’t seem to happen.
If your drive is not failing, it will boot up a fresh install, you will need a recent backup to restore, so make sure you have a few available incase one does not work.
Generally very easy to do, but you really need an idea of why it failed to boot if you want to have long term success.
Thanks.
I know now that it’s due to an custom component. So just avoid installing it again and I should be fine I guess.
