My project: Chicken coop automation
Hi folks
I thought I’d add some words about an ESPHome project I’ve had during 2021. Nothing fancy really but fun to do. We got an opportunity to “adopt” 8 chickens from a friend and while I was building the cage and chicken coop I thought to myself, this calls for some automation. I mean, manually opening and closing a chicken coop door is so 2010. :slight_smile:
As I like to fiddle with most things technical the project grew from the initial requirement of controlling the coop door to something…else. This is the result taken from the Home Assistant dashboard, pardon the Swedish labels. The whole setup is powered by a 12v 18ah AGM battery charged by a 200W solar panel.
*I had to have a camera in the coop and I had a Raspberry Zero lying around for another project. Raspberry pi zero w + camera module + protective case camera box diy kit Sale - Banggood.com completed the setup and I moved all the pieces into a dust proof case.
*I also had a spare 433mhz temperature sensor which was already set up in HA with rfxcom, only took a rename and a good location to get good data.
*Now for the fun part. It’s basically an end-stop cover setup with my complete ESPHome code below. The servo driving the coop dor is a continuous drive servo.
*Two 433mhz door sensors are used, “Hönsgården” for the cage door and “Hönshusdörr” for the entrance to the coop (for people).
*The last two switches in HA are actually helpers controlling the camera and 12v LED strip.
*I dug up a guide on how to measure battery voltage using a divider curcuit and input A0 on the Wemos, I use this to drive some automations in HA.
*Last piece are status of the actual relay switches for the camera and LED strip.
cover:
  - platform: endstop
    #assumed_state: false
    #optimistic: false
    device_class: garage
    open_action:
      - servo.write:
          level: 60.0%
      - logger.log: "Cover opening"
      - lambda: id(coopdoor).publish_state(COVER_OPEN);
    open_duration: 10sec
    open_endstop: top_endstop
    close_action:
      - servo.write:
          level: -60.0%
      - lambda: id(coopdoor).publish_state(COVER_CLOSED);
      - logger.log: "Cover closing"
    close_duration: 10sec
    close_endstop: bottom_endstop
    stop_action:
      - delay: 100ms
      - servo.write:
          level: 0%
      - logger.log: "Motor stopped COVER"
      - servo.detach: my_servo
    max_duration: 15sec
binary_sensor:
#TopSwitch
  - platform: gpio
    pin:
      number: D5
      inverted: true
      mode: INPUT_PULLUP
    on_press:
      then:
        - logger.log: "Motor stopped TOP"
        - lambda: id(coopdoor).position = COVER_OPEN;
        - cover.stop: coopdoor
#BottomSwitch
  - platform: gpio
    pin:
      number: D6
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      then:
        - logger.log: "Motor stopped Bottom"
        - lambda: id(coopdoor).position = COVER_CLOSED;
#Open door
  - platform: gpio
    pin:
      number: D3
      inverted: true
      mode: INPUT_PULLUP
    on_click:
      then:
          - logger.log: "Openbutton"
          - lambda: id(coopdoor).publish_state(COVER_OPERATION_OPENING);
          - cover.open: coopdoor
#Close door
  - platform: gpio
    pin:
      number: D4
      mode: INPUT_PULLUP
      inverted: true
    on_click:
      then:
        - logger.log: "Closebutton"
        - lambda: id(coopdoor).publish_state(COVER_OPERATION_CLOSING);
        - cover.close: coopdoor
servo:
  - id: my_servo
    output: pwm_output
output:
  - platform: esp8266_pwm
    pin: D1
    frequency: 50 Hz
#  - platform: wifi_signal
#    name: "WiFi Strength"
#    update_interval: 60s
#  - platform: uptime
#    name: "Uptime"
  - platform: adc
    pin: A0
    update_interval: 30 seconds
    lambda: return id(VCC).state * 33.30;
    unit_of_measurement: V
    accuracy_decimals: 2
switch:
  - platform: gpio
    pin: D8
  - platform: gpio
    pin: D7
Below are the related automations in HA.
*To save battery I turn off the camera at night, battery drain goes from 0.4A to 0.2A
alias: CoopCameraOff
description: ''
  - platform: time
    at: '23:00'
condition: []
  - service: switch.turn_off
      entity_id: switch.camera
mode: single
*If the battery has enough volts, I turn on the camera again in the morning.
alias: CoopCameraOn
description: ''
  - platform: time
    at: '07:00'
condition:
  - condition: numeric_state
    entity_id: sensor.kalibreradvcc
    above: '11.8'
  - service: switch.turn_on
mode: single
*I want the entrance to turn on the LED strip, but only if there is enough power in the battery and turn it off again when the door is closed…but not if the LED has been commanded ON by the helper. I’m thinking the poor critters will need light during the winter. (I live in Scandinavia)
alias: CoopDoorLED
description: ''
  - platform: state
    entity_id: binary_sensor.dorrsensor2
condition: []
  - choose:
      - conditions:
            above: '11.7'
          - condition: state
            state: 'on'
        sequence:
              entity_id: switch.led_strip
      - conditions:
          - condition: state
            state: 'off'
          - condition: state
            entity_id: input_boolean.manualled_strip
            state: 'off'
        sequence:
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
    default: []
mode: single
The last one is a bit of a doozy. I want some things done depending on the battery volts. Turn off the LED first, since its using the most power, and disable the input selector. Then turn off and disable the camera. Do everything in reverse when the battery has charged enough.
alias: CoopVoltageActions
description: ''
  - platform: state
condition:
    below: '12'
  - choose:
      - conditions:
            below: '11.8'
        sequence:
          - service: python_script.set_state
              data_template: null
              state: unavailable
          - choose:
              - conditions:
                    below: '11.7'
                sequence:
                      entity_id: input_boolean.manualcamera
                      data_template: null
                      state: unavailable
      - conditions:
            above: '11.8'
        sequence:
              data_template: null
              state: '{{states(''switch.camera'')}}'
          - choose:
              - conditions:
                    above: '11.9'
                sequence:
                      data_template: null
                      state: '{{states(''switch.led_strip'')}}'
            default: []
    default: []
mode: single
Some photos of the end result.
I realise there are alot more to write but this is a quick start. Expect some editing later.
Peace out and thank you for a great forum.
/Fredrik
I love “little” :wink: projects like this.
I have a project for my fish tank that controls the lights, heater, filter, air pump and power head flow pumps. None of those things I can’t do myself but why should I when HA makes it so easy to do it automatically!?
It’s become a pretty extensive automation package with all of the little nuances that i thought of for lighting and such. And it has notifications for any important failures in the system - heater stays on or doesn’t come on, filter stops running, things like that.
I even have a button I push when I feed the fish that turns off the filter and all the automations for 5 minutes to let then eat and then turns everything on to circulate the extra bits thru the filters. And if I haven’t fed them by 2 o’clock it reminds me.
So I get how such “simple” things turn into a huge project pretty quickly.
But it was fun. :laughing:
Smart chickens, who’d a thought?
Cool project. What make/model of server did you use? thx
Hi Fantangelo
Thank you. I’m not sure what you mean by “server”. The ESP is a Wemos D1 mini and HA is running on a Raspberry Pi4.
/Fredrik
grrrr, sorry meant servo, not server. thx
:slight_smile:
The servo is this one. TD-8120MG Waterproof Digital Servo - 20kg - Continuous - TD-8120MG-CONT
Thanks for the info!
Hi Fredrik. This is great and looks like something I’d like to do. I don’t suppose you have schematics of your setup do you?
Thanks for sharing this build!
To anyone who has a similar build, did you face problems with the continuous servo’s not remaining open?
It depends a bit on the weather I think, but from time to time my doors will close by themselves because they seem heavy enough to unwind the wound-up rope while the servo is unpowered.
A non-continous servo could remain powered to maintain its desired position, but AFAIK this is not possible with continuous servo’s.
I already tried adding some logic to the ESPHome configuration to re-open the doors when they close unexpectedly, but this made the configuration significantly more complex, didn’t work as intended and also has the side effect of unintentionally opening the doors when they should be closed.
Guys, were do you find a motor that’s has a wheel, so the rope can rotate on it? I don’t find it on AliExpress
