My script won't open in UI - I get a blank screen!
Bit of a strange one this - I’ve made a simple script, but when I try to open the script to edit it, I get a blank screen. This happens on the web and in the iOS app. I can duplicate the script, which enables me to edit it and save a new version, but all new versions I’ve saved also can’t open, they also go to a blank screen. But my other scripts open fine! Has anyone ever had this bug and can anyone shed any light on how I might be able to fix it please? I’m on macOS and Firefox & Safari, and iOS app.
Thank you!
maybe paste here the script contents?
You must have altered configuration.yaml. Can you please post it’s contents?
Thanks both. The script is as follows:
alias: Night fade down 3 (Duplicate)
sequence:
  - repeat:
      count: 10
      sequence: null
  - repeat:
      sequence:
        - delay:
            hours: 0
            minutes: 0
            seconds: 60
            milliseconds: 0
        - data:
            volume_level: "{{ state_attr('media_player.daphne', 'volume_level') - 0.01 }}"
            entity_id: media_player.daphne
          action: media_player.volume_set
      while:
        - condition: numeric_state
          attribute: volume_level
          above: 0
  - action: media_player.media_stop
    metadata: {}
    data: {}
mode: restart
icon: mdi:weather-night
description: ""
The configuration.yaml is as follows:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
media_player:
  - platform: cambridge_cxn
    host: 192.168.14.11
#  - platform: bluesound
#    hosts:
#    - host: Daphne.local
influxdb:
    api_version: 2
    ssl: false
    host: 192.168.14.2
    port: 8086
    token: b4UAVI5NUhnpanxvptlaJfH-AEr9zH0LVyCvjrhotEyQD_Sm4TMbDMl6OJl_d9C0aoaqi50nn3i56dm_whsyQw==
    organization: timonium
    bucket: book 1
    tags_attributes: friendly_name
    include:
        entities:
        - sensor.oreithyia_atmospheric_pressure
        - sensor.oreithyia_carbon_dioxide
        - sensor.oreithyia_humidity
        - sensor.oreithyia_pm2_5
        - sensor.oreithyia_radon
        - sensor.oreithyia_temperature
        - sensor.oreithyia_vocs
        - sensor.home_outdoor_temperature
        - sensor.home_solar_percentage
        - sensor.home_heating
        - sensor.home_humidity
        - sensor.home_temperature
        - sensor.home_tado_mode_2
        - sensor.leto_temperature
        - sensor.leto_humidity
That part isn’t valid
Amazing. Deleting that, it works again. Thank you - I hadn’t managed to check the yaml because of how hard it was to access it (having to duplicate the script then edit in yaml). Thanks very much.
