Hi Everyone,
I wanted to share my solution for controlling any Android App from Lovelace. It’s got a few different moving parts, but overall I don’t think it’s that difficult to implement. I wanted to get feedback from the HA community to see if anyone has ideas on a better / more efficient way of implementing the same concept.
My solution involves a few different parts:
An Android App called ScreenStream that streams your Android screen to a local url (like http://192.168.1.156:8080/stream.mjpeg)
joaoapps Tasker and AutoRemote that work together to create a cloud-based API that you can use to POST http requests and take action on your Android device.
joaoapps AutoInput to handle more complicated actions on the Android Device.
A few different Home Assistant Scripts, Automations, updates to configuration.yaml and the Lovelace yaml.
Here’s a ~ 9 minute video I just put together illustrating the prep work that needs to be done on your Android device using Tasker, etc.
Add the following to your configuration.yaml:
(NOTE: Replace ‘192.168.1.156’ with the IP of your Android device)
(NOTE: Get the rest_command URLs via AutoRemote (see the last minute of the above video))
input_select:
android_controls:
options:
- Select Action
- Toggle ScreenStream
- View Ring Front Door
initial: Select Action
icon: mdi:apps
stream:
camera:
- platform: mjpeg
mjpeg_url: http://192.168.1.156:8080/stream.mjpeg
rest_command:
android_toggle_screenstream:
url: 'https://autoremotejoaomgcd.appspot.com/sendmessage?key=...&message=Toggle%20ScreenStream'
android_view_ring_front_door:
url: 'https://autoremotejoaomgcd.appspot.com/sendmessage?key=...&message=Ring%20Live%20View'
Add the following to your scripts.yaml:
android_reset_input_select:
alias: Android Reset Input Select
sequence:
- service: input_select.select_option
data_template:
entity_id: input_select.android_controls
option: 'Select Action'
alias: Refresh Android Screen Stream
sequence:
- service: rest_command.android_toggle_screenstream
alias: View Ring Front Door
sequence:
- service: rest_command.android_view_ring_front_door
Add the following to your automations.yaml (make sure the IDs are not the same as any of your existing Automations):
- id: '1572704111917'
alias: AndroidControlToggleScreenStream
description: ''
- entity_id: input_select.android_controls
platform: state
to: Toggle ScreenStream
condition: []
- service: script.toggle_screenstream
- data: {}
service: script.android_reset_input_select
- id: '1572704356298'
alias: AndroidControlLaunchRing
description: ''
platform: state
to: View Ring Front Door
condition: []
- service: script.android_view_ring_front_door
- data: {}
Now, let’s make a new tab in Lovelace by adding the following yaml via the “Raw Config editor”:
- cards:
- entities:
- input_select.android_controls
type: entities
- camera_image: camera.android_stream
camera_view: live
entities:
- camera.android_stream
title: My Android Device
type: picture-glance
panel: true
path: android
title: AndroidControl
Now you can navigate to the “AndroidControl” tab in your Home Assistant frontend and execute a couple of Tasker commands via the input_select dropdown above the livestream of the Android screen! You, of course, can add as many additional Tasker commands as you want following the patterns illustrated in the above.
Any feedback/criticism is welcome - especially anything that makes this more efficient (less moving parts, etc).
