I have set up my HA with data to influxdb, which work great. How ever I do not get the values from my system monitor into influxdb. E.g memory_use_percent.
I can se it in the UI, under history, but not in influxdb/grafana.
Rather than, like for most things you query, doing this:
SELECT mean("value") FROM "autogen"."sensor.processor_use"
You need to do this
SELECT mean("value") FROM "autogen"."%" WHERE ("entity_id" = 'processor_use')
If you’re using the visual query editor then you need to change from to autogen, click select measurement and choose % and then you click the + next to WHERE, choose entity_id and then select the sensor you want to read the data from.
