My take on a home dashboard running on the Lenovo ThinkSmart View and managing multiple devices running Fully Kiosk
I have no clue where to find it in the settings. Re-read all options several times and I am unable to find anything.
Bit surprise I am missing something but no idea what is it… :s
Have you enabled dev mode?
Looks like there’s two ROMs available - Lineage 15.1 and Mattmon’s 8.1 ROM. It looks like Lineage doesn’t enable using tapping of the display to wake up the screen. Wondering if that feature is available on other ROMs, like Mattmon’s 8.1 ROM?
Yes I did, but even still not seeing anything related with reboot/shutdown or similar in my LineageOS :frowning:
i’m at work but will have a look, hopefully tonight or over the weekend
Maybe it’s not the right place, but I’m trying… My Lenovo have worked for 1 month and today the screen don’t have backlight. It’s all black… the brightness is at 100% but no screen. Try factory reset and nothing change
Correct. Unfortunately this Lineage build doesn’t support tap screen to wake. I think Mattmon’s build does IIRC, but there are other issue with that build - eg audio. It’s a toss up as to which features you need. Never is perfect but in my testing of both, Lineage came out on top.
Nice work! I have two questions: are your washer / dryer „smart”? I have quite old washer and I am wondering if there is any way to get it into HA (except of using a smart plug to monitor energy use on it…)
Are you using the Lenovo camera to wake up fully kios from sleep mode? Is there a way to get this entity active in HA?
Thanks a lot in advance…
Best, J
Hi, yes I have Samsung smart washer and dryer. They’re excellent machines. They connect to SmartThings and I then get the data from that. It is cloud based however but it has been working reliably so far. Probably one of the most useful sets of data to show on a dashboard :grin:
To wake the screens, I have a set of automations linked via mmWave presence sensors in each location. That works flawlessly.
Thanks a lot!
The Playstore version of WallPanel seems to constantly crash. Anyone find a stable version that works with LineageOS on the Lenovo?
Not being able to wake the screen is more of an issue than I originally thought. The volume buttons don’t wake the screen. And there’s no power button to tap. The only way is to slide the camera privacy shuttle slider back and forth, that’s really hard to do. I’m not sure that slider is designed to take that much abuse.
I guess a motion sensor to make a wake API call is the only solution if you don’t want the display on all day long.
The volume button do wake the screen - if you have that set in the settings. Looks like you don’t have it set.
Hi @bjm
Did you have chance to have a look?
Thank you!
bugga, sorry, totally forgot, the long weekend got away from me, I’ll take a look tonight, I’ll put a calendar reminder on for me :slight_smile:
Hey @miriumar if you go to settings > hardware switch settings andcyou eill get these settings
Hi @bjm
I can not see this option on my device under settings. Maybe because your version is different than another I installed: Is this the perfect standalone tablet for HA? ?
However from your options looks like there is no way to shutdown the device either, mainly wake or sleep one. I wanted to find a way to shutdown it properly without need of power off the electricity… but looks like it is getting hard :smiley:
Thank you for your support anyway!
My thread (this one) is about Lineage and not Mattmon’s 8.1. They are quite different although both based on Android 8.1.
Thanks for reply @pgale I don’t know why but convinced Mattmon’s were based on LineageOS 15.1…
I may need to consider installing yours since have shutdown capability which I want and seems you got it really stable.
Thanks for sharing!
Not sure Lineage does shut down. I don’t ever do that so haven’t tested that. I think someone else said there were problems. None of these ROMs are 100% perfect, Lineage is the best for my use though. I think Lineage needs root access to shut down and restart and that was tricky when I tested it - but didn’t persevere.
