Hi all, finally i succesful integrated my google home to hassio…i followed this https://home-assistant.io/components/google_assistant/ but my problem is:
My tv and all other devices is recognized as a Light, so when i say: Hey google turn off the light the tv will be turned off also.
Any suggestions?
Thank you
I don’t have my Google Home mini yet (this weekend!) but I think this is to be expected. Google assistant believes it is talking to a Philips Hue bridge where everything is a light. Maybe you can create some kind of automation that turns on/off all the lights - and ask Google to turn on and off that instead.
What i did was assign all lights to a room (Living room) and then i can say: ‘Turn on living room’. I didn’t assign the television to a room so it only gets switched when i explicitly say: ‘Turn on/off television’
Mine shows up as a switch in my home control section, Do you have anything special setup for your tv in HA? I have configured though via my broadlink rm mini. I can use my google home mini or full size google home to shut it off just by saying ok google turn off samsung tv , or turn on samsung tv.
you can specify in the config for the TV not to be exposed to HA, that way it wont turn off with the lights.
