Termite Swarm Sensor
Swarming termites is a strange phenomenon that happens during a specific timeframe every year in the southern US city I live in. I’m sure it must happen other places, but I have lived in 4 different states, and this is literally the only place I have ever experienced anything like it. No matter how well you think your house is sealed, if a termite swarm comes by, they will get in - especially if your porch lights (or even inside lights) are on. It’s truly borderline old testament stuff. This project creates a sensor that tracks when someone tweets about termites in my city during termite swarm season and sends an actionable alert with the content of the tweet, the option to turn on a “Termite Mode” script that turns off all of the lights, and which gives me the option to reset it or look at more tweets on Twitter. Outside of Home Assistant, I have no programming experience, so I would not be surprised if programming best practices are not in play here. I’m sure there are simpler ways to accomplish this and or streamline.
Home Assistant Helpers
I used HA’s helpers to set up an input_boolean entity and an input_text entity.
I created the input_boolean entity in the UI by going to Configuration/Helpers and clicking the add button, then “Toggle.” I then added a name, in my case “Termite Detector”. This entity will be used to turn on the “Termites May Be Swarming” sensor that would stay “on” until turned off manually or by an automated reset.
I created the input_text entity in the UI by going to Configuration/Helpers and clicking the add button, then “Text.” I then added a name, in my case “Termite Tweets”. This entity will be used to store text (Tweets) delivered by the IFTTT webhook.
IFTTT Webhook
This sensor uses an IFTTT integration to trigger a webhook if certain Twitter search terms are met. In testing, there has been an up to 8 minute delay between a tweet and the webhook trigger.
**Disclaimer: when I first set this up, IFTTT was still totally free. Both then and now, these are the only applets I use, so I’m still under the limit on the free account.
IFTTT Applet Setup
After setting up the IFTTT webhook using the integration instructions linked above, I created two applets in IFTTT.
IF THIS
For the “If this” input, I chose Twitter, linked a twitter account following the IFTTT instructions, and then chose “New tweet from search” for the trigger. I used Twitter’s search operators to search for “# “termite” OR “termites” AND “(the name of my city)” -RT”. This searches for tweets that contain the words “termite” OR “termites” AND “(the name of my city)” while excluding retweets.
THEN THAT
I then chose the “Webhooks” service for the “then that” action. I filled the “URL” with my webhook address that was created during the IFTTT Home Assistant integration setup, set the “Method” to “POST,” “Content Type” to “application/json,” and “Body” to
"action": "call_service",
"service": "input_boolean.turn_on",
"entity_id": "input_boolean.termite_detector",
"text": "tweet",
"tweet": "@{{UserName}}: {{Text}}"
The “action,” “service,” and “entity_id” data classes are explained in the “USING THE INCOMING DATA” section of the HA IFTTT integration documentation. I added two data classes labelled “text” and “tweet” to categorize the webhook for additional automations, and pass the actual triggering tweet and username into Home Assistant, respectively. The webhook as written turns on the “input_boolean.termite_detector” entity without any additional configuration in Home Assistant.
I will create automations later to use the additional incoming data from IFTTT.
configuration.yaml
There are two sections that have to be added to configuration.yaml for this tracker:
Template Sensors
First I created a termite_display template sensor which is outputting text based on the state of the input_boolean entity that I created using Helpers. If input_boolean.termite_detector is on, then the sensor will output “Termites May Be Swarming.” Otherwise, the sensor will output “Termites Not Detected.”
# configuration.yaml
##########Termite Alert Sensor##########
sensors:
termite_display:
value_template: >
{% if is_state('input_boolean.termite_detector', 'on') %}
{% else %}
{% endif %}
Actionable Notifications
This section sets up the part of the project that uses actionable notifications. I had some trouble doing this when I first did it for another project, but it’s fairly well documented here: https://companion.home-assistant.io/docs/notifications/actionable-notifications/
ios:
push:
categories:
- name: Termite Alert
identifier: 'termitealert'
actions:
- identifier: 'TURN_ON_TERMITE_MODE'
title: 'Turn on termite mode'
- identifier: 'RESET_TERMITE_SENSOR'
title: 'Reset Termite Sensor'
- identifier: 'SEE_TERMITE_TWEETS'
title: 'Check Tweets'
Scripts
I created two scripts for use in this project. One turns off all the lights in the house except a few that are on their lowest brightness. (This is “Termite Mode.”) The other resets the termite alert and clears tweets. I made these as scripts so I could control them both through automations and manual input buttons in the UI.
termite_mode:
alias: Termite Mode
sequence:
- service: light.turn_off
entity_id: all
- service: switch.turn_off
entity_id: switch.alley_lights
- data:
brightness_pct: 01
entity_id: light.lamp_left
service: light.turn_on
- data:
brightness_pct: 20
entity_id: light.master_bedroom_bedside_lamps
reset_termite_alert:
alias: Reset Termite Mode
sequence:
- service: input_boolean.turn_off
entity_id: input_boolean.termite_detector
- service: input_text.set_value
entity_id: input_text.termite_tweets
value: " "
Automations
I created five automations for the main part of this project, and I’ll do my best to explain them and the logic behind them: (I also have an Actionable Alexa alert, but I’m not going to cover that in this writeup.)
Automation Using IFTTT webhook to Send Actionable Notification
When the IFTTT webhook is triggered, this automation checks to make sure that a) it’s within 3 hours of sunset or before 10:30 pm, b) it’s between April 1st and August 1st, and c) the “input_boolean.termite_detector” entity is “off,” and if all conditions are met, it sends an actionable notification (“Someone is tweeting about termites in (the name of my city). Here is what they said”) to an iOS device with the options to “Turn on termite mode,” “Reset Termite Sensor,” or “Check Tweets.” The automation uses the event_data class I created (“tweet”) from the IFTTT webhook to pass the actual tweet through to the push notification. (’{{ trigger.event.data.tweet }}’)
# automations.yaml
- id: '1589933488026'
alias: Termite Alert - IFTTT Send Tweet Notification
description: ''
- event_data:
text: tweet
event_type: ifttt_webhook_received
platform: event
condition:
- after: sunset
after_offset: -03:00:00
condition: sun
- condition: template
value_template: "{% set n = now() %} {{ n.month >= 4 and n.day >=1\n or n.month\
\ <= 8 and n.day <= 1 }}\n"
- before: '22:30:00'
condition: time
- condition: state
state: 'off'
- data_template:
push:
category: termitealert
message: Someone is tweeting about termites in (the name of my city). Here is what they
said - '{{ trigger.event.data.tweet }}'
title: Potential Termite Swarm Alert
service: notify.mobile_app_iphone
Automation Turning on Scripts from Actionable Notification
These two automations are triggered by returns from the actionable notifications “Turn on Termite Mode” (which turns on the “Termite Mode” script and “Check Tweets” (which sends a second notification to the device that will open Twitter to the search terms when clicked). I have these automations in practice going to my phone and my wife’s phone, so in order to only send the Twitter link to the phone that requested it, I used the Developer Tools to listen to “ios.notification_action_fired” events to determine the “sourceDevicePermanentID,” and used that ID to trigger the notification. (There is a duplicate automation not included in this write up with the ID for my wife’s phone.)
# automations.yaml
- id: alias: Termite Alert - iOS/Alexa Action Trigger Termite Mode
description: ''
- event_data:
actionName: TURN_ON_TERMITE_MODE
event_type: ios.notification_action_fired
platform: event
- event_data:
event_id: actionable_notification_termite_mode
event_response: ResponseYes
event_type: alexa_actionable_notification
platform: event
condition: []
- data: {}
service: script.termite_mode
- alias: Termite Alert - Launch Twitter on iPhone
description: ''
- event_data:
actionName: SEE_TERMITE_TWEETS
sourceDevicePermanentID: ########-####-####-####-############
platform: event
condition: []
- data:
url: https://twitter.com/search?q=%22termite%22%20OR%20%22termites%22%20AND%20%22name%20of%20my%20city%22%20-RT&src=typed_query&f=live
message: Click Here.
title: See Tweets About Termites in (the name of my city)
Automation Resetting Termite Swarm Sensor Each Day or When Reset From Actionable Notification
This automation resets the input_boolean.termite_detector entity to “off” every day at 1:00 a.m., 8:00 am, and 3 hours before sunset, or when it is reset through the actionable notification. It’s conditioned to run only if sensor.termite_display is showing “Termites May Be Swarming.”
# automations.yaml
- alias: Termite Alert - Reset for the day
description: Resets termite alert at the end of the day if it is triggered
- at: 01:00:00
platform: time
- at: 08:00:00
platform: time
- event: sunset
offset: -03:00:00
platform: sun
- event_data:
actionName: RESET_TERMITE_SENSOR
platform: event
condition:
- condition: state
entity_id: sensor.termite_display
state: Termites May Be Swarming
- data: {}
service: script.reset_termite_alert
Automation Setting the Text of the Triggering Tweet
I added this automation to input the text of the tweet that triggered the Termite Swarm Sensor into the input_text.termite_tweets entity that I created in Helpers. This allows me to have a Lovelace card displaying the tweet and when it was sent. This data is pulled from the “tweet” data class that I created in IFTTT.
# automations.yaml
- alias: Termite Alert - IFTTT - Input Text Tweet for Sensor
description: ''
- event_data:
text: tweet
platform: event
condition: []
- data_template:
value: '{{ trigger.event.data.tweet }}'
Custom Card for Lovelace UI
I combined everything into a simple custom picture elements card. I had originally used an entity card with three button cards combined into stacks, but found I preferred the look of everything unified together, so I came up with this:
cards:
- elements:
- entity: sensor.termite_display
style:
bottom: 58%
color: black
font-size: 26px
left: 4.5%
transform: initial
type: state-label
state_image:
Termites May Be Swarming: 'https://i.imgur.com/x4O77NF.png'
Termites Not Detected: 'https://i.imgur.com/QX9GxS8.png'
unknown: 'https://i.imgur.com/QX9GxS8.png'
style:
left: 89%
top: 22%
width: 12%
tap_action:
action: none
type: image
- entity: script.termite_mode
state_image:
'off': 'https://i.imgur.com/g6XDKwQ.png'
'on': 'https://i.imgur.com/g6XDKwQ.png'
style:
left: 17%
top: 74%
width: 30%
tap_action:
action: call-service
service: script.turn_on
service_data:
entity_id: script.termite_mode
type: image
state_image:
'off': 'https://i.imgur.com/jGz3ryb.png'
'on': 'https://i.imgur.com/jGz3ryb.png'
style:
left: 50%
top: 74%
width: 30%
tap_action:
service_data:
entity_id: script.reset_termite_alert
type: image
- double_tap_action:
action: url
url_path: 'https://bit.ly/2zveqUh'
state_image:
'off': 'https://i.imgur.com/oEj7vAn.png'
'on': 'https://i.imgur.com/oEj7vAn.png'
style:
left: 83%
top: 74%
width: 30%
tap_action:
action: url
url_path: 'https://bit.ly/2SM3Z5r'
type: image
image: 'https://i.imgur.com/CNlwZC1.png'
type: picture-elements
- content: >-
### Most recent tweet ({{
as_timestamp(state_attr('automation.termite_alert_input_text_tweet_for_sensor',
'last_triggered'))|timestamp_custom("%-I:%M:%S%p - %B %-d, %Y") }}):
{{ states.input_text.termite_tweets.state }}
type: markdown
type: vertical-stack
Final Thoughts:
I’ve mentioned this project a few times before on some forums, but hadn’t decided whether to post it since it’s such a specific weird thing. Maybe it can inspire someone to tackle some other problem via Twitter crowdsourcing.
If any of these automations would be helpful to anyone as blueprints, let me know and I’ll try to set something up. I did this project in May, so some functionality of Home Assistant has changed since then, but everything still works. I tested it today.
