My version of an aquarium contoller
so i have a fluval aquasky plant communicating with ha via an esp32board.
i also have a colocast background light that i paired via local tuya. decided to build a controller. that synce the lights to each other and the sun and created biome presets. most of it works except for the storms.
automations
- id: aos_master_engine_v2026_final_sync
  alias: "🐠 Aquarium OS 2.0: Master Controller"
  description: "Unified Brain for WRGB and Background"
  mode: restart
    - platform: time_pattern
      seconds: "/5"
    - platform: state
      entity_id:
        - input_boolean.weather_sync
        - input_boolean.storm_active
    # βšͺ WHITE CHANNEL
    - action: number.set_value
        entity_id: number.fluvalble_bigtank_channel_white
        value: >
          {% if is_state('input_boolean.storm_active', 'on') %} 0
          {% elif is_state('input_boolean.weather_sync', 'on') %} {{ states('sensor.aquarium_live_white') | int(0) }}
          {% else %} 500 {% endif %}
    # πŸ”΅ BLUE CHANNEL
        entity_id: number.fluvalble_bigtank_channel_blue
        value: >
          {% elif is_state('input_boolean.weather_sync', 'on') %} {{ states('sensor.aquarium_live_blue') | int(0) }}
    # πŸ”΄ RED CHANNEL
        entity_id: number.fluvalble_bigtank_red
        value: >
          {% elif is_state('input_boolean.weather_sync', 'on') %} {{ states('sensor.aquarium_live_red') | int(0) }}
    # 🟒 GREEN CHANNEL
        entity_id: number.fluvalble_bigtank_channel_green
        value: >
          {% elif is_state('input_boolean.weather_sync', 'on') %} {{ states('sensor.aquarium_live_green') | int(0) }}
# 🌌 BACKGROUND LED SYNC
    - if:
        - condition: state
          entity_id: input_select.aquarium_atmosphere
          state: "Auto"
        # ADDED: Only sync if a storm is NOT running
        - condition: state
          entity_id: input_boolean.storm_active
          state: "off"
      then:
        - action: light.turn_on
            entity_id: light.background_led_bigtank_backlight
            rgb_color: >
              {% set r = state_attr('sensor.aquarium_atmosphere_engine', 'rgb')[0] | default(255) | int %}
              {% set g = state_attr('sensor.aquarium_atmosphere_engine', 'rgb')[1] | default(141) | int %}
              {% set b = state_attr('sensor.aquarium_atmosphere_engine', 'rgb')[2] | default(227) | int %}
              {% if r == 255 and g == 141 and b == 227 %}
                {{ [100, 200, 255] }}
              {% else %}
                {{ [r, g, b] }}
              {% endif %}
            brightness_pct: 60
- alias: "AOS: Stochastic Storm Trigger"
  description: "Syncs the Master Controller to the Storm switch with the correct entity name"
    - platform: state
    - if:
        - condition: state
          state: "on"
      then:
        - service: automation.turn_off
            entity_id: automation.aquarium_os_2_0_master_controller
      else:
        - service: automation.turn_on
- alias: "AOS: Update Storm Schedule"
  description: "Updates the dashboard timer for the next storm"
    - platform: state
      to: "off"
    - service: input_datetime.set_datetime
        entity_id: input_datetime.aquarium_next_storm
        timestamp: >
          {# Sets next storm to a random time between 6 and 24 hours from now #}
          {{ (as_timestamp(now()) + range(21600, 86400) | random) }}
- alias: "Aquarium: Master Atmosphere Controller"
  mode: restart
    - platform: state
    - repeat:
        while:
          - condition: template
            value_template: >
              {{ states('input_select.aquarium_atmosphere') != 'Auto' and
                 is_state('input_boolean.storm_active', 'off') }}
        sequence:
          - choose:
              # πŸ”₯ FIREPLACE (Faster flicker)
              - conditions:
                    value_template: "{{ 'Fireplace' in states('input_select.aquarium_atmosphere') }}"
                sequence:
                    target: {entity_id: light.background_led_bigtank_backlight}
                    data: {rgb_color: [255, 60, 0], brightness_pct: 80, transition: 1.5}
                  - delay: 1.5
                    data: {rgb_color: [180, 30, 0], brightness_pct: 35, transition: 2}
                  - delay: 2
              # πŸŒ‹ VOLCANO / VENT (Slow heavy magma pulse)
              - conditions:
                    value_template: "{{ 'Volcano' in states('input_select.aquarium_atmosphere') or 'Vent' in states('input_select.aquarium_atmosphere') }}"
                sequence:
                    data: {rgb_color: [255, 10, 0], brightness_pct: 90, transition: 5}
                  - delay: 5
                    data: {rgb_color: [80, 0, 0], brightness_pct: 15, transition: 8}
                  - delay: 8
              # 🌊 DEEP WATER
              - conditions:
                    value_template: "{{ 'Deep' in states('input_select.aquarium_atmosphere') or 'Abyss' in states('input_select.aquarium_atmosphere') or 'Bioluminesc' in states('input_select.aquarium_atmosphere') or 'Midnight' in states('input_select.aquarium_atmosphere') or 'Reef' in states('input_select.aquarium_atmosphere') }}"
                sequence:
                    data: {rgb_color: [0, 0, 150], brightness_pct: 20, transition: 8}
                  - delay: 8
                    data: {rgb_color: [20, 20, 200], brightness_pct: 45, transition: 8}
                  - delay: 8
              # 🌿 BIOME
              - conditions:
                    value_template: "{{ 'Jungle' in states('input_select.aquarium_atmosphere') or 'Forest' in states('input_select.aquarium_atmosphere') or 'Mangrove' in states('input_select.aquarium_atmosphere') or 'Mediterranean' in states('input_select.aquarium_atmosphere') }}"
                sequence:
                    data: {rgb_color: [20, 110, 20], brightness_pct: 50, transition: 8}
                  - delay: 8
                    data: {rgb_color: [90, 130, 35], brightness_pct: 30, transition: 8}
                  - delay: 8
              # β›ˆοΈ WEATHER
              - conditions:
                    value_template: "{{ 'Storm' in states('input_select.aquarium_atmosphere') or 'Thunder' in states('input_select.aquarium_atmosphere') or 'Peak' in states('input_select.aquarium_atmosphere') or 'Mist' in states('input_select.aquarium_atmosphere') or 'Arctic' in states('input_select.aquarium_atmosphere') }}"
                sequence:
                    data: {rgb_color: [255, 255, 255], brightness_pct: 100, transition: 0.1}
                  - delay: {milliseconds: 100}
                    data: {rgb_color: [30, 30, 60], brightness_pct: 10, transition: 3}
                  - delay: "{{ range(4, 15) | random }}"
              # πŸŒ… SKY
              - conditions:
                    value_template: "{{ 'Sun' in states('input_select.aquarium_atmosphere') or 'Hour' in states('input_select.aquarium_atmosphere') or 'Dew' in states('input_select.aquarium_atmosphere') or 'Chill' in states('input_select.aquarium_atmosphere') or 'Sahara' in states('input_select.aquarium_atmosphere') or 'Caribbean' in states('input_select.aquarium_atmosphere') }}"
                sequence:
                    data: {rgb_color: [255, 110, 0], brightness_pct: 65, transition: 15}
                  - delay: 15
                    data: {rgb_color: [255, 45, 0], brightness_pct: 40, transition: 15}
                  - delay: 15
              # 🎑 VIBE
              - conditions:
                    value_template: "{{ 'Tokyo' in states('input_select.aquarium_atmosphere') or 'Party' in states('input_select.aquarium_atmosphere') or 'Algae' in states('input_select.aquarium_atmosphere') or 'Movie' in states('input_select.aquarium_atmosphere') or 'Feeding' in states('input_select.aquarium_atmosphere') }}"
                sequence:
                    data: {rgb_color: [255, 0, 255], brightness_pct: 95, transition: 2}
                  - delay: 2
                    data: {rgb_color: [0, 255, 255], brightness_pct: 95, transition: 2}
                  - delay: 2
          - delay: 1```
- alias: "Aquarium: Force Thunderstorm on Switch"
  mode: single
    - platform: state
      to: "on"
    - action: input_select.select_option
        option: "Thunderstorm
heres my template
# 🧠 AQUARIUM OS 2.0 - SCIENTIFIC ENGINE
- sensor:
    # β˜€οΈ SOLAR ENGINE
    - name: "Aquarium Solar Intensity"
      unique_id: aos_solar_v2026_final
      unit_of_measurement: "pts"
      state: >
        {% set rise = today_at("06:17").timestamp() %}
        {% set sunset = today_at("19:55").timestamp() %}
        {% set now_ts = now().timestamp() %}
        {% if rise <= now_ts <= sunset %}
          {% set noon = rise + ((sunset - rise) / 2) %}
          {{ (((now_ts - rise) / (noon - rise)) * 1000) | int if now_ts <= noon else (1000 - (((now_ts - noon) / (sunset - noon)) * 1000)) | int }}
        {% else %} 0 {% endif %}
    # 🌦️ MODIFIERS
    - name: "Aquarium Environment Modifier"
      unique_id: aos_env_mod_final
      state: >
        {% set w = states('weather.kccr') %}
        {% if is_state('input_boolean.storm_active', 'on') %} 0.0
          {% if w in ['cloudy', 'partlycloudy', 'fog'] %} 0.6
          {% elif w in ['rainy', 'pouring', 'snowy'] %} 0.4
          {% else %} 1.0 {% endif %}
# πŸ§ͺ BIOME DICTIONARY (Full Library)
    - name: "Aquarium Biome Dictionary"
      unique_id: aos_biomes_v2026_final
      state: >
        {% set m = states('input_select.aquarium_mode') or states('input_select.aquarium_mode_2') %}
        {{ m | lower | trim if m not in ['unknown', 'unavailable', 'none', ''] else 'midday peak' }}
      attributes:
        # Raw Ratios: [White, Blue, Red, Green]
        channels: >
          {% set map = {
            'amazon basin': [1.0, 0.4, 0.2, 0.1],
            'blackwater': [0.2, 0.2, 0.8, 0.0],
            'lake malawi': [1.0, 0.9, 0.1, 0.0],
            'tanganyika rock': [0.9, 1.0, 0.0, 0.0],
            'indo-pacific reef': [0.4, 1.0, 0.1, 0.0],
            'australian river': [0.8, 0.5, 0.4, 0.2],
            'mangrove swamp': [0.6, 0.5, 0.5, 0.2],
            'peat swamp': [0.1, 0.2, 0.7, 0.5],
            'coldwater stream': [0.7, 0.9, 0.1, 0.0],
            'brackish estuary': [0.6, 0.6, 0.3, 0.1],
            'plant growth': [0.5, 0.4, 1.0, 0.2],
            'high tech': [1.0, 0.8, 0.9, 0.5],
            'low tech': [0.5, 0.4, 0.3, 0.1],
            'algae scrubber': [0.0, 0.1, 1.0, 0.0],
            'breeding': [0.3, 0.3, 0.2, 0.1],
            'fry growout': [0.7, 0.6, 0.4, 0.2],
            'quarantine': [0.4, 0.2, 0.1, 0.0],
            'midday peak': [1.0, 1.0, 1.0, 1.0],
            'golden hour': [0.6, 0.1, 1.0, 0.0],
            'deep blue': [0.0, 1.0, 0.0, 0.0],
            'moonlight only': [0.0, 0.3, 0.0, 0.0],
            'stormy sky': [0.3, 0.3, 0.4, 0.1],
            'cloudy day': [0.5, 0.5, 0.5, 0.2]
          {{ map.get(this.state, [1.0, 1.0, 1.0, 1.0]) }}
        description: >
          {% set desc = {
            'amazon basin': 'Dense jungle canopy; warm, high-intensity white.',
            'blackwater': 'Tannin-stained; dim, tea-colored tint with low white.',
            'lake malawi': 'Rift Valley clarity; crisp, high-alkalinity bright white.',
            'tanganyika rock': 'Deep water rock shelf; cool-spectrum white.',
            'indo-pacific reef': 'Oceanic depth; actinic blue/white blend.',
            'australian river': 'Clear outback waters; balanced midday brightness.',
            'mangrove swamp': 'Intertidal zone; morning and evening bias.',
            'peat swamp': 'Dim swamp floor; extra dim with red/green bias.',
            'coldwater stream': 'Mountain runoff; low intensity cool white.',
            'brackish estuary': 'Coastal mix; cloudy/natural spectral shift.',
            'plant growth': 'Photosynthetic peak; pink/red heavy spectrum.',
            'high tech': 'CO2 optimization; maximum PAR output.',
            'low tech': 'Algae prevention; gentle lighting for slow growth.',
            'algae scrubber': 'Refugium growth; targeted red spectrum.',
            'breeding': 'Low stress; soft, non-stressful lighting.',
            'fry growout': 'Development mode; extended daylight hours.',
            'quarantine': 'Recovery mode; dim, antiseptic lighting.',
            'midday peak': 'Solar noon; 100% burst for 1 hour.',
            'golden hour': 'Sunset transition; warm orange glow.',
            'deep blue': 'Nighttime actinic; heavy blue spectrum.',
            'moonlight only': 'Lunar simulation; blue channel at 2-5%.',
            'stormy sky': 'Low pressure simulation; dim with random flicker.',
            'cloudy day': 'Overcast simulation; neutral grey/dim white.'
          {{ desc.get(this.state, 'Standard spectrum for selected biome.') }}
        target_values: >
          {% set c = this.attributes.channels %}
          W: {{ (c[0]*100)|int }}% | B: {{ (c[1]*100)|int }}% | R: {{ (c[2]*100)|int }}% | G: {{ (c[3]*100)|int }}%
# 🎨 ATMOSPHERE ENGINE (The Complete 30)
    - name: "Aquarium Atmosphere Engine"
      unique_id: aquarium_master_atmosphere_engine
      state: >
        {% set a = states('input_select.aquarium_atmosphere') %}
        {{ a | lower | trim if a not in ['unknown', 'unavailable', 'none', ''] else 'auto' }}
      attributes:
        description: >
          {% set desc = {
            'auto': 'System-managed lighting based on solar/lunar cycle.',
            'manual': 'Static neutral white; all animations paused.',
            'feeding time': 'High-visibility white for inspection/feeding.',
            'movie mode': 'Deep dimming to reduce room glare.',
            'amazon jungle': 'Dense canopy greens; slow organic breathing.',
            'boreal forest': 'Cooler pine greens with filtered sunlight.',
            'mangrove': 'Coastal root-zone teal and earthy greens.',
            'mediterranean': 'Bright coastal turquoise and high-intensity white.',
            'deep sea': 'Abyssal blue; slow, heavy depth pressure pulse.',
            'abyss': 'Near-total darkness with faint deep-blue shimmer.',
            'bioluminescent': 'Neon teal and electric blue pulses.',
            'midnight': 'Moonless night; minimal visibility.',
            'reef blue': 'Actinic blue spectrum for coral/color pop.',
            'thunderstorm': 'Dark blue-grey with erratic white lightning.',
            'stormy peak': 'High-altitude grey with rapid flicker.',
            'highland mist': 'Soft, foggy white with low-contrast shifts.',
            'arctic': 'Freezing pale blue and white shimmer.',
            'sunrise': 'Early morning pink and soft orange transition.',
            'golden hour': 'Deep sunset orange; heavy warm saturation.',
            'morning dew': 'Crisp, cool-toned morning light.',
            'evening chill': 'Deepening purple and blue twilight.',
            'sahara': 'High-heat desert yellow and harsh orange.',
            'caribbean': 'Shallow water cyan and vibrant turquoise.',
            'mangrove sunset': 'Deep fiery orange hitting coastal greens.',
            'volcano': 'Heavy magma pulse; deep red to cooling embers.',
            'volcanic vent': 'Intense localized red heat pulse.',
            'fireplace': 'Cozy hearth flicker; warm orange and red jumps.',
            'neon tokyo': 'Vibrant synthwave pulse; pink and cyan shift.',
            'party': 'High-energy cycle through the full RGB spectrum.',
            'algae scrubber': 'Pure growth spectrum; specialized heavy red.'
          {{ desc.get(this.state, 'Dynamic lighting effect active.') }}
        target_rgb: >
          {% set map = {
            'amazon jungle': [20, 110, 20], 'boreal forest': [30, 80, 30], 'mangrove': [40, 120, 50],
            'mediterranean': [200, 255, 255], 'deep sea': [0, 0, 150], 'abyss': [10, 10, 80],
            'bioluminescent': [0, 255, 150], 'midnight': [5, 5, 40], 'reef blue': [0, 100, 255],
            'thunderstorm': [30, 30, 60], 'stormy peak': [50, 50, 80], 'highland mist': [150, 150, 180],
            'arctic': [200, 220, 255], 'sunrise': [255, 100, 50], 'golden hour': [255, 120, 0],
            'morning dew': [180, 200, 150], 'evening chill': [100, 100, 150], 'sahara': [255, 180, 50],
            'caribbean': [0, 200, 200], 'mangrove sunset': [255, 80, 30], 'volcano': [255, 10, 0],
            'volcanic vent': [180, 20, 0], 'fireplace': [255, 60, 0], 'neon tokyo': [255, 0, 255],
            'party': [200, 0, 200], 'algae scrubber': [0, 255, 0], 'feeding time': [255, 255, 255],
            'movie mode': [20, 20, 20], 'manual': [255, 255, 255], 'auto': [150, 150, 150]
          {{ map.get(this.state, [255, 255, 255]) }}
    # πŸ“Š LIVE CHANNELS
    - name: "Aquarium Live White"
      state: >
        {% set solar = states('sensor.aquarium_solar_intensity') | float(0) %}
        {% set env = states('sensor.aquarium_environment_modifier') | float(1.0) %}
        {% set multi = state_attr('sensor.aquarium_biome_dictionary', 'channels')[0] | float(1.0) %}
        {{ (solar * env * multi) | int }}
    - name: "Aquarium Live Blue"
      state: >
        {% set multi = state_attr('sensor.aquarium_biome_dictionary', 'channels')[1] | float(1.0) %}
    - name: "Aquarium Live Red"
      state: >
        {% set multi = state_attr('sensor.aquarium_biome_dictionary', 'channels')[2] | float(1.0) %}
    - name: "Aquarium Live Green"
      state: >
        {% set multi = state_attr('sensor.aquarium_biome_dictionary', 'channels')[3] | float(1.0) %}
    # πŸŒ• LUNAR ENGINE
    - name: "Aquarium Lunar Intensity"
      unique_id: aos_lunar_v2026_final
      state: >
        {% set moon_rise = today_at("19:55").timestamp() %}
        {% if now().timestamp() >= moon_rise %} 100 {% else %} 0 {% endif %}
    # β›ˆοΈ STORM ENGINE
    - name: "Aquarium Storm Active"
      unique_id: aos_storm_active_final
      state: "{{ is_state('input_boolean.storm_active', 'on') }}"
    - name: "Aquarium Storm Probability"
      unique_id: aos_storm_prob_final
      unit_of_measurement: "%"
      state: >
        {% if is_state('input_boolean.aquarium_random_storms', 'on') %} {{ range(1, 101) | random }}
    # 🌌 BACKGROUND SPECTRAL SYNC
    - name: "AOS Background Spectral Sync"
      unique_id: aos_bg_color_sync_v2
      state: >
        {% if states('sensor.aquarium_solar_intensity') | int(0) > 0 %} Day {% else %} Night {% endif %}
      attributes:
        rgb_color: >
          {% set r = (states('sensor.aquarium_live_red') | int(0) * 0.255) | round(0) %}
          {% set g = (states('sensor.aquarium_live_green') | int(0) * 0.255) | round(0) %}
          {% set b = (states('sensor.aquarium_live_blue') | int(0) * 0.255) | round(0) %}
          {{ [r, g, b] }}
    - name: "55g Tank Temperature"
      unique_id: aquarium_55g_temp_sensor
      unit_of_measurement: "Β°F"
      device_class: temperature
      state: "{{ states('input_number.55g_tamp') | float(77) }}"
here are my helpers
# 🌦️ Master Overrides
weather_sync:
  name: "☁️ Global Weather Sync (KCCR)"
  icon: mdi:weather-partly-cloudy
random_storms:
  name: "⚑ Enable Stochastic Thunderstorms"
  icon: mdi:flash
# πŸ” Maintenance toggles
feeding_mode_55g:
  name: "πŸ” 55g Feeding Mode (Kills Filters for 15m)"
  icon: mdi:fish
# πŸ§ͺ Hardware Toggles
uv_sterilizers_55g:
  name: "🦠 55g UV Sterilizers Override"
  icon: mdi:lightbulb-fluorescent-tube
storm_active:
  name: "Aquarium Storm Active Toggle"
  icon: mdi:weather-lightning```
selects
# 🌍 BUS A: The 55g Fluval Biological Spectrum
aquarium_mode:
  name: "🌍 55g Biological Biome"
  icon: mdi:earth
  options:
    - "Amazon Basin"
    - "Blackwater"
    - "Lake Malawi"
    - "Tanganyika Rock"
    - "Indo-Pacific Reef"
    - "Australian River"
    - "Mangrove Swamp"
    - "Peat Swamp"
    - "Coldwater Stream"
    - "Brackish Estuary"
    - "Plant Growth"
    - "High Tech"
    - "Low Tech"
    - "Algae Scrubber"
    - "Breeding"
    - "Fry Growout"
    - "Quarantine"
    - "Midday Peak"
    - "Golden Hour"
    - "Deep Blue"
    - "Moonlight Only"
    - "Stormy Sky"
    - "Cloudy Day"
# 🎭 BUS B: The Background Atmosphere Strip
aquarium_atmosphere:
  name: "🎭 55g Background Atmosphere"
  icon: mdi:led-strip
  options:
    - "Auto"
    - "Manual"
    - "Feeding Time"
    - "Movie Mode"
    - "Amazon Jungle"
    - "Boreal Forest"
    - "Mangrove"
    - "Mediterranean"
    - "Deep Sea"
    - "Abyss"
    - "Bioluminescent"
    - "Midnight"
    - "Reef Blue"
    - "Thunderstorm"
    - "Stormy Peak"
    - "Highland Mist"
    - "Arctic"
    - "Sunrise"
    - "Golden Hour"
    - "Morning Dew"
    - "Evening Chill"
    - "Sahara"
    - "Caribbean"
    - "Mangrove Sunset"
    - "Volcano"
    - "Volcanic Vent"
    - "Fireplace"
    - "Neon Tokyo"
    - "Party"
    - "Algae Scrubber"
ran out of characters i can have in a post heres my dashboard
heres my dashboard
  - type: sections
    max_columns: 3
    title: fish
    path: fish
    sections:
      - type: grid
        cards:
          - type: custom:bubble-card
            card_type: select
            entity: input_select.aquarium_mode
            sub_button:
              main: []
              bottom: []
            show_state: true
            show_last_updated: true
          - type: markdown
            content: >
              ### 🌍 Current Biome: {{
              states('sensor.aquarium_biome_dictionary') | title }}
              **Description:** {{ state_attr('sensor.aquarium_biome_dictionary',
              'description') }}
              **Target Spectrum:** `{{
              state_attr('sensor.aquarium_biome_dictionary', 'target_values')
            title: Biome Details
            card_type: select
            entity: input_select.aquarium_atmosphere
            sub_button:
              main: []
              bottom: []
            show_state: true
            show_last_changed: true
            card_type: button
            entity: input_boolean.storm_active
            button_type: switch
            sub_button:
              main: []
              bottom: []
            show_state: true
            card_type: button
            entity: switch.platytank
            name: Platy Tank Light
            button_type: switch
            sub_button:
              main: []
              bottom: []
            show_state: true
          - type: entities
            title: ⚑🧩 ESPHome Hardware Direct
            show_header_toggle: false
            entities:
              - entity: number.fluvalble_bigtank_channel_white
                name: βšͺ Force White
                icon: mdi:circle-outline
              - entity: number.fluvalble_bigtank_channel_blue
                name: πŸ”΅ Force Blue
              - entity: number.fluvalble_bigtank_red
                name: πŸ”΄ Force Red
              - entity: number.fluvalble_bigtank_channel_green
                name: 🟒 Force Green
              - entity: light.background_led_bigtank_backlight
                name: 🌌 Background LED
                icon: mdi:led-strip-variant
            state_color: true
            card_mod:
              style: >
                ha-card {
                  border-radius: 22px;
                  padding: 10px 10px 12px;
                  background: linear-gradient(135deg, rgba(0,140,255,0.18), rgba(0,255,200,0.10));
                  border: 1px solid rgba(255,255,255,0.08);
                  box-shadow: 0 12px 32px rgba(0,0,0,0.40);
                  backdrop-filter: blur(10px);
                .card-header {
                  font-size: 18px;
                  font-weight: 800;
                  letter-spacing: 0.2px;
                /* Row styling to look like β€œmodules” */
                #states > div {
                  border-radius: 14px;
                  margin: 6px 0;
                  padding: 6px 8px;
                  background: rgba(10, 18, 30, 0.35);
                  border: 1px solid rgba(255,255,255,0.05);
                /* Subtle icon glow */
                state-badge { filter: drop-shadow(0 4px 10px rgba(0,0,0,0.45));
          - type: entities
            title: β›ˆοΈ Storm Engine Control
            entities:
              - entity: input_boolean.random_storms
                name: 🌩️ Random Storms (Master)
                icon: mdi:weather-lightning-rainy
              - entity: input_boolean.aquarium_random_storms
                name: 🐠 Tank Storms (Local)
                icon: mdi:fishbowl
              - entity: input_number.storm_frequency
                name: πŸŒͺ️ Storm Frequency / Intensity
                icon: mdi:weather-windy
              - entity: input_datetime.next_scheduled_storm
                name: πŸ—“οΈ Next Scheduled Storm
                icon: mdi:calendar-clock
              - entity: sensor.aquarium_storm_active
                name: 🚨 Storm Active
                icon: mdi:alert-decagram
              - entity: sensor.aquarium_storm_probability
                name: 🎲 Storm Probability
                icon: mdi:percent
              - entity: sensor.aquarium_storm_intensity
              - entity: input_boolean.storm_active
            card_mod:
              style: |
                ha-card {
                  background: linear-gradient(135deg, rgba(0,140,255,0.18), rgba(120,0,255,0.10));
                #states > div {
                  margin: 6px 0;
                  padding: 6px 8px;
          - type: tile
            entity: switch.aquarium_ai_55gallon_55gallon_analyze_camera
          - type: tile
            entity: switch.aquarium_ai_55gallon_55gallon_analyze_overall_health
          - type: tile
            entity: switch.aquarium_ai_55gallon_55gallon_analyze_temperature
          - type: tile
            entity: switch.aquarium_ai_55gallon_55gallon_analyze_water_change
          - type: tile
            entity: switch.aquarium_ai_55gallon_55gallon_auto_send_notifications
          - type: tile
            entity: sensor.aquarium_ai_55gallon_55gallon_camera_analysis
          - type: tile
            entity: select.aquarium_ai_55gallon_55gallon_notification_format
          - type: tile
            entity: sensor.aquarium_ai_55gallon_55gallon_overall_analysis
          - type: tile
            entity: sensor.aquarium_ai_55gallon_55gallon_quick_status
          - type: tile
            entity: button.aquarium_ai_55gallon_55gallon_run_analysis
          - type: tile
            entity: switch.aquarium_ai_55gallon_55gallon_run_analysis_on_startup
          - type: tile
            entity: sensor.aquarium_ai_55gallon_55gallon_simple_status
          - type: tile
            entity: sensor.aquarium_ai_55gallon_55gallon_status_emoji
          - type: tile
            entity: sensor.aquarium_ai_55gallon_55gallon_temperature_analysis
          - type: tile
            entity: sensor.aquarium_ai_55gallon_55gallon_temperature_status
          - type: tile
            entity: binary_sensor.aquarium_ai_55gallon_55gallon_water_change_needed
          - type: tile
            entity: sensor.aquarium_ai_55gallon_55gallon_water_change_recommendation
          - type: entities
            entities:
              - entity: sensor.aquarium_biome_dictionary
              - type: attribute
                attribute: description
                name: About this Biome
              - type: attribute
                attribute: target_values
      - type: grid
        cards:
          - type: heading
            heading: β˜€οΈ Solar Output
          - type: custom:mini-graph-card
            entities:
              - entity: sensor.aquarium_solar_intensity
                name: Solar Intensity
                color: '#FFFF00'
              - entity: sensor.aquarium_live_white
              - entity: sensor.aquarium_live_blue
              - entity: sensor.aquarium_live_red
              - entity: sensor.aquarium_live_green
                color: '#228B22'
            hours_to_show: 48
            show:
              fill: fade
              legend: true
          - type: heading
            heading: πŸŒ™ Lunar Output
            entities:
              - entity: sensor.aquarium_lunar_intensity
                name: Lunar Intensity
                color: '#FFFF00'
            hours_to_show: 12
            show:
              fill: fade
              legend: true
          - type: custom:horizon-card
            moon: true
            fields:
              sunrise: true
              sunset: true
              moon_phase: true
          - type: custom:advanced-camera-card
            cameras:
              - camera_entity: camera.fishcam
          - type: history-graph
            title: 🌌 Background Light 24h Logic
            hours_to_show: 24
            entities:
                name: Solar Intensity (Target)
                name: Bkg Brightness
              - entity: input_select.aquarium_atmosphere
    badges:
      - type: entity
        entity: weather.kccr
this is all a work in progress and i used AI heavily to help write the code.
