My very first automation fails, what is wrong with it?
Trying to create my very first automation, but it fails and fails and fails, what is wrong with it? :slight_smile:
Took automation from here: https://www.hackster.io/robin-cole/pi-camera-doorbell-with-notifications-408d3d
Automation is added to automation.yaml, there is nothing more than below.
automation: !include automations.yaml is on configuration.yaml
  - alias: Doorbell_pressed_automation
     platform: mqtt
     topic: dev/test
     payload: 'Capture!'
     - service: automation.turn_off
       entity_id: automation.doorbell_pressed_automation
     - service: script.turn_on
       entity_id: script.doorbell_pressed_script
     - delay: "00:00:5"
     - service: automation.turn_on
Config check:
Configuration invalid
Testing configuration at /config
2018-01-31 22:18:43 ERROR (SyncWorker_0) [homeassistant.util.yaml] while parsing a block collection in “/config/automations.yaml”, line 1, column 3 expected , but found ‘’ in “/config/automations.yaml”, line 2, column 4
2018-01-31 22:18:43 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while parsing a block collection in “/config/automations.yaml”, line 1, column 3 expected , but found ‘’ in “/config/automations.yaml”, line 2, column 4
From Hass info:
while parsing a block collection in “/config/automations.yaml”, line 1, column 2 expected , but found ‘’ in “/config/automations.yaml”, line 9, column 3
9:56 PM helpers/entity_component.py (ERROR)
9:56 PM util/yaml.py (ERROR)
9:55 PM helpers/entity_component.py (ERROR)
9:55 PM util/yaml.py (ERROR)
try like this:
      platform: mqtt
      topic: dev/test
      payload: 'Capture!'
      - service: homeassistant.turn_off
      - service: script.doorbell_pressed_script
      - delay: "00:00:05"
      - service: homeassistant.turn_on
besides the first line every other was missing a space, hopefully now it’s working.
You can also use automation.turn_on or script.turn_on, usually I just use homeassistant.turn_ because it can be used with every entity and for scripts I don’t use any I just put the script entity at the service and its been working flawless.
indentation is exceptionally important in yaml.
if it is wrong then you will get errors and hass web interface won’t load.
Awesome, thank you! That was it :slight_smile:
Yes, I´ve really noticed that :smiley:
Found this one and it hopefully saves my lifes sometimes in the future :slight_smile: http://www.yamllint.com/
Also need to try some tweaks for Notepad++ as I didn´t saw my initial flaw with it.
Try Visual Studio Code.
