Weather Dashboard - Dwains Dashboard Add-on (more_page)
Weather Dashboard in Home Assistant Dwains Dashboard.
Created by Léon van der Linden
Prerequisite
- Make sure you have installed the lovelace mini-graph-card, fontawesome icons, Button Card and the integration Neerslag app. This can be done manually or directly via hacs
Make Home Assistant integration
Please reboot Home Assistant after config the sensors!
Buienradar sensor + Radar map
- Make the integration with Buienradar
- Choose
latitudeandlongtiudefrom the correct weather station
# Example configuration.yaml entry
- platform: buienradar
# Force 'Meetstation Apeldoorn' to be used:
latitude: 50.00
longitude: 5.00
monitored_conditions:
- stationname
- barometerfc
- barometerfcname
- conditioncode
- condition
- conditiondetailed
- conditionexact
- symbol
- feeltemperature
- humidity
- temperature
- groundtemperature
- windspeed
- windforce
- winddirection
- windazimuth
- pressure
- visibility
- windgust
- precipitation
- irradiance
- precipitation_forecast_average
- precipitation_forecast_total
- rainlast24hour
- rainlasthour
# conditions for forecasted data:
- symbol_1d
- symbol_2d
- symbol_3d
- symbol_4d
- symbol_5d
- temperature_1d
- temperature_2d
- temperature_3d
- temperature_4d
- temperature_5d
- mintemp_1d
- rainchance_1d
- rainchance_2d
- sunchance_1d
- sunchance_2d
- rain_1d
- rain_2d
- minrain_1d
- maxrain_1d
- windforce_1d
- windforce_2d
- windspeed_1d
- windspeed_2d
- winddirection_1d
- winddirection_2d
- windazimuth_1d
- windazimuth_2d
camera:
Ambee Pollen sensoren
- Make the integration with Ambee Pollen
- Make sure you have reboot Home Assistant after that you have made the sensors!
### Ambee Pollen
# Must be added in sensor.yml
# replace LAT, LONG and API-KEY with your values
- platform: rest
scan_interval: 3600
resource: https://api.ambeedata.com/latest/pollen/by-lat-lng?lat=LAT&lng=LONG
headers:
content-type: "application/json"
x-api-key: "YOUR-API-KEY"
json_attributes_path: "$.data.['Risk']"
json_attributes:
- tree_pollen
- grass_pollen
- weed_pollen
sensors:
ambee_pollen_tree:
icon_template: "mdi:tree-outline"
friendly_name: "tree"
value_template: >-
{% set state = state_attr('sensor.ambee_pollen', 'tree_pollen') %}
{% if state == "Low" %}Low
{% elif state == "Moderate"%}Moderate
{% elif state == "High"%}High
{% elif state == "Very High"%}Very High
{% else %}Unbekannt{% endif %}
sensors:
ambee_pollen_weed:
icon_template: "mdi:nature"
friendly_name: "weed"
value_template: >-
{% set state = state_attr('sensor.ambee_pollen', 'weed_pollen') %}
sensors:
ambee_pollen_grass:
icon_template: "mdi:grass"
friendly_name: "grass"
value_template: >-
{% set state = state_attr('sensor.ambee_pollen', 'grass_pollen') %}
KMNI sensor
- Make the integration with KNMI
- platform: scrape
resource: https://www.knmi.nl/nederland-nu/weer/waarschuwingen/gelderland #change provincie
select: "div.alert__heading"
name: "knmi weercode"
scan_interval: 300
- platform: scrape
select: "a.alert__description"
name: "knmi weer waarschuwing"
scan_interval: 300
Moon sensor
- Make the integration with Moon
- platform: moon
Season sensor
- Make the integration with Season
- platform: season
Sun integration
- Make the integration with Sun
sun:
Installation Add-on (only for users of Dwains Dashboard)
- Copy the
weatherfolder in to thedwains-dashboard/addons/more_pagedirectory. - Open your
more_page.yamlfile indwains-dashboard/configsand add the following;
- name: Weather
main_menu: 'true' #Show this addon in the main navigation bar!
icon: fas:cloud-sun-rain
path: 'dwains-dashboard/addons/more_page/weather/page.yaml'
- Reload the theme configuration via Theme Settings
Replace the following
- If some
sensorsnot showing after this manual, please add the correctsensorto monitor - The dashboard will refresh every 10 minutes. When you want to skip this, delete the code between line 66 till 69
- cards:
Refresh: null
type: 'custom:auto-reload-card'
delay_in_minute: 10
Result
Enjoy my card? Help me out for a couple of
or a
