I enabled SSL by importing the keys and adding them to the configuration.yaml. Then I decided to disable it (for reasons I won’t get into). Now that I’ve reverted the configuration, my integrations throw a 401 error (401: Unauthorized). The system works fine via non-SSL and I can also ssh in, but the window-based add-ons including Visual Studio don’t work (401). I rebooted the hardware, reinstalled the integrations, but I am stuck. I believe that somewhere some component is remembering that it likes SSL. There is no mention of https or keys in my configuration.yaml now. The visual studio log clearly says “Not serving HTTPS”. I do see an error in my logs as follows:
Source: components/hassio/handler.py:467
Integration: Home Assistant Supervisor
Last logged: 9:46:33 AM
/ingress/validate_session return code 401
Anybody?
/root/ssl exists, but is empty.
OS Version: Home Assistant OS 9.5
Home Assistant Core: 2023.1.7
