hi,
seems that I have a interesting problem with my external connecteed Z-wave stick (Aeotec DSA02203 Z-Stick S2) it have work without any problem until supervisor 244 and 0.113.3 and 0.114.3 also tried switching from docker to virtual machine with the same results.
seems that home assistants looses the Z-wave stick and if i restart ha everything is fine until next time. I can’t see anything in the logs regarding this and the time frame is different everytime, I restarted HA yesterday at 2100 and this morning 04:00 it seems that it stoped working again.
In HA logs I can’t see anything and the Z-wave logs don’t much use ether
2020-09-17 04:48:55.719 Info, Node051, Received SensorMultiLevel report from node 51, instance 1, Power: value=0.4W
2020-09-17 04:48:55.719 Detail, Node051, Refreshed Value: old value=0.3, new value=0.4, type=decimal
2020-09-17 04:48:55.720 Detail, Node051, Changes to this value are not verified
2020-09-17 04:48:55.720 Detail, Node051, Notification: ValueChanged
2020-09-17 04:49:39.496 Detail, Node007, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 2 (poll queue has 0 messages)
2020-09-17 04:49:39.497 Detail, Node007, Queuing (Poll) MultiChannel Encapsulated (instance=2): SwitchBinaryCmd_Get (Node=7): 0x01, 0x0d, 0x00, 0x13, 0x07, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x89, 0x05
2020-09-17 04:49:39.497 Info, Node007, Sending (Poll) message (Callback ID=0x89, Expected Reply=0x04) - MultiChannel Encapsulated (instance=2): SwitchBinaryCmd_Get (Node=7): 0x01, 0x0d, 0x00, 0x13, 0x07, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x89, 0x05
2020-09-17 04:49:40.497 Error, Node007, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-17 04:49:40.498 Detail, Node007, Removing current message
2020-09-17 04:49:40.498 Detail, Node007, Notification: Notification - TimeOut
2020-09-17 04:50:40.501 Detail, Node007, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 3 (poll queue has 0 messages)
2020-09-17 04:50:40.501 Detail, Node007, Queuing (Poll) MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Get (Node=
I’m still running the old Z-wave integration do you think it will be stabile with the new beta OpenZwave?
