MyDlink Switch DSPW215 Power Measurements
Hello, do you think the power consumption values from the custom_ui_state_card for my switch dlink is trustable? I haven’t found anything about sensor integartion of DSPW215 in HA. Since i connected the switch to home assistant my dsp w215 is unreachable from the android app and i can not compare them.
Hi how did you integrated dlink to your homeassistant? Thank you
username and password are on the backside of the module
I use one of them for my washing machine, if it is below 1Wh for 5 minutes it fires an automation that gives a notification that the washing machine is done. It is pretty accurate if you ask me.
The user name of the app but of the device. Ok thank you
device, it’s also on the box
"Config.yaml
switch:
platform: dlink
host: 192.168.1.25
username: admin
password: 7654678
I tried to put user and password but the smart plug is not available
Hi there.
Can you please let me known how I should get 2 D-Link DCP-W118 (similar to DCP-W215 I think) integrated in Home Assistant ?
I use this in the homeassistant/config/configuration.yaml :
  • platform: dlink
    name: “D-Link DSP-W118-b9b5”
    host: 192.168.0.177
    username: admin
    password: 123456
  • platform: dlink
    name: “D-Link DSP-W118-9f59”
    host: 192.168.0.112
    username: admin
    password: 123456
thx for your reply
hello,
how did you displayed the power consuption as a secondary info label under the switch button?
it is not available for me (HA latest w d link W215)
many thanks!
Home Assistant stopped with the power usage support of the D-Link integration unfortunatly.
The D-Link app on my phone does show the power usage, so I am searching for a solution to get it back in Home Assistant.
Please tell if you found anything. I used to use this 2 years ago, it was a surprise to me, that it has been bricked by Hass.
