I am using Curl command in shell script to access MyFox directly from HA. I do not need an expensive Tahoma box. I can get the status of the alarm even when changed directly from the Android App (by trapping Emails send from MyFox), send command to MyFox to change the alarm level but also to Open/Close shutters for instance… You have to create a development account on Somfy site to access the API… A token (to be refreshed regularly) is required to send commands.
