MyGasChevrolet: Monitor the fuel level of your gas Chevrolet vehicle
With the upgrade of the mychevy package to 2.1, it is now possible to retrieve information about gas vehicles, along with EV vehicles. I’ve created a custom component to create these sensors (and by create, I mean I took the mychevy system integration and perverted it for my uses.)
It can be installed manually, or by adding a custom repository to HACS:
HACS
Under Custom Repositories, add https://github.com/dennyreiter/hass-mygaschevy as an integration. Then install.
Configuration
Add the following code in your configuration.yaml file:
mygaschevy:
    username: YOUR_USERNAME
    password: YOUR_PASSWORD
Configuration
key required type usage
username true string The email address for the MyChevrolet account
password true string The password for the MyChevrolet account
Just like the My Chevrolet integration, it can take two to three minutes for the results to be returned.
The created sensors will be in the form of sensor.mygaschevy_VEHICLE_NAME.*
sensor description
sensor.mygaschevy_VEHICLE_NAME_fuel_economy miles per gallon per vehicle
sensor.mygaschevy_VEHICLE_NAME_fuel_percentage percentage of fuel left in the tank
sensor.mygaschevy_VEHICLE_NAME_gas_range approximate range in miles per vehicle
sensor.mygaschevy_VEHICLE_NAME_mileage the vehicle mileage
This is amazing! Thanks @dennyreiter. \w/
No rush, heads up I raised a request on the repo to sync fork.
