I’m brand new to Home Assistant and need a little hint. I have a mygekko “smarthome” - its very not smart… but I can only control the temperature and shutters over it. the have an api you get the infos like that:
"name": "HAR",
"sumstate": {
"value": "State[-2=Hold_down|-1=Down|0=Stop|1=Up|2=Hold_up];Position[%];Angle[°];SumState[0=Ok|1=ManualOff|2=ManualOn|3=Locked|4=Alarm];SlatRotationArea[°]",
"type": "STRING",
"permission": "READ",
"index": 200100
"scmd": {
"value": "-2|-1|0|1|2|T|P55.4|S32.4 (Hold_down|Down|Stop|Up|Hold_up|Toggle|Position|Angle)",
"type": "STRING",
"permission": "WRITE",
"index": 200101
but you only can shut the shutter down with http get like
GET:http://IP-ADRESS/api/v1/var/blinds/item2/scmd/set?value=-1&username=admin&password=PASSWORD
or you can say that it shut down to 77 % with
GET:http://IP-ADRESS/api/v1/var/blinds/item2/scmd/set?value=P77&username=admin&password=PASSWORD
do you have an hint how I can integrate it in ha ? especially the with a http request where you have a slider convert it to a dynamic url.
