I decided to upgrade via fresh install today. I’m running Home Assistant 0.106.6. I’ve configured the myQ component (I have a garage door opener connected to the myQ cloud on wifi - no hub) as shown in the documentation:
cover:
- platform: myq
username: "<my_email_address>@gmail.com"
password: "<my_password>"
However, this isn’t working. There aren’t any errors in the log. In fact, in the logs, it doesn’t even look like Home Assistant is attempting to load the component:
➜ config ha core logs
2020-03-14 01:02:31 INFO (SyncWorker_6) [homeassistant.loader] Loaded garmin_connect from homeassistant.components.garmin_connect
2020-03-14 01:02:31 INFO (SyncWorker_1) [homeassistant.loader] Loaded neato from homeassistant.components.neato
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded local_ip from homeassistant.components.local_ip
2020-03-14 01:02:31 INFO (SyncWorker_0) [homeassistant.loader] Loaded withings from homeassistant.components.withings
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded cast from homeassistant.components.cast
2020-03-14 01:02:31 INFO (SyncWorker_1) [homeassistant.loader] Loaded ecobee from homeassistant.components.ecobee
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded geofency from homeassistant.components.geofency
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded meteo_france from homeassistant.components.meteo_france
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded izone from homeassistant.components.izone
2020-03-14 01:02:31 INFO (SyncWorker_6) [homeassistant.loader] Loaded gios from homeassistant.components.gios
2020-03-14 01:02:31 INFO (SyncWorker_0) [homeassistant.loader] Loaded homematicip_cloud from homeassistant.components.homematicip_cloud
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded minecraft_server from homeassistant.components.minecraft_server
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded traccar from homeassistant.components.traccar
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded ifttt from homeassistant.components.ifttt
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded gdacs from homeassistant.components.gdacs
2020-03-14 01:02:31 INFO (SyncWorker_3) [homeassistant.loader] Loaded icloud from homeassistant.components.icloud
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded konnected from homeassistant.components.konnected
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded melcloud from homeassistant.components.melcloud
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded iaqualink from homeassistant.components.iaqualink
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded plex from homeassistant.components.plex
2020-03-14 01:02:31 INFO (SyncWorker_1) [homeassistant.loader] Loaded sentry from homeassistant.components.sentry
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded tradfri from homeassistant.components.tradfri
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded wled from homeassistant.components.wled
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded huawei_lte from homeassistant.components.huawei_lte
2020-03-14 01:02:31 INFO (SyncWorker_1) [homeassistant.loader] Loaded opentherm_gw from homeassistant.components.opentherm_gw
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded esphome from homeassistant.components.esphome
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded vizio from homeassistant.components.vizio
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded geonetnz_volcano from homeassistant.components.geonetnz_volcano
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded elgato from homeassistant.components.elgato
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded heos from homeassistant.components.heos
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded linky from homeassistant.components.linky
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded samsungtv from homeassistant.components.samsungtv
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded transmission from homeassistant.components.transmission
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded mikrotik from homeassistant.components.mikrotik
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded solaredge from homeassistant.components.solaredge
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded solarlog from homeassistant.components.solarlog
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded tesla from homeassistant.components.tesla
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded locative from homeassistant.components.locative
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded smartthings from homeassistant.components.smartthings
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded starline from homeassistant.components.starline
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded plaato from homeassistant.components.plaato
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded somfy from homeassistant.components.somfy
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded upnp from homeassistant.components.upnp
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded axis from homeassistant.components.axis
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded zha from homeassistant.components.zha
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded iqvia from homeassistant.components.iqvia
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded twilio from homeassistant.components.twilio
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded owntracks from homeassistant.components.owntracks
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded simplisafe from homeassistant.components.simplisafe
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded smhi from homeassistant.components.smhi
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded daikin from homeassistant.components.daikin
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded unifi from homeassistant.components.unifi
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded deconz from homeassistant.components.deconz
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded brother from homeassistant.components.brother
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded tplink from homeassistant.components.tplink
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded netatmo from homeassistant.components.netatmo
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded almond from homeassistant.components.almond
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded point from homeassistant.components.point
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded tellduslive from homeassistant.components.tellduslive
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded coolmaster from homeassistant.components.coolmaster
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded vilfo from homeassistant.components.vilfo
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded wemo from homeassistant.components.wemo
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded openuv from homeassistant.components.openuv
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded toon from homeassistant.components.toon
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded ring from homeassistant.components.ring
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded airly from homeassistant.components.airly
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded twentemilieu from homeassistant.components.twentemilieu
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded cert_expiry from homeassistant.components.cert_expiry
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded dynalite from homeassistant.components.dynalite
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded life360 from homeassistant.components.life360
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded lifx from homeassistant.components.lifx
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded hisense_aehw4a1 from homeassistant.components.hisense_aehw4a1
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded hangouts from homeassistant.components.hangouts
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded velbus from homeassistant.components.velbus
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded ps4 from homeassistant.components.ps4
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded soma from homeassistant.components.soma
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded sonos from homeassistant.components.sonos
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded wwlln from homeassistant.components.wwlln
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded nest from homeassistant.components.nest
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded zwave from homeassistant.components.zwave
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded coronavirus from homeassistant.components.coronavirus
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded ios from homeassistant.components.ios
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded ipma from homeassistant.components.ipma
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded ambient_station from homeassistant.components.ambient_station
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded ambiclimate from homeassistant.components.ambiclimate
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded geonetnz_quakes from homeassistant.components.geonetnz_quakes
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded dialogflow from homeassistant.components.dialogflow
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded mailgun from homeassistant.components.mailgun
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded abode from homeassistant.components.abode
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded emulated_roku from homeassistant.components.emulated_roku
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded luftdaten from homeassistant.components.luftdaten
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded rainmachine from homeassistant.components.rainmachine
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded adguard from homeassistant.components.adguard
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded gpslogger from homeassistant.components.gpslogger
2020-03-14 01:02:31 INFO (SyncWorker_9) [homeassistant.loader] Loaded hue from homeassistant.components.hue
2020-03-14 01:02:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded vesync from homeassistant.components.vesync
2020-03-14 01:02:31 INFO (SyncWorker_4) [homeassistant.loader] Loaded logi_circle from homeassistant.components.logi_circle
2020-03-14 01:02:31 INFO (SyncWorker_5) [homeassistant.loader] Loaded notion from homeassistant.components.notion
2020-03-14 01:02:31 INFO (SyncWorker_2) [homeassistant.loader] Loaded glances from homeassistant.components.glances
➜ config
Does anyone see what I’m doing wrong? The last time I reconfigured my system was way back on v0.64, so maybe something has changed!
