Good morning/afternoon everyone,
It appears that after upgrading to Hass.io version 0.74 MyQ support broke. No change in config. I’m getting this from the logs. To me it appears like myq-end is causing the issue (their site is not responding) but I logged into my portal without any issues and IOS app works fine.
Any thoughts?
Error while setting up platform myq
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 384, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 380, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.6/http/client.py", line 1331, in getresponse
response.begin()
File "/usr/local/lib/python3.6/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.6/http/client.py", line 258, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.6/socket.py", line 586, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.6/ssl.py", line 1009, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.6/ssl.py", line 871, in read
return self._sslobj.read(len, buffer)
File "/usr/local/lib/python3.6/ssl.py", line 631, in read
v = self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 445, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.6/site-packages/urllib3/packages/six.py", line 686, in reraise
raise value
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 386, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 306, in _raise_timeout
raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='myqexternal.myqdevice.com', port=443): Read timed out. (read timeout=3.0)
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 129, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cover/myq.py", line 45, in setup_platform
if not myq.is_login_valid():
File "/usr/local/lib/python3.6/site-packages/pymyq/__init__.py", line 90, in is_login_valid
timeout=self.REQUEST_TIMEOUT
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 112, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 512, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 622, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 526, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='myqexternal.myqdevice.com', port=443): Read timed out. (read timeout=3.0)
