Also seeing similar issue with MyQ on 79.2, but appears to be intermittent. I have had it work sometimes, but more often than not it isn’t.
Seeing this in the logs:
2018-10-02 08:41:35 ERROR (MainThread) [homeassistant.components.cover] Error while setting up platform myq
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 171, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 56, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.6/socket.py", line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 849, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 314, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 180, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6f6f7990>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 445, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='myqexternal.myqdevice.com', port=443): Max retries exceeded with url: /api/v4/User/Validate (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f6f7990>: Failed to establish a new connection: [Errno -3] Try again',))
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cover/myq.py", line 54, in setup_platform
if not myq.is_login_valid():
File "/usr/local/lib/python3.6/site-packages/pymyq/__init__.py", line 97, in is_login_valid
timeout=self.REQUEST_TIMEOUT
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 112, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 512, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 622, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 513, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='myqexternal.myqdevice.com', port=443): Max retries exceeded with url: /api/v4/User/Validate (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f6f7990>: Failed to establish a new connection: [Errno -3] Try again',))
