Cross-posting to a few others as this does not appear to be solved, for me at least, after upgrading to .79 which has the pull request merged. Any ideas are greatly appreciated.
The new update on 0.79 doesn’t seem to solve the issue for me. I am still getting the below when opening and stopping the door halfway. The system doesn’t seem to recognize the ‘opening’ / ‘stopped’ state, though it does see ‘closing’ and ‘closed’:
2018-09-28 21:24:14 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 234, in async_update_ha_state
state = self.state
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/cover/init.py”, line 231, in state
if self.is_opening:
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/cover/myq.py”, line 109, in is_opening
return MYQ_TO_HASS[self._status] == STATE_OPENING
KeyError: ‘stopped’
The above occurs when I am running the ‘open’ and then ‘stop’ command. Otherwise, the below is happening in the background and writing to the log file:
2018-09-28 21:20:29 ERROR (SyncWorker_11) [pymyq] MyQ - API Error[get_devices] 500 Server Error: Internal Server Error for url: https://myqexternal.myqdevice.com/api/v4/UserDeviceDetails/Get
2018-09-28 21:20:29 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
state = self.state
if self.is_opening:
KeyError: False
