I’m getting the following error from the myq component since the 0.47 upgrade. I haven’t tried 47.1 yet, I’ll try it when I get home tonight, but I wanted to see if anyone had any insights.
2017-06-22 10:22:46 ERROR (MainThread) [homeassistant.helpers.entity] Update for cover.single_car fails
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 224, in async_update_ha_state
yield from self.hass.async_add_job(self.update)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/cover/myq.py", line 99, in update
self._status = self.myq.get_status(self.device_id)
File "/home/homeassistant/.homeassistant/deps/pymyq/__init__.py", line 153, in get_status
devices = self.get_devices()
File "/home/homeassistant/.homeassistant/deps/pymyq/__init__.py", line 124, in get_devices
devices = devices.json()['Devices']
KeyError: 'Devices'
Hmm, i’ve been running it on 0.47.0 and now 0.47.1 without issue. Does everything work in the Chamberlain/Liftmaster mobile app? The error message seems to show that authentication worked but its not getting any devices returned.
I just added the following two info log entries around the json reformat. I wanted to see what Devices was before the format and after.
self.logger.info("Devices={}".format(devices))
self.logger.info("Devices after json conversion={}".format(devices))
It seems to be blowing up on the json() conversion I think because it’s getting a successful message and not the json string.
2017-06-23 17:34:22 INFO (Thread-10) [pymyq] Devices=<Response [200]>
2017-06-23 17:34:22 ERROR (MainThread) [homeassistant.helpers.entity] Update for cover.two_car fails
File "/home/homeassistant/.homeassistant/deps/pymyq/__init__.py", line 155, in get_status
File "/home/homeassistant/.homeassistant/deps/pymyq/__init__.py", line 125, in get_devices
KeyError: 'Devices'
I’ll try and format the request and see what I get back as a response.
The “200” code is the status of the return but not the content(body). I manually did a connection using postman to validate, then get device details. Got a 200 return code with the devices json in the body.
fyi, security token changed for the example. Basically running the validate to get the security token to use in the get device details. In the validate the MyQApplicationId is in the header, the username and password are in the body. In the device details both the security token and MyQApplicationId are in the headers. You may know all that but putting it out there anyway.
The body of the devices return should be about 5-8KB in size containing the details in json.
Does everything work in the mobile app? I can’t replicate that error in postman no matter how badly i muck up the method, id, username or password. Can you ping myqexternal.myqdevice.com from the HA system?
Yes everything works in the mobile app. I can ping myqexternal.myqdevice.com from the HA system. I’ve tried resetting my password and saying forgot password and having chamberlain do it for me. Still no luck.
Try adding a “cover” folder in “custom_components” and create a myq.py file with the contents from the gist below:
EDIT: File removed as it has known problems
then restart HA.
This has a few updates that I haven’t committed to HA yet, mostly an update interval so the endpoints aren’t getting hit as often, interval defaults to 120 seconds but can be changed in the config by adding a “scan_interval: 300” in the myq config.
Ok, give me a few, I’m updating all my appdaemon apps to account for Not having the zwave node_id after them and printing a new knob for my 3d printer. So I don’t want to restart HA at the moment, but I’ll get to it shortly.
Ok, here is what I get using the myq.py in custom_components/cover. At least this is a Python error and not some strange random error being thrown by chamberlain.
2017-06-24 16:08:45 ERROR (MainThread) [homeassistant.helpers.entity] Update for cover.two_car fails
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/util/__init__.py", line 302, in wrapper
if force or utcnow() - throttle[1] > self.min_time:
TypeError: unorderable types: datetime.timedelta() > NoneType()
2017-06-24 16:08:45 ERROR (MainThread) [homeassistant.helpers.entity] Update for cover.single_car fails
Oh and I’m happy to help debug this anyway you need.
Interesting, wonder if some of those functions are new to Python 3.5 or 3.6. I’m on 3.6 in the docker image. I’m obviously not a Python expert but will see if I can setup a 3.4 install of HA and check out those errors.
Not sure I have any answers for you. Tried the official component on python 3.4.x and 3.5.x and it starts up and controls the door without issue. The custom component (from the gist) does not work in 3.4.x as I get the same errors as you. Probably not going to worry about it as its not published yet and seems HA is pushing for getting on 3.6 soon anyway.
You should probably remove the custom version.
I will put some more thought into your -3333 error with the official component. If you could try hitting the endpoints manually with postman or something similar that may be helpful. Also did you try the username and password directly in config without using !secret? I at a loss for the moment otherwise. Will keep an eye on the forums for others possibly having similar issues.
