I am a new Home Assistant user and I was able to hook up my craftsman garage door opener on the MyQ plug-in to Home Assistant. It works flawlessly when I press the up and down buttons with the widget I have on the dashboard, however, it stopped working for the automation I set up.
The automation I set up detects when my phone is entering my home zone, and it tells the garage door opener to open up the door. It worked great for a few days, but the past week, it has only worked 1 out of 5 times that I’ve gone home. I had to open the garage door from the Home Assistant dashboard using the widgets, which worked.
I checked the automation and it does indeed get triggered, but it gets the following error when trying to open the garage door:
2022-06-29 19:49:58 ERROR (MainThread) [homeassistant.components.automation.open_garage_door_when_coming_home_phu] Error while executing automation automation.open_garage_door_when_coming_home_phu: Opening of cover Garage Door Opener failed with error: Error requesting data from https://account-devices-gdo.myq-cloud.com/api/v5.2/Accounts/<Some sort of uuid>/door_openers/<some sort of code>/open: 401 - Unauthorized
This message happens every time the automation doesn’t work properly. Has anyone encountered this or know why it might be happening?
