MyQ Garage door integration stops working unless 'reloaded'
HA is docker install
MyQ garage doors (2) are on DHCP reservations so the IPs stay consistant.
About every few days or a week or so (need to watch closer) MyQ garage doors stop responding to open/close commands via HA. If I go to integrations and “reload” MyQ - it starts working again.
Any ideas what might cause this?
I have the garage status icons overlaid on a camera view of the garage doors so I can see and then easily open/close remotely with home assistant.
If I use the MyQ app, it ALWAYS works, even with the HA integration stops. Nothing in the HA logs.
Thank you!!
The MyQ integration in HA uses an unpublished and reverse engineered API similar to what the app uses. However, MyQ has been known in the past to push a change to the API that breaks everything except their app. It’s possible MyQ has done something recently.
Anecdotally I will say I also have HA running in a docker and haven’t had a problem with MyQ for a few weeks. Status is reported correctly and I can control the garage doors through HA (specifically the HomeKit integration).
