I’m completely new to HA and have only been tinkering with setup & configuration for maybe a good 8-10 hours or so but I’m trying to make an honest effort to learn before asking for some help. I have probably 30-40 integrations setup & working already but I keep having a problem with the MyQ integration and Im hoping someone can offer some help.
Basically, once I set up the MyQ integration, it works for about 30 minutes and then says my password is invalid. I’m still logged into the mobile app and confirm it’s still working, but if I log out of mobile and try to log back in then I get a popup saying, “Sorry, your account has been locked because of too many bad attempts. Please reset your password or try again in 1 hour.” So I reset the password, confirm it’s working, and I’m able to login to the mobile app again, then update the password in HA and it all works again. Then 30 minutes later, it says the passwords are invalid and I’m forced to reset the password and update HA again only for it to keep failing every 20-30 minutes.
I’m running…
Home Assistant OS 6.6
core-2021.11.3
supervisor-2021.10.8
This is the only relevant thing I see when I go to Config → Logs
Logger: homeassistant.config_entries Source: config_entries.py:318
Config entry 'Garage Door' for myq integration could not authenticate: Invalid MyQ credentials provided. Please recheck login and password
I’m using the File editor Addon and disabled enforce_basepath to allow me to view all files & folders but I cant seem to find the actual MyQ integration spot to try and debug further. When I reset the password and get the integration working I was able to click on it and unselect two options for polling updates which I thought would solve the problem however that hasn’t changed anything, password keeps getting blocked after 20-30 minutes. I don’t see anything in the configuation.yaml file that even references this integration.
Anyways, hoping that maybe its something really simple I am missing and someone to help point me towards a fix.
- Ryan
