I’ve noticed after the latest MyQ fix that the cover state no longer changes to opening. As a result when you press the open button you receive no indication that the command was received. Once the door is opened fully the state changes to open. Prior to the last update I would see an immediate change by the up arrow graying out and the down arrow becoming active. Anyone else seeing this?
Just after posting this I’ve tested a couple of times and the results are inconsistent. Sometimes the state will go into opening and sometimes it will not. Same thing for closing.
I’m seeing this as well, but I haven’t dug into any logs yet. Figured I’d just add a “me too.” To the issue.
