I’m having problems with my ethernet gateway, my node wil not connect.
When i rebuild my gateway to a serial gateway with the same components, it works.
Can someone post a working sketch for an ethernet gateway (w5100)?
I’ve only tested the MQTT gateway on the 5100 for mysensors 2.0 and that worked. I used the default example sketch and just changed the IP address for the broker, I think.
Do you have a serial log from the node?
Did you uncomment the w5100 configuration section in the sketch?
I’m at work now, i Will post the sketches and the logs when i come home.
The sketch for the serial gateway:
* The MySensors Arduino library handles the wireless radio link and protocol
* between your home built sensors/actuators and HA controller of choice.
* The sensors forms a self healing radio network with optional repeaters. Each
* repeater and gateway builds a routing tables in EEPROM which keeps track of the
* network topology allowing messages to be routed to nodes.
* Created by Henrik Ekblad <[email protected]>
* Copyright (C) 2013-2015 Sensnology AB
* Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
* Documentation: http://www.mysensors.org
* Support Forum: http://forum.mysensors.org
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation.
* DESCRIPTION
* The ArduinoGateway prints data received from sensors on the serial link.
* The gateway accepts input on seral which will be sent out on radio network.
* The GW code is designed for Arduino Nano 328p / 16MHz
* Wire connections (OPTIONAL):
* - Inclusion button should be connected between digital pin 3 and GND
* - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
* LEDs (OPTIONAL):
* - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
* - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
* - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
* - ERR (red) - fast blink on error during transmission error or recieve crc error
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
// Set LOW transmit power level as default, if you have an amplified NRF-module and
// power your radio separately with a good regulator you can turn up PA level.
#define MY_RF24_PA_LEVEL RF24_PA_LOW
// Enable serial gateway
#define MY_GATEWAY_SERIAL
// Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
#if F_CPU == 8000000L
#define MY_BAUD_RATE 38400
#endif
// Flash leds on rx/tx/err
#define MY_LEDS_BLINKING_FEATURE
// Set blinking period
#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Inverses the behavior of leds
//#define MY_WITH_LEDS_BLINKING_INVERSE
// Enable inclusion mode
#define MY_INCLUSION_MODE_FEATURE
// Enable Inclusion mode button on gateway
#define MY_INCLUSION_BUTTON_FEATURE
// Inverses behavior of inclusion button (if using external pullup)
//#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
// Set inclusion mode duration (in seconds)
#define MY_INCLUSION_MODE_DURATION 60
// Digital pin used for inclusion mode button
#define MY_INCLUSION_MODE_BUTTON_PIN 3
// Uncomment to override default HW configurations
//#define MY_DEFAULT_ERR_LED_PIN 4 // Error led pin
//#define MY_DEFAULT_RX_LED_PIN 6 // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN 5 // the PCB, on board LED
#define MY_NODE_ID 0
#include <SPI.h>
#include <MySensors.h>
#define SN "GateWay"
#define SV "1.0"
void setup() {
// Setup locally attached sensors
void presentation() {
// Present locally attached sensors
sendSketchInfo(SN, SV);
void loop() {
// Send locally attached sensor data here
The sketch for the sensor:
* REVISION HISTORY
* Version 1.0 - Henrik EKblad
* DESCRIPTION
* This sketch provides an example how to implement a humidity/temperature
* sensor using DHT11/DHT-22
* http://www.mysensors.org/build/humidity
#define MY_DEBUG
//#define MY_DEBUG_VERBOSE_RF24
//#define MY_RF24_PA_LEVEL RF24_PA_LOW
//#define MY_RF24_DATARATE RF24_1MBPS
#define MY_NODE_ID 4
#include <SPI.h>
#include <DHT.h>
#define SN "Noor"
#define SV "1.0"
#define CHILD_ID_TEMP 1
#define CHILD_ID_HUM 2
#define CHILD_ID_MOT 3 // Id of the sensor child
#define HUMIDITY_SENSOR_DIGITAL_PIN 4
#define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
DHT dht;
float lastTemp;
float lastHum;
boolean metric = true;
MyMessage msgHum(CHILD_ID_HUM, V_HUM);
MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
void presentation()
// Send the Sketch Version Information to the Gateway
// Register all sensors to gw (they will be created as child devices)
delay(200);
present(CHILD_ID_TEMP, S_TEMP);
delay(200);
present(CHILD_ID_HUM, S_HUM);
delay(200);
present(CHILD_ID_MOT, S_MOTION);
metric = getConfig().isMetric;
void setup()
dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
if (SLEEP_TIME <= dht.getMinimumSamplingPeriod()) {
Serial.println("Warning: UPDATE_INTERVAL is smaller than supported by the sensor!");
// Sleep for the time of the minimum sampling period to give the sensor time to power up
// (otherwise, timeout errors might occure for the first reading)
sleep(dht.getMinimumSamplingPeriod());
// metric = getConfig().isMetric;
pinMode(DIGITAL_INPUT_SENSOR, INPUT); // sets the motion sensor digital pin as input
delay(100);
send(msgTemp.set("0"));
delay(100);
send(msgHum.set("0"));
delay(100);
send(msgMot.set("0"));
void loop()
// Read digital motion value
boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
Serial.println(tripped);
send(msgMot.set(tripped?"1":"0")); // Send tripped value to gw
delay(dht.getMinimumSamplingPeriod());
// Fetch temperatures from DHT sensor
float temperature = dht.getTemperature();
if (isnan(temperature)) {
Serial.println("Failed reading temperature from DHT");
} else if (temperature != lastTemp) {
lastTemp = temperature;
if (!metric) {
temperature = dht.toFahrenheit(temperature);
send(msgTemp.set(temperature, 1));
#ifdef MY_DEBUG
Serial.print("T: ");
Serial.println(temperature);
#endif
// Fetch humidity from DHT sensor
float humidity = dht.getHumidity();
if (isnan(humidity)) {
Serial.println("Failed reading humidity from DHT");
} else if (humidity != lastHum) {
lastHum = humidity;
send(msgHum.set(humidity, 1));
#ifdef MY_DEBUG
Serial.print("H: ");
Serial.println(humidity);
#endif
sleep(INTERRUPT,CHANGE, SLEEP_TIME); //sleep a bit
The sketch for the ethernet gateway:
* REVISION HISTORY
* Contribution by a-lurker and Anticimex,
* Contribution by Norbert Truchsess <[email protected]>
* Contribution by Tomas Hozza <[email protected]>
* DESCRIPTION
* The EthernetGateway sends data received from sensors to the ethernet link.
* The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
* The GW code is designed for Arduino 328p / 16MHz. ATmega168 does not have enough memory to run this program.
* LED purposes:
* - To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h
* See http://www.mysensors.org/build/ethernet_gateway for wiring instructions.
#define MY_DEBUG
// Enable gateway ethernet module type
#define MY_GATEWAY_W5100
// W5100 Ethernet module SPI enable (optional if using a shield/module that manages SPI_EN signal)
//#define MY_W5100_SPI_EN 4
// Enable Soft SPI for NRF radio (note different radio wiring is required)
// The W5100 ethernet module seems to have a hard time co-operate with
// radio on the same spi bus.
#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
#define MY_SOFTSPI
#define MY_SOFT_SPI_SCK_PIN 14
#define MY_SOFT_SPI_MISO_PIN 16
#define MY_SOFT_SPI_MOSI_PIN 15
#endif
// When W5100 is connected we have to move CE/CSN pins for NRF radio
#ifndef MY_RF24_CE_PIN
#define MY_RF24_CE_PIN 5
#endif
#ifndef MY_RF24_CS_PIN
#define MY_RF24_CS_PIN 6
#endif
// Enable to UDP
//#define MY_USE_UDP
#define MY_IP_ADDRESS 192,168,0,40 // If this is disabled, DHCP is used to retrieve address
// Renewal period if using DHCP
//#define MY_IP_RENEWAL_INTERVAL 60000
// The port to keep open on node server mode / or port to contact in client mode
#define MY_PORT 5003
// Controller ip address. Enables client mode (default is "server" mode).
// Also enable this if MY_USE_UDP is used and you want sensor data sent somewhere.
//#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
// The MAC address can be anything you want but should be unique on your network.
// Newer boards have a MAC address printed on the underside of the PCB, which you can (optionally) use.
// Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
//#define MY_LEDS_BLINKING_FEATURE
//#define MY_INCLUSION_BUTTON_FEATURE
//#define MY_INCLUSION_MODE_BUTTON_PIN 3
//#define MY_DEFAULT_ERR_LED_PIN 7 // Error led pin
//#define MY_DEFAULT_RX_LED_PIN 8 // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN 9 // the PCB, on board LED
#include <SPI.h>
#if defined(MY_USE_UDP)
#include <EthernetUdp.h>
#endif
#include <Ethernet.h>
#define SV "1.0"
void setup() {
//void loop() {
// // Send locally attached sensor data here
When i use this sketch, I rewire the radio-module like told here https://www.mysensors.org/build/ethernet_gateway
I also uncomment
#define MY_SOFTSPI
in Myconfig.h
This is the serial log for the ethernet gateway:
��0���0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
0;255;3;0;9;TSM:INIT
0;255;3;0;9;TSM:RADIO:OK
0;255;3;0;9;TSM:GW MODE
0;255;3;0;9;TSM:READY
IP: 192.168.0.40
IP: 192.168.0.40
and here is the serial log for the sensor when using the ethernet gateway:
��Starting sensor (RNNNA-, 2.0.0)
TSM:INIT
TSM:RADIO:OK
TSP:ASSIGNID:OK (ID=4)
TSM:FPAR
TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
TSM:FPAR
TSM:FPAR
TSM:FPAR
!TSM:FPAR:FAIL
!TSM:FAILURE
TSM:PDT
And these are warnings from hass:
16-08-30 14:48:53 WARNING (MainThread) [mysensors.mysensors] File does not exist or is not readable: /home/pi/.homeassistant/mysensors_ethernet.json
16-08-30 14:48:53 WARNING (MainThread) [mysensors.mysensors] Trying backup file: /home/pi/.homeassistant/mysensors_ethernet.json.bak
16-08-30 14:48:53 WARNING (MainThread) [mysensors.mysensors] File does not exist or is not readable: /home/pi/.homeassistant/mysensors_ethernet.json.bak
16-08-30 14:48:53 WARNING (MainThread) [mysensors.mysensors] Failed to load sensors from file: /home/pi/.homeassistant/mysensors_ethernet.json
The node fails to find a parent, which usually is a sign of bad/unreliable radio communication. Check wiring, check/change power source, check/change capacitors, change distance between gateway and node. Do all this for both sides, gateway and node, if you’re not sure that either side is good, not at fault.
See:
https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
for debugging schema.
You don’t have to define MY_SOFTSPI in MyConfig.h as it is automatically defined in the sketch.
The warning messages from home assistant is just due to no persistence file exists at first start.
Do you use 5V or 3,3V for the W5100?
Normally 3.3V but you should check the labels/instructions for your copy. I’ve seen reports of 5V labels on the power pin for some copies.
Might be good to start testing at 3.3V, that way you won’t risk smoking anything.
I finally made it work.
Thanks to this topic: https://forum.mysensors.org/topic/4628/solved-mysensors-2-0-ethernet-gateway-enc28j60-restart-ip-issue/46
I had to update to Arduino IDE 1.6.11 and downgrade to AVR Board defs 1.6.11,
then i used the same components and sketch.
btw it was 5V
My ethernet gateway was broken, so I had to make a new one.
I used the same components
Arduino IDE 1.8.1
Arduino AVR Boards 1.6.20
Mysensors 2.2.0
and
