Currently I’m not able to get MySensors Arduino Mega 2560 v3 working with Home Assistant.
Arduino Code:
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable serial gateway
#define MY_GATEWAY_SERIAL
// Enable inclusion mode
#define MY_INCLUSION_MODE_FEATURE
// Enable Inclusion mode button on gateway
#define MY_INCLUSION_BUTTON_FEATURE
// Set inclusion mode duration (in seconds)
#define MY_INCLUSION_MODE_DURATION 60
// Digital pin used for inclusion mode button
#define MY_INCLUSION_MODE_BUTTON_PIN 3
// Uncomment to override default HW configurations
//#define MY_DEFAULT_ERR_LED_PIN 4 // Error led pin
//#define MY_DEFAULT_RX_LED_PIN 6 // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN 5 // the PCB, on board LED
#include <SPI.h>
#include <MySensors.h>
#include <Bounce2.h>
// Enable repeater functionality for this node
#define MY_REPEATER_FEATURE
#define RELAY_1 14 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define RELAY_2 15
#define RELAY_3 16
#define RELAY_4 17
#define NUMBER_OF_RELAYS 4 // Total number of attached relays
#define RELAY_ON 1 // GPIO value to write to turn on attached relay
#define RELAY_OFF 0 // GPIO value to write to turn off attached relay
#define BUTTON_PIN 5
#define BUTTON2_PIN 6
#define BUTTON3_PIN 7
#define BUTTON4_PIN 8
void before() {
for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
// Then set relay pins in output mode
pinMode(pin, OUTPUT);
// Set relay to last known state (using eeprom storage)
digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
Bounce debouncer = Bounce();
Bounce debouncer2 = Bounce();
Bounce debouncer3 = Bounce();
Bounce debouncer4 = Bounce();
void setup() {
// Setup locally attached sensors
delay(10000);
// Setup the button.
pinMode(BUTTON_PIN, INPUT_PULLUP);
pinMode(BUTTON2_PIN, INPUT_PULLUP);
pinMode(BUTTON3_PIN, INPUT_PULLUP);
pinMode(BUTTON4_PIN, INPUT_PULLUP);
// After setting up the button, setup debouncer.
debouncer.attach(BUTTON_PIN);
debouncer.interval(5);
debouncer2.attach(BUTTON2_PIN);
debouncer2.interval(5);
debouncer3.attach(BUTTON3_PIN);
debouncer3.interval(5);
debouncer4.attach(BUTTON4_PIN);
debouncer4.interval(5);
//presentation();
void presentation()
// Send the sketch version information to the gateway and Controller
sendSketchInfo("Relay", "1.0");
// Register all sensors to gw (they will be created as child devices)
present(sensor, S_LIGHT);
MyMessage msg(1, V_LIGHT);
MyMessage msg2(2, V_LIGHT);
MyMessage msg3(3, V_LIGHT);
MyMessage msg4(4, V_LIGHT);
void loop() {
// Send locally attached sensor data here
if (debouncer.update()) {
// Get the update value.
int value = debouncer.read();
// Send in the new value.
if (value == LOW) {
saveState(1, !loadState(1));
digitalWrite(RELAY_1, loadState(1) ? RELAY_ON : RELAY_OFF);
send(msg.set(loadState(1)));
if (debouncer2.update()) {
int value2 = debouncer2.read();
if(value2 == LOW){
saveState(2, !loadState(2));
digitalWrite(RELAY_2, loadState(2)?RELAY_ON:RELAY_OFF);
send(msg2.set(loadState(2)));
if (debouncer3.update()) {
int value3 = debouncer3.read();
if(value3 == LOW){
saveState(3, !loadState(3));
digitalWrite(RELAY_3, loadState(3)?RELAY_ON:RELAY_OFF);
send(msg3.set(loadState(3)));
if (debouncer4.update()) {
int value4 = debouncer4.read();
if(value4 == LOW){
saveState(4, !loadState(4));
digitalWrite(RELAY_4, loadState(4)?RELAY_ON:RELAY_OFF);
send(msg4.set(loadState(4)));
void receive(const MyMessage &message) {
// We only expect one type of message from controller. But we better check anyway.
if (message.type == V_LIGHT) {
// Change relay state
digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
// Store state in eeprom
saveState(message.sensor, message.getBool());
// Write some debug info
Serial.print("Incoming change for sensor:");
Serial.print(message.sensor);
Serial.print(", New status: ");
Serial.println(message.getBool());
Arduino is working properly but HA doesn’t see any switches or relays.
Config:
mysensors:
gateways:
- device: '/dev/ttyACM0'
persistence_file: 'mysensors.json'
baud_rate: 115200
nodes:
1:
optimistic: true
retain: true
version: '2.0'
Console:
➜ /config hassio hw info
audio: {}
disk: []
gpio: []
input:
- PC Speaker
- Power Button
serial:
- /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_9573632363235121D150-if00
- /dev/ttyS0
- /dev/ttyACM0
mysensor.json - automatically generated:
I’m currently using Hassio 0.97.2 on UnRaid (docker) - I’ve tried on Raspberry Pi, Ubuntu Server (docker) and same think, nothing is showing up in mysensor.json
Any idea how to make it work?
