Hi all. Today I hit the brick wall and I cannot find my way around it:
I run somewhat decent HomeAssistant instance (hundreds of entities) at home for quite a long time (years). Today I just wanted to add another ESP8266 MySensor Gateway to my configuration, like this:
gateways:
- device: '192.168.1.201'
persistence_file: '/config/mysensors-balcony-light.json'
tcp_port: 5003
- device: '192.168.1.109'
persistence_file: '/config/mysensors-gw.json'
tcp_port: 5003
- device: '192.168.1.204'
persistence_file: '/config/cooling-fans.json'
tcp_port: 5003
- device: '192.168.1.135'
persistence_file: '/config/mysensors-gw-433.json'
tcp_port: 5003
- device: '192.168.1.210'
persistence_file: '/config/balcony-led.json'
tcp_port: 5003
I know that the new GW is OK (it responds to telnet:5003 and behaves as it should). It is the carbon copy of an existing GW on a different IP, so I am reasonably sure that its fw is OK.
All gateways are running happily, but HomeAssistant refuses to connect to the last one (1.210). In my log I can see connect attempts to the current GWs, but the 1.210 remains ignored:
2021-03-27 09:58:13 INFO (MainThread) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.204', 5003)
2021-03-27 09:58:13 INFO (MainThread) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.201', 5003)
2021-03-27 09:58:13 INFO (MainThread) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.135', 5003)
2021-03-27 09:58:13 INFO (MainThread) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.109', 5003)
Also, in the fancy new GUI integration screen I can see MySensors tile with 4 GWs, but no mention about the 5th.
There is nothing suspicious in the log nor anywhere else. I have some feeling that it might have something to do with the recent HASS update (I am currently running HA 2021.3.4) and maybe there is some conflict between YAML and “GUI” configuration, but I just cannot find anything else to tweak.
Does anybody of y’all have any insight regarding this? I admit I am at my wit’s end.
Many thanks,
Jan
