I keep getting these error messages in the log file when I start one specific sensor:
child_id 1 already exists in children of node 227, cannot add child
This is an energy meter sensor, using the default sketch from the Mysensors libraries. The sensor works as expected (e.g it shows up in HA and shows values for kWh and W), but everytime it starts I get the above message. Do I need to worry about it?
Here’s the serial log from the sensor:
0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1
4 TSM:INIT
4 TSF:WUR:MS=0
12 TSM:INIT:TSP OK
14 TSF:SID:OK,ID=227
16 TSM:FPAR
53 TSF:MSG:SEND,227-227-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
2060 !TSM:FPAR:NO REPLY
2062 TSM:FPAR
2099 TSF:MSG:SEND,227-227-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
2666 TSF:MSG:READ,0-0-227,s=255,c=3,t=8,pt=1,l=1,sg=0:0
2672 TSF:MSG:FPAR OK,ID=0,D=1
4108 TSM:FPAR:OK
4108 TSM:ID
4110 TSM:ID:OK
4112 TSM:UPL
4118 TSF:MSG:SEND,227-227-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
4233 TSF:MSG:READ,0-0-227,s=255,c=3,t=25,pt=1,l=1,sg=0:1
4239 TSF:MSG:PONG RECV,HP=1
4241 TSM:UPL:OK
4243 TSM:READY:ID=227,PAR=0,DIS=1
4249 TSF:MSG:SEND,227-227-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
4390 TSF:MSG:READ,0-0-227,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
4399 TSF:MSG:SEND,227-227-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
4409 TSF:MSG:SEND,227-227-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
4888 TSF:MSG:READ,0-0-227,s=255,c=3,t=6,pt=0,l=1,sg=0:M
4896 TSF:MSG:SEND,227-227-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Energy Meter
4909 TSF:MSG:SEND,227-227-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
4919 TSF:MSG:SEND,227-227-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
4925 MCO:REG:REQ
4964 !TSF:MSG:SEND,227-227-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
6973 TSF:MSG:SEND,227-227-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
7049 TSF:MSG:READ,0-0-227,s=255,c=3,t=27,pt=1,l=1,sg=0:1
7055 MCO:PIM:NODE REG=1
7057 MCO:BGN:STP
7061 TSF:MSG:SEND,227-227-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
7067 MCO:BGN:INIT OK,TSP=1
7360 TSF:MSG:READ,0-0-227,s=1,c=1,t=24,pt=0,l=2,sg=0:79
Received last pulse count from gw:79
And here’s the mosquitto_sub output when starting the sensor:
mysensors-out/227/255/0/0/17 2.1.1
mysensors-out/227/255/3/0/6 0
mysensors-in/227/255/3/0/6 M
mysensors-out/227/255/3/0/11 Energy Meter
mysensors-out/227/255/3/0/12 1.0
mysensors-out/227/1/0/0/13 (null)
mysensors-out/227/1/2/0/24 (null)
mysensors-in/227/1/1/0/24 79
