I’d like to turn on my mysensor driver led strips on a certain brightness.
When I do that the led strips turns on on 100% brightness then immediately dimmed down to the wanted level. Is this intentional? Or am I doing something wrong?
Full sketch for the arduino:
// Enable debug prints to serial monitor
#define MY_DEBUG
#define MY_RADIO_NRF24
#define MY_NODE_ID 141
#define CHILD_ID 123
#define CHILD_ID2 124
// Enable and select radio type attached
#include <MySensors.h>
#define SN "KitchenCabinet2"
#define SV "1.5"
#define LED_PIN 3 // Arduino pin attached to MOSFET Gate pin
#define LED_PIN2 5 // Arduino pin attached to MOSFET Gate pin
#define FADE_DELAY 10 // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
static int16_t currentLevel = 0; // Current dim level...
static int16_t currentLevel2 = 0; // Current dim level...
MyMessage dimmerMsg(CHILD_ID, V_DIMMER);
MyMessage lightMsg(CHILD_ID, V_LIGHT);
MyMessage dimmerMsg2(CHILD_ID2, V_DIMMER);
MyMessage lightMsg2(CHILD_ID2, V_LIGHT);
Dimmable LED initialization method
void setup()
void presentation()
// Register the LED Dimmable Light with the gateway
sendSketchInfo(SN, SV);
present(CHILD_ID, S_DIMMER);
present(CHILD_ID2, S_DIMMER);
void loop()
static bool first_message_sent = false;
if ( first_message_sent == false ) {
analogWrite( LED_PIN, 0);
analogWrite( LED_PIN2, 0);
Serial.println( "Sending initial state..." );
send(lightMsg.set(currentLevel));
send(dimmerMsg.set(currentLevel));
send(lightMsg2.set(currentLevel2));
send(dimmerMsg2.set(currentLevel2));
first_message_sent = true;
void receive(const MyMessage &message)
if (message.type == V_LIGHT || message.type == V_DIMMER) {
if (message.sensor == CHILD_ID) {
// Retrieve the power or dim level from the incoming request message
int requestedLevel = atoi( message.data );
// Adjust incoming level if this is a V_LIGHT variable update [0 == off, 1 == on]
requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
// Clip incoming level to valid range of 0 to 100
requestedLevel = requestedLevel > 100 ? 100 : requestedLevel;
requestedLevel = requestedLevel < 0 ? 0 : requestedLevel;
Serial.print( "led1 Changing level to " );
Serial.print( requestedLevel );
Serial.print( ", from " );
Serial.println( currentLevel );
fadeToLevel( requestedLevel );
// Inform the gateway of the current DimmableLED's SwitchPower1 and LoadLevelStatus value...
send(lightMsg.set(currentLevel > 0));
// hek comment: Is this really nessesary?
send( dimmerMsg.set(currentLevel) );
if (message.sensor == CHILD_ID2) {
Serial.print( "Led2 Changing level to " );
Serial.println( currentLevel2 );
fadeToLevel2( requestedLevel );
send(lightMsg2.set(currentLevel2 > 0));
send( dimmerMsg2.set(currentLevel2) );
This method provides a graceful fade up/down effect
void fadeToLevel(int toLevel ) {
int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
while ( currentLevel != toLevel ) {
currentLevel += delta;
analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
delay( FADE_DELAY );
void fadeToLevel2(int toLevel ) {
int delta = ( toLevel - currentLevel2 ) < 0 ? -1 : 1;
while (currentLevel2 != toLevel ) {
currentLevel2 += delta;
analogWrite(LED_PIN2, (int)(currentLevel2 / 100. * 255) );
delay(FADE_DELAY );
