Hello friends of the automated house,
not shure if this is the right topic, if not my apologies.
I would like to submit the following;
Currently i have automated part of the house via MySensors, which works well, but it is quite complex to adjust or update anything, and for good integration with HA I would have to reprogram all nodes.
In addition, I have a gateway that I have to reset regularly, and then also have to reboot HA, which is quite annoying of course.
Now I wondered what an alternative to MySensors would be, of course I immediately thought of ESPHome, of which I have also made some things, which is certainly less time-consuming.
I mainly created the MySensors network via RS485 with an Ethernet gateway, because I prefer a wired network in this case.
ESPHome is of course via WiFi, but I saw that it could also be connected via wired Ethernet, is that recommended?
What I also saw is that an Arduino can be used as a port extender, but is that a good choice?
My current MySensors network is now approximately as follows:
Most are equipped with an Arduino Pro Mini.
- 1 network in the meter cupboard
- 8 outputs (relay),
- 6 inputs, 1 DHT & 2 MQ sensors
- 2x control for water valve garden water, open & closed (control and status), 1 flow sensor 1x DHT sensor
- 1x water meter node, proximity sensor, Dallas temperature, pressure sensor, open/close (control & status) water tap, humidity sensor (with logic that closes the tap in case of leakage or excessive flow)
- 1x display node with display on Mega mini, with various inputs and outputs for buttons, LEDs and panel meter.
- And an old telephone that I can use as an alarm (bell) or selection (dial).
In addition, I have my own network for gardening, which includes, among other things:
- An Arduino Mega use for analog & binary inputs and outputs,
- A weather station with two pro minis,
- Thermostat and ventilation control for the shed.
- A valve control with 4 valves and 4 moisture sensors,
- And a ground temperature node with 6 Dallas temp sensors.
What would you advise, upgrade and adapt the current MySensor networks, or replace part of it with another system?
And what would be the best choice for me?
I have now used a Zigbee DIN rail relay for one of the outputs in the distribution box, which I like because of the extras such as metering.
Indeed, no ready-made components, but many self-made (diy) components.
I would like it if you could give me some tips, with the wired network as a starting point.
thanks in advance for your input!
