Hi.
I got problem with latest HA and mysensors gateway.
I just moved my HA in to a virtual machine (Lubuntu 14.04) and switched from a serial gateway to ethernet gateway.
Now i can’t get it going.
I can ping my gateway from my virtual machine. It responds as it should.
From my .yaml:
mysensors:
gateways:
- device:‘192.168.1.66’
persistence_file:’/home/lubuntu/.homeassistant/mysensors.json’
debug: ‘true’
version: ‘1.5’
Log:
ERROR:homeassistant.bootstrap:Error during setup of component mysensors
File “/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py”, line 150, in _setup_component
if not component.setup(hass, config):
File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensor s.py”, line 102, in setup
device = gway[CONF_DEVICE]
TypeError: string indices must be integers
