Hello HA community,
Is there anyway to increase the watchdog timer of the mySensors TCP integration?
My mySensors Gateway (ethernet) is rock solid for many years… but I do have many sensors and the network is reasonably busy, with eventual collisions + retries.
I understood that Home Assistant keeps pulling the gateway on every 10 seconds or so, and if the gateway is lazy to respond, the connection is closed and re-opened , with the message above. I’m getting this on every 1min or so:
I think by increasing the pooling interval (or better, the tolerance of response?) will keep my logs less poluted with this dummy warning message. Also, I think it may reduce the eventual HA lags in mySensors immediate commands such as lights on/off.
Thanks!
