When I configure my MySensors Gateway as an Ethernet gateway, and configure HASS in the same way, everything works fine.
However, if I change my MySensors gateway to be an MQTT gateway, the sensors never show up in HASS. I can see the topics being published to using an MQTT client. My HASS configuration looks like this:
mysensors:
gateways:
- device: mqtt
persistence_file: ‘/home/hass/.homeassistant/mysensors.json’
topic_in_prefix: ‘mysensors-in’
topic_out_prefix: ‘mysensors-out’
debug: true
optimistic: false
persistence: true
retain: true
version: 2.0
What did I do wrong?
i have really no clue about MQTT but i think that we should call @martinhjelmare to the rescue ![:wink: :wink:](https://community.home-assistant.io/images/emoji/twitter/wink.png?v=9)
Have you also configured the mqtt component in home assistant?
You should also check the topic prefixes. The topic where the gateway publishes should go to topic_in_prefix
and the gateway’s subscribe topic should go to topic_out_prefix
. If you didn’t change the prefixes when writing the mqtt gateway sketch, the prefixes should be configured like this:
topic_in_prefix: 'mygateway1-out'
topic_out_prefix: 'mygateway1-in'
But check how you have setup your gateway sketch.
Ah ha! I didn’t realize the out_prefix was supposed to point to the “in” topic, and vice versa. I’ll give that a shot. Thank you!
