MySensors multiple relays (without button) + reed switches problem
Hi everyone. Please help I’m struggling with this problem for days…
I want to create a sketch for Adruino to control 10 reed switches + 20 relays. I know how to create 1 relay and 1 switch (based on Mysensors documentation) and this works perfectly. When I try to add more relays - no new sensors appears in HA :frowning:
I have json file to store data and I delete this file every time something changes in Mysensors config)
Please take a look at the code,
I’m pretty sure I do something wrong in
void receive(const MyMessage &message)
or
void loop
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable serial gateway
#define MY_GATEWAY_SERIAL
// Define a lower baud rate for Arduino’s running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
#if F_CPU == 8000000L
#define MY_BAUD_RATE 38400
#endif
// Enable inclusion mode
#define MY_INCLUSION_MODE_FEATURE
// Enable Inclusion mode button on gateway
#define MY_INCLUSION_BUTTON_FEATURE
// Inverses behavior of inclusion button (if using external pullup)
//#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
// Set inclusion mode duration (in seconds)
#define MY_INCLUSION_MODE_DURATION 60
// Digital pin used for inclusion mode button
#define MY_INCLUSION_MODE_BUTTON_PIN 3
#include <SPI.h>
#include <MySensors.h>
#include <Bounce2.h>
// Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define RELAY_PIN_1A 22
#define RELAY_PIN_1B 23
// Arduino Digital I/O pin for button/reed switch
#define BUTTON_PIN2 24
#define NUMBER_OF_RELAYS 2 // Total number of attached relays
#define RELAY_ON 1 // GPIO value to write to turn on attached relay
#define RELAY_OFF 0 // GPIO value to write to turn off attached relay
#define CHILD_ID 1
#define CHILD_ID2 2
#define CHILD_ID3 3
void before()
for (int sensor=1, pin=RELAY_PIN_1A; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
// Then set relay pins in output mode
pinMode(pin, OUTPUT);
// Set relay to last known state (using eeprom storage)
digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF);
Bounce debouncer = Bounce();
Bounce debouncer2 = Bounce(); // Reed
Bounce debouncer3 = Bounce();
// for reed switch
int oldValue=-1;
bool state = false;
bool initialValueSent = false;
MyMessage msg(CHILD_ID, V_STATUS);
MyMessage msg2(CHILD_ID2, V_TRIPPED);
MyMessage msg3(CHILD_ID3, V_STATUS);
void setup()
debouncer2.attach(BUTTON_PIN2);
debouncer2.interval(5);
// Setup the button
pinMode(BUTTON_PIN2,INPUT);
digitalWrite(BUTTON_PIN2,HIGH);
// Make sure relays are off when starting up
pinMode(RELAY_PIN_1A, OUTPUT);
digitalWrite(RELAY_PIN_1A, RELAY_OFF);
pinMode(RELAY_PIN_1B, OUTPUT);
digitalWrite(RELAY_PIN_1B, RELAY_OFF);
void presentation() {
sendSketchInfo(“Relay”, “1.0”);
present(CHILD_ID, S_BINARY);
present(CHILD_ID2, S_DOOR);
present(CHILD_ID3, S_BINARY);
void loop()
if (!initialValueSent) {
request(CHILD_ID, V_STATUS);
request(CHILD_ID2, V_TRIPPED);
request(CHILD_ID3, V_STATUS);
wait(2000, C_SET, V_STATUS);
if (debouncer.update()) {
if (debouncer.read()==LOW) {
state = !state;
// Send new state and request ack back
send(msg.set(state?RELAY_ON:RELAY_OFF), true);
if (debouncer3.update()) {
if (debouncer3.read()==LOW) {
state = !state;
send(msg3.set(state?RELAY_ON:RELAY_OFF), true);
if (debouncer2.update()) {
// reed
// Get the update value
int value = debouncer2.read();
if (value != oldValue) {
// Send in the new value
send(msg2.set(value==HIGH ? 1 : 0));
oldValue = value;
void receive(const MyMessage &message) {
if (message.isAck()) {
Serial.println(“This is an ack from gateway”);
if (message.type == V_STATUS) {
Serial.println(“Receiving initial value from controller”);
initialValueSent = true;
// Change relay state
state = (bool)message.getInt();
if (message.sensor == CHILD_ID) {
  digitalWrite(RELAY_PIN_1A, state?RELAY_ON:RELAY_OFF);
  send(msg.set(state?RELAY_ON:RELAY_OFF));
else if (message.sensor == CHILD_ID3) {
digitalWrite(RELAY_PIN_1B, state?RELAY_ON:RELAY_OFF);
send(msg3.set(state?RELAY_ON:RELAY_OFF));
//else {
UPDATE
The code don’t show any sensors in HA righ now…
to get something shown in HA i need to use
… but then I can control 1 relay only :frowning:
Hello, ich have a similar problem did you found any solution?:slight_smile:
This code should work. I took relevant parts from code I am running for years now. Code not fully mine, sources unknown.
Attention: not tested with Home Assistant. I’m just moving from fhem.de to Home Assistant. Not much knowledge yet, e.g. I have no clue, how to toggle the relays from the UI. In fhem it works well. If someone has any hints, I would appreciate hints :slight_smile:
  Multi Relay Node
  Relays: D5,D6,D7,D8					--> 5v
// Enable and select radio type attached
#define MY_RADIO_RF24
#define MY_RF24_PA_LEVEL RF24_PA_MAX
#define MY_NODE_ID 2
#define MY_SPLASH_SCREEN_DISABLED
#define MY_TRANSPORT_WAIT_READY_MS (30000) // Don't stay awake for more than 30s if communication is broken
// Enable repeater functionality for this node
#define MY_REPEATER_FEATURE
#define SKETCH_NAME "multi relay node"
#define SKETCH_VERSION "2.3.1"
#define CHILD_ID_RELAY1 1 // 2,3,4
// Wait times
#define LONG_WAIT 500
#define SHORT_WAIT 50
// RELAY ///////////////////////////////////////////////////////////////////////
#define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define NUMBER_OF_RELAYS 4 // Total number of attached relays
#define RELAY_ON    LOW  // GPIO value to write to turn on attached relay
#define RELAY_OFF   HIGH // GPIO value to write to turn off attached relay
// Initialize message types
// https://www.mysensors.org/download/serial_api_20#variable-types
MyMessage msgRelay(CHILD_ID_RELAY1, V_STATUS); //V_TRIPPED);
  // Send the sketch version information to the gateway and Controller
  sendSketchInfo(SKETCH_NAME, SKETCH_VERSION " (" __DATE__ ")");
  wait(LONG_WAIT);
  // 4 channel relay
  for (int relays = 1, pin = RELAY_1; relays <= NUMBER_OF_RELAYS; relays++, pin++) {
    // Register all sensors to gateway (they will be created as child devices)
    present(relays, S_BINARY, "Relais (1/0)", ack);
    wait(SHORT_WAIT);
void setup() {
    // digitalWrite(pin, loadState(relays)?RELAY_ON:RELAY_OFF);
    digitalWrite(pin, RELAY_OFF);
  // We only expect one type of message from controller. But we better check anyway.
    digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
void loop() {}
