Hi All.
I am starting to set up Mysensors integration.
I have my mysenors /RFM95(433Mhz) to MQTT gateway running on the ESP32.
The Hassio Mysensors intagration, sees my first basic node (door/button binary sensor), Great.
But…
I am looking for checking the sensor availability, so I know if it drops off the system for some reason.
Research reveals the heart beat function, so now my node sends to the heartbeat topic…
mygateway1-out/2/255/3/0/22
the millis since node startup…a ever increasing number…
My question, has anyone else come up with a nice automation or process to create a node availability sensor for this.
Or, did I miss something in the Mysensors integration which already takes care of heart beats and such.
Cheers
P
Hi. Did you figure a good solution on this.
I am seeing heartbeat messages but do not know how to use them. Because there are big gaps in the increment of heartbeat messages.
I would appreciate if you could let me know your experience /thoughts
Thanks.
Answered my own question:
How to add node availability sensor to Home assistant.
Date: 26/4/20
Platform: Hassio Core 0.107.7 Operating system 3.12
Mysensors 2.3.2
Assumptions: You have a mysensors MQTT gateway setup on your home assistant and a mysensors node (Node 1) and child sensors sending data in, and you have hassio receiving/processing that sensor data.
Tip: use MQTTExplorer to check your MQTT messages are flowing through the gateway and MQTT broker
- We use mysensors heartbeats sent every 30 seconds from the node.
insert this code into your mysensors hardware node sketch firmware and upload
insert the void loop()
//-------------- Heart Beat---------------------------------------------------------
//this is sent by the Mysensors MQTTGateway to topic: mygateway1-out/1/255/3/0/22
static unsigned long lastLoopTime = 0; // Holds the last time the main loop ran.
if (millis() - lastLoopTime > 30000) {//one every 30 seconds
lastLoopTime = millis();
sendHeartbeat();//sends heartbeat msg time in millisseconds
- confirm heartbeat messages are coming through via the gateway and create a Hassio sensor: sensor.node_1_heart_beats -
platform: mqtt
name: “node1 heartbeats”
state_topic: “mygateway1-out/1/255/3/0/22”
you should see large integers every 30 seconds
3) make sure you have the Time_Date sensor configured in the Hassio configuration.yaml
4) add these automatons: which will compare local time with the time sensor.node_1_heart_beats is updated (with your node heartbeat via MQTT)
alias: Heartbeat RX regularity monitor, no HB after 40 s= avail = offline
description: ‘’
value_template: ‘{{ (states.sensor.time.last_changed - states.sensor.node_1_heart_beat.last_changed).total_seconds()> 40 }}’
condition: []
- data:
payload: offline
topic: tele/Node1
service: mqtt.publish
alias: Heartbeat RX regularity monitor, HB within 40 s = avail = online
description: ‘’
< 40 }}’
condition: []
- data:
payload: online
topic: tele/Node1
- setup a sensor in Home assistant sensor.node1_availability to monitor the MQTT topic tele/Node1
- platform: mqtt
name: “Node1 Availability”
state_topic: “tele/Node1”
