Mysensors receives messages but HA does not add entities
Running hassio on ubuntu, mysensors gateway with nodemcu mqtt gateway and having mysensor nodes. hassio version 0.103.3.
I had used this earlier (maybe 2-3 monts ago) and it worked fine. We had some renovation and the nodes were out of use for a long time.
The problem is that mysensor node sends all the info through gateway to HA but HA does not create the entities. I updated the mysensor libraries to 2.3.2 (currently latest) before starting. Maybe it was bad idea. But for now I have no idea what to do next. Deleting the persistence (pickle) file didnt help either. Tried restarting the homeassistant multiple times but didn’t help either.
I checked from the mosquitto broker that the messages are coming in. I could use just mqtt sensors in HA but that is not the idea with mysensors.
Added logging to home assistant and to me it seems fine again. I filtered the below to show only debug entries.
2019-12-30 20:54:12 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/+/+/0/+/+, qos: 0
2019-12-30 20:54:12 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/+/+/3/+/+, qos: 0
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;22;177057
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Publishing 3;255;3;0;19;
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;0;0;17;2.3.2
2019-12-30 20:55:00 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 255
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;6;0
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Publishing 3;255;3;0;6;M
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;20;0;0;34;Juha button 1
2019-12-30 20:55:00 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 20
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/3/20/1/+/+, qos: 0
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/3/20/2/+/+, qos: 0
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/3/+/4/+/+, qos: 0
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;21;0;0;34;Juha button 2
2019-12-30 20:55:00 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 21
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/3/21/1/+/+, qos: 0
2019-12-30 20:55:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/3/21/2/+/+, qos: 0
2019-12-30 20:55:01 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;22;0;0;34;Tiina button 1
2019-12-30 20:55:01 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 22
2019-12-30 20:55:01 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/3/22/1/+/+, qos: 0
2019-12-30 20:55:01 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/3/22/2/+/+, qos: 0
2019-12-30 20:55:01 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/3/+/4/+/+, qos: 0
2019-12-30 20:55:01 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;23;0;0;34;Tiina button 2
2019-12-30 20:55:01 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 23
2019-12-30 20:55:01 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/3/23/1/+/+, qos: 0
2019-12-30 20:55:01 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/3/23/2/+/+, qos: 0
2019-12-30 20:55:01 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;11;Bedcontrol
2019-12-30 20:55:01 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 255
2019-12-30 20:55:01 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;12;0.1
2019-12-30 20:55:16 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;23;1;0;37;1
2019-12-30 20:55:16 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 23
2019-12-30 20:55:16 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 23: value_type 37, value = 1
2019-12-30 20:55:16 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;23;1;0;37;0
2019-12-30 20:55:16 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 23: value_type 37, value = 0
2019-12-30 20:55:17 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;23;1;0;37;1
2019-12-30 20:55:17 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 23
2019-12-30 20:55:17 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 23: value_type 37, value = 1
2019-12-30 20:55:17 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;23;1;0;37;0
2019-12-30 20:55:17 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 23: value_type 37, value = 0
2019-12-30 20:56:00 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;22;237058
2019-12-30 20:56:00 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 255
2019-12-30 20:56:00 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 23: value_type 37, value = 0
2019-12-30 20:56:54 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;0;0;17;2.3.2
2019-12-30 20:56:54 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 255
2019-12-30 20:56:54 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;6;0
2019-12-30 20:56:54 DEBUG (MainThread) [mysensors.gateway_mqtt] Publishing 3;255;3;0;6;M
2019-12-30 20:56:54 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;20;0;0;34;Juha button 1
2019-12-30 20:56:55 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;21;0;0;34;Juha button 2
2019-12-30 20:56:55 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;22;0;0;34;Tiina button 1
2019-12-30 20:56:55 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;23;0;0;34;Tiina button 2
2019-12-30 20:56:55 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;11;Bedcontrol
2019-12-30 20:56:55 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 255
2019-12-30 20:56:55 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;12;0.1
2019-12-30 20:56:55 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 23: value_type 37, value = 0
2019-12-30 20:57:07 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;22;1;0;37;1
2019-12-30 20:57:07 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 22
2019-12-30 20:57:07 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 22: value_type 37, value = 1
2019-12-30 20:57:07 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;22;1;0;37;0
2019-12-30 20:57:07 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 22: value_type 37, value = 0
2019-12-30 20:57:52 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;22;57072
2019-12-30 20:57:52 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 255
2019-12-30 20:57:52 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 23: value_type 37, value = 0
2019-12-30 20:57:52 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 22: value_type 37, value = 0
2019-12-30 20:58:52 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;22;117073
2019-12-30 20:58:52 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 255
2019-12-30 20:58:52 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 23: value_type 37, value = 0
2019-12-30 20:58:52 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 22: value_type 37, value = 0
2019-12-30 20:59:52 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 3;255;3;0;22;177074
2019-12-30 20:59:52 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 255
2019-12-30 20:59:52 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 23: value_type 37, value = 0
2019-12-30 20:59:52 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Bedcontrol 3 22: value_type 37, value = 0
This is my configuration:
mysensors:
  gateways:
    - device: mqtt
      topic_in_prefix: 'mysensors-out'
      topic_out_prefix: 'mysensors-in'
  optimistic: false
  persistence: false #true
  retain: false
  version: '2.3'
This is my arduino code. It works by sending integer 1-3 to HA so I know if the button was one, double or long press. I checked that this type should be supported (and it was working earlier).
#include "OneButton.h"
// Enable debug prints to serial monitor
//#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_RF24
// Define fixed numbers for the
// controller - MY_NODE_ID
// sensors - CHILD_ID_xxx
#define MY_NODE_ID 3
#define CHILD_ID_JUHA_BUTTON1 20
#define CHILD_ID_JUHA_BUTTON2 21
#define CHILD_ID_TIINA_BUTTON1 22
#define CHILD_ID_TIINA_BUTTON2 23
#include <MyConfig.h>
#include <MySensors.h>
MyMessage MSjuhaButton1(CHILD_ID_JUHA_BUTTON1, V_LEVEL);
MyMessage MSjuhaButton2(CHILD_ID_JUHA_BUTTON2, V_LEVEL);
MyMessage MStiinaButton1(CHILD_ID_TIINA_BUTTON1, V_LEVEL);
MyMessage MStiinaButton2(CHILD_ID_TIINA_BUTTON2, V_LEVEL);
// Button locations
bool buttonDefault = LOW;
const int juhaButton1Pin = 5;
const int juhaButton2Pin = 6;
const int tiinaButton1Pin = 7;
const int tiinaButton2Pin = 8;
//classes for buttons
OneButton juhaButton1(juhaButton1Pin, buttonDefault);
OneButton juhaButton2(juhaButton2Pin, buttonDefault);
OneButton tiinaButton1(tiinaButton1Pin, buttonDefault);
OneButton tiinaButton2(tiinaButton2Pin, buttonDefault);
// Heartbeat times
unsigned long heartbeat_timer = 0;
void presentation()
    // Register all sensors to gateway (they will be created as child devices)
    present(CHILD_ID_JUHA_BUTTON1, S_VIBRATION, "Juha button 1", false);
    wait(200);
    present(CHILD_ID_JUHA_BUTTON2, S_VIBRATION, "Juha button 2", false);
    wait(200);
    present(CHILD_ID_TIINA_BUTTON1, S_VIBRATION, "Tiina button 1", false);
    wait(200);
    present(CHILD_ID_TIINA_BUTTON2, S_VIBRATION, "Tiina button 2", false);
    wait(200);
    // Send the sketch version information to the gateway and Controller
    sendSketchInfo("Bedcontrol", "0.1", false);
void setup()
    // Attach button click functions
    juhaButton1.attachClick(juhaClick1);
    juhaButton1.attachDoubleClick(juhaDoubleclick1);
    juhaButton1.attachLongPressStart(juhaLongPressStart1);
    tiinaButton1.attachClick(tiinaClick1);
    tiinaButton1.attachDoubleClick(tiinaDoubleclick1);
    tiinaButton1.attachLongPressStart(tiinaLongPressStart1);
    juhaButton2.attachClick(juhaClick2);
    juhaButton2.attachDoubleClick(juhaDoubleclick2);
    juhaButton2.attachLongPressStart(juhaLongPressStart2);
    tiinaButton2.attachClick(tiinaClick2);
    tiinaButton2.attachDoubleClick(tiinaDoubleclick2);
    tiinaButton2.attachLongPressStart(tiinaLongPressStart2);
void loop()
    juhaButton1.tick();
    tiinaButton1.tick();
    juhaButton2.tick();
    tiinaButton2.tick();
    if( heartbeat_timer + 60000 < millis() )
      heartbeat_timer = millis();
      sendHeartbeat();
// Functions for acting to button press
void juhaClick1()
  send(MSjuhaButton1.set(1));
  wait(400);
  send(MSjuhaButton1.set(0));
void juhaClick2()
  send(MSjuhaButton2.set(1));
  wait(400);
  send(MSjuhaButton2.set(0));
void juhaDoubleclick1()
  send(MSjuhaButton1.set(2));
  wait(400);
void juhaDoubleclick2()
  send(MSjuhaButton2.set(2));
  wait(400);
void juhaLongPressStart1()
  send(MSjuhaButton1.set(3));
  wait(400);
void juhaLongPressStart2()
  send(MSjuhaButton2.set(3));
  wait(400);
void tiinaClick1()
  send(MStiinaButton1.set(1));
  wait(400);
  send(MStiinaButton1.set(0));
void tiinaClick2()
  send(MStiinaButton2.set(1));
  wait(400);
  send(MStiinaButton2.set(0));
void tiinaDoubleclick1()
  send(MStiinaButton1.set(2));
  wait(400);
void tiinaDoubleclick2()
  send(MStiinaButton2.set(2));
  wait(400);
void tiinaLongPressStart1()
  send(MStiinaButton1.set(3));
  wait(400);
void tiinaLongPressStart2()
  send(MStiinaButton2.set(3));
  wait(400);
// Message received functions from the central node
void receive(const MyMessage &message)
    if (message.type == V_LIGHT)
        if (message.sensor == CHILD_ID_JUHA_BUTTON1)
            if (message.getBool()== 1)
            else
I have the same problem with mysensors 2.3.2, did you solve it?
@Jumping
Yes, my problem was that I was looking entities based on child id from present function. It actually worked for me all the time. The entities are created based on what is passed through sketch info.
Entities from my sketch are something like sensor.bedcontrol_3_20
Paste your code if you have some other problem.
