I’m runnin home-assistant 0.89.2 (also tried upgrading to 0.90 beta 4) on hassbian. Also running mysensors gateway 2.3.1 on the same rpi. Also I have test mysensors node (v. 2.3.1) presented as “S_RGB_LIGHT”. Problem is that home-assistant gives me an error and doesn’t add this node to the list.
18 22:57:37 hassbian hass[9235]: 2019-03-18 22:57:37 DEBUG (MainThread) [mysensors] Receiving 10;255;3;0;6;0
18 22:57:37 hassbian hass[9235]: 2019-03-18 22:57:37 DEBUG (MainThread) [mysensors] Sending 10;255;3;0;6;M
18 22:57:37 hassbian hass[9235]: 2019-03-18 22:57:37 DEBUG (MainThread) [mysensors] Receiving 10;255;3;0;11;RGB Dimmable Light
18 22:57:37 hassbian hass[9235]: 2019-03-18 22:57:37 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 10 child 255
18 22:57:37 hassbian hass[9235]: 2019-03-18 22:57:37 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
18 22:57:37 hassbian hass[9235]: 2019-03-18 22:57:37 DEBUG (MainThread) [mysensors] Receiving 10;255;3;0;12;1.0
18 22:57:37 hassbian hass[9235]: 2019-03-18 22:57:37 DEBUG (MainThread) [mysensors] Receiving 10;1;0;0;26;RGB_test
18 22:57:37 hassbian hass[9235]: 2019-03-18 22:57:37 WARNING (MainThread) [mysensors] Not a valid message: Not valid message sub-type: 26 for dictionary value @ data['sub_type']
18 22:57:37 hassbian hass[9235]: 2019-03-18 22:57:37 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.1
“26” - is a type value for “S_RGB_LIGHT” in mysensors Serial API. Somehow home-assistant doesn’t recognize it. The same node is working with domoticz on the other rpi.
mysgw log:
Mar 18 23:13:10 DEBUG TSF:MSG:READ,80-80-0,s=255,c=3,t=11,pt=0,l=18,sg=0:RGB Dimmable Light
Mar 18 23:13:10 DEBUG TSF:MSG:READ,80-80-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
Mar 18 23:13:10 DEBUG TSF:MSG:READ,80-80-0,s=1,c=0,t=26,pt=0,l=8,sg=0:RGB_test
Mar 18 23:13:10 DEBUG TSF:MSG:READ,80-80-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
Mar 18 23:13:10 DEBUG TSF:MSG:SEND,0-0-80-80,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
