Sorry, I don’t know what could be wrong. I just tested this on my development instance and tail -f
on the log works for me. This is after a restart of hass
. You can see that as soon as the logger
component is set up, the log gets output:
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds.
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setting up http
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setting up system_log
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setting up api
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setting up recorder
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.3 seconds.
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setting up history
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2018-04-02 20:53:38 INFO (MainThread) [homeassistant.setup] Setting up frontend
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.2 seconds.
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setting up alarm_control_panel
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setting up zone
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setting up group
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.0 seconds.
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setting up config
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setting up logbook
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setting up automation
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.0 seconds.
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setup of domain alarm_control_panel took 0.1 seconds.
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setting up updater
2018-04-02 20:53:39 WARNING (MainThread) [homeassistant.components.updater] Running on 'dev', only analytics will be submitted
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setting up mysensors
2018-04-02 20:53:39 DEBUG (Thread-18) [mysensors.persistence] Loading sensors from persistence file /home/martin/.homeassistant/mysensors6.json
2018-04-02 20:53:39 DEBUG (Thread-19) [mysensors.persistence] Saving sensors to persistence file /home/martin/.homeassistant/mysensors6.json
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setup of domain mysensors took 0.0 seconds.
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setting up switch
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds.
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.components.mysensors] Adding new devices: [<Entity Lamp 1 1: off>]
2018-04-02 20:53:39 DEBUG (MainThread) [homeassistant.components.mysensors] Entity update: Lamp 1 1: value_type 2, value = 0
2018-04-02 20:53:39 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 1.37s
2018-04-02 20:53:39 INFO (MainThread) [mysensors.gateway_serial] Trying to connect to /dev/ttyACM0
2018-04-02 20:53:39 INFO (MainThread) [mysensors] Connected to Serial<id=0x7fad05dde438, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False)
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:4 TSM:INIT
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:6 TSF:WUR:MS=0
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14 TSM:INIT:TSP OK
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:17 TSM:INIT:GW MODE
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:20 TSM:READY:ID=0,PAR=0,DIS=0
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:23 MCO:REG:NOT NEEDED
2018-04-02 20:53:40 INFO (MainThread) [mysensors] n:0 c:255 t:3 s:14 p:Gateway startup complete.
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:28 MCO:BGN:STP
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:34 MCO:BGN:INIT OK,TSP=1
2018-04-02 20:53:40 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:73 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
2018-04-02 20:53:52 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:12028 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
2018-04-02 20:53:52 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:12035 TSF:MSG:BC
2018-04-02 20:53:52 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:12038 TSF:MSG:FPAR REQ,ID=1
2018-04-02 20:53:52 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:12041 TSF:PNG:SEND,TO=0
2018-04-02 20:53:52 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:12045 TSF:CKU:OK
2018-04-02 20:53:52 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:12047 TSF:MSG:GWL OK
2018-04-02 20:53:52 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:12837 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14078 TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14085 TSF:MSG:PINGED,ID=1,HP=1
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14090 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14103 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14113 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14120 TSF:MSG:READ,1-1-0,s=255,c=0,t=18,pt=0,l=5,sg=0:2.2.0
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14128 TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14143 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14150 TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=4,sg=0:Lamp
2018-04-02 20:53:54 DEBUG (MainThread) [homeassistant.components.mysensors] Node update: node 1 child 255
2018-04-02 20:53:54 DEBUG (MainThread) [homeassistant.components.mysensors] Not a child update for node 1
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14157 TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14166 TSF:MSG:READ,1-1-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
2018-04-02 20:53:54 WARNING (MainThread) [mysensors.sensor] child_id 1 already exists in children of node 1, cannot add child
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14175 TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14183 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14195 TSF:MSG:READ,1-1-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
2018-04-02 20:53:54 DEBUG (MainThread) [homeassistant.components.mysensors] Node update: node 1 child 1
2018-04-02 20:53:54 DEBUG (MainThread) [homeassistant.components.mysensors] Entity update: Lamp 1 1: value_type 2, value = 0
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14205 TSF:MSG:READ,1-1-0,s=1,c=2,t=2,pt=0,l=0,sg=0:
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14220 TSF:MSG:SEND,0-0-1-1,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
2018-04-02 20:53:54 DEBUG (MainThread) [mysensors] n:0 c:255 t:3 s:9 p:14227 TSF:MSG:READ,1-1-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
2018-04-02 20:53:59 DEBUG (Thread-22) [mysensors.persistence] Saving sensors to persistence file /home/martin/.homeassistant/mysensors6.json
