Hi everyone.
I have a problem with connect MySensors gateway over USB. Home Assitant is installed on docker (RPi 3B+) and Arduino Mega is connected via USB. I have checked the port using: ls /dev/ttyACM* command. I am using this script:
I tried add baudrate 115200, but nothing changed.
Logs:
2020-07-14 19:39:27 ERROR (MainThread) [homeassistant.components.mysensors] No devices could be setup as gateways, check your configuration
2020-07-14 19:39:27 ERROR (MainThread) [homeassistant.setup] Setup failed for mysensors: Integration failed to initialize.
I found the solution, i didn’t add ttyACM0 device in docker config. But i have another problem
2020-07-14 22:35:35 WARNING (MainThread) [homeassistant.components.mysensors.gateway] Gateway /dev/ttyACM0 not ready after 15.0 secs so continuing with setup
