Hi
It a trying to use MySensors gateway connected over USB.
I see two issues at the moment.
First one. My switch is not displayed by home-assistant GUI by default after boot. It appears after MySensors sends signal to home-assistant.
Second one is that i am not able to change state from home-assistant GUI. Logs says:
2017-11-11 00:44:32 INFO (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: service=load_platform.switch, platform=mysensors, discovered=devices=[(1949681808, 0, 1, 2)], name=mysensors>
2017-11-11 00:44:32 INFO (MainThread) [homeassistant.loader] Loaded switch.mysensors from homeassistant.components.switch.mysensors
2017-11-11 00:44:32 INFO (MainThread) [homeassistant.components.switch] Setting up switch.mysensors
2017-11-11 00:44:32 INFO (SyncWorker_4) [homeassistant.components.mysensors] Adding new devices: [<Entity Relay 0 1: off>]
2017-11-11 00:44:32 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=mysensors_send_ir_code>
2017-11-11 00:44:52 WARNING (Thread-2) [mysensors] Error decoding message from gateway, bad data received: Incoming change for sensor:1, New status: 0
2017-11-11 00:44:52 WARNING (Thread-2) [mysensors] Not a valid message:
2017-11-11 00:44:56 WARNING (Thread-2) [mysensors] Error decoding message from gateway, bad data received: Incoming change for sensor:1, New status: 0
2017-11-11 00:44:56 WARNING (Thread-2) [mysensors] Not a valid message:
2017-11-11 00:45:01 WARNING (Thread-2) [mysensors] Error decoding message from gateway, bad data received: Incoming change for sensor:1, New status: 0
2017-11-11 00:45:01 WARNING (Thread-2) [mysensors] Not a valid message:
2017-11-11 00:45:23 WARNING (Thread-2) [mysensors] Error decoding message from gateway, bad data received: Incoming change for sensor:1, New status: 0
2017-11-11 00:45:23 WARNING (Thread-2) [mysensors] Not a valid message:
2017-11-11 00:45:27 WARNING (Thread-2) [mysensors] Error decoding message from gateway, bad data received: Incoming change for sensor:1, New status: 0
2017-11-11 00:45:27 WARNING (Thread-2) [mysensors] Not a valid message:
2017-11-11 00:45:49 WARNING (Thread-2) [mysensors] Error decoding message from gateway, bad data received: Incoming change for sensor:1, New status: 0
2017-11-11 00:45:49 WARNING (Thread-2) [mysensors] Not a valid message:
I run few tests on domoticz, and my gateway works there - no issues.
Are those issues looks familiar (known bugs) or i am missing something.
