Hi all,
After much frustration I’ve realised the reason my light sensor isn’t working when I use v_level is because you need to specifiy to use version 2.0, otherwise it defaults to version 1.4 which doesn’t support v_level for s_light_level… it only supports v_light_level which is a % (so must be 0-100). My node is sending out lux so this is a bit of a problem.
Anyway… so I’ve tried setting version to “2.0” as shown here https://www.home-assistant.io/components/mysensors/
However this gives me a config error.
Can anyone help me with this?
Heres the my config:
mysensors:
gateways:
- device: '192.168.0.26'
tcp_port: 5003
persistence_file: '/home/homeassistant/.homeassistant/mysensors.json'
version: '2.0'
Thanks!
