I updated HA to 0.52 and noticed on the release notes that mysensors support have had some changes.
MySensors: Not a breaking change per se but users that have not been following the mysensors serial API could face dropped messages after this change. Messages are now validated according to the API before being passed along from/to devices.
The problem now is that Mysensor devices are not anymore discussing with Home Assistant.
The setup goes so that I have one NRF24 radio attached to a Raspberry. On there I’m running the mysensors gateway of which communicates with home assistant. The gateway receives all the messages sent by other arduino+NRF24 units but home assistant is not doing anything.
But the funny thing is that mysensors works good for a few seconds on home assistant booting up. Then, nothing… Could someone help me out to check if I have sketch error or some configuration mistake? I just cant get on top of this. I tried the debug mode introduced with the newest update but to my understanding it didnt have a word about mysensors.
HA config:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: xx
longitude: xx
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 5
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Helsinki
# Customize entities
customize:
switch.bedlights_106_1:
friendly_name: "Juha's Nightlight"
switch.bedlights_106_2:
friendly_name: "Tiina's Nightlight"
switch.bedlights_106_3:
friendly_name: "Heart Nightlight"
sensor.bedlights_106_4:
hidden: true
sensor.bedlights_106_4_2:
hidden: true
# Alarm clock sensors
sensor.alarm_clock_hour:
hidden: true
sensor.alarm_clock_minute:
hidden: true
sensor.alarm_clock_time_long:
hidden: true
sensor.alarm_clock_time:
friendly_name: 'Alarm Clock Setting'
icon: mdi:alarm
# Alarm clock inputs
input_slider.alarm_clock_hour:
friendly_name: 'Hour'
icon: mdi:timer
input_slider.alarm_clock_minute:
friendly_name: 'Minute'
icon: mdi:timer
input_boolean.alarm_clock_status:
friendly_name: 'Alarm Clock Status'
icon: mdi:alarm-check
# Time and Date
sensor.time:
friendly_name: 'Time'
icon: mdi:clock
sensor.date:
friendly_name: 'Date'
icon: mdi:calendar-today
# Bedroom sensors
sensor.bedroom_temperature:
friendly_name: 'Temperature'
icon: mdi:thermometer
sensor.bedroom_humidity:
friendly_name: 'Humidity'
icon: mdi:water-percent
# Shower sensors
sensor.shower_temperature:
sensor.shower_humidity:
# Living Room sensors
sensor.living_room_temperature:
sensor.living_room_humidity:
# Living room cabinet lights
switch.towerdetector_107_1:
friendly_name: 'Standalone lamp'
switch.towerdetector_107_2:
friendly_name: 'Decorative light'
# Bathroom sensors
sensor.bathroom_temperature:
sensor.bathroom_humidity:
sensor.bathroom_pressure:
frindly_name: 'Pressure'
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Uncomment this to add a password (recommended!)
api_password: xx
# Uncomment this if you are using SSL or running in Docker etc
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# Recorder component to make the database. include and exclude will
# affect also to history component
recorder:
purge_days: 5
include:
domains:
- sensor
#- binary_sensor #for now blocked tower detector motion sensors
- device_tracker
exclude:
entities:
- sensor.date
- sensor.time
- sensor.alarm_clock_hour
- sensor.alarm_clock_minute
- sensor.alarm_clock_time
- sensor.alarm_clock_time_long
- sensor.yr_symbol
# View all events in a logbook
logbook:
# Track the sun
sun:
# sensors
- platform: yr
- platform: dht
sensor: DHT22
pin: 17
monitored_conditions:
- temperature
- humidity
- platform: mqtt
state_topic: "bedroom/dht"
name: 'Bedroom Temperature'
unit_of_measurement: "°C"
value_template: '{{ value_json.temperature }}'
- platform: mqtt
name: 'Bedroom Humidity'
unit_of_measurement: "%"
value_template: '{{ value_json.humidity }}'
- platform: mqtt
state_topic: "shower/dht"
name: 'Shower temperature'
- platform: mqtt
name: 'Shower Humidity'
- platform: mqtt
state_topic: "bathroom/dht"
name: 'Bathroom temperature'
- platform: mqtt
name: 'Bathroom Humidity'
- platform: mqtt
state_topic: "bathroom/pressure"
name: 'Bathroom Pressure'
unit_of_measurement: "Pa"
value_template: '{{ value_json.pressure }}'
# Alarm clock code start
- platform: time_date
display_options:
- 'time'
- 'date'
sensors:
alarm_clock_hour:
value_template: '{{ states.input_slider.alarm_clock_hour.state | int }}'
alarm_clock_minute:
value_template: '{{ states.input_slider.alarm_clock_minute.state | int }}'
alarm_clock_time:
value_template: >-
{{ states.sensor.alarm_clock_hour.state }}:
{%- if states.sensor.alarm_clock_minute.state|length == 1 -%}
0
{%- endif -%}
{{ states.sensor.alarm_clock_minute.state }}
value_template: >-
{% if states.sensor.alarm_clock_hour.state|length == 1 -%}
0
{%- endif -%}
0
{%- endif -%}
# Alarm clock code end
binary_sensor:
# Bathroom motion sensor
- platform: mqtt
state_topic: 'bathroom/motion'
payload_on: 'on'
payload_off: 'off'
device_class: motion
# Text to speech
tts:
platform: google
group: !include groups.yaml
script: !include scripts.yaml
# Spotify integration
media_player:
- platform: spotify
client_id: xx
client_secret: xx
# Track devices connected to the Asus router
device_tracker:
- platform: bluetooth_tracker
# MQTT with mosquitto
mqtt:
broker: xx
port: xx
client_id: xx-xx-xx
username: xx
password: xx
# Mysensors
mysensors:
gateways:
- device: '127.0.0.1'
persistence_file: '/home/homeassistant/mysensors.json'
tcp_port: 5003
optimistic: false
persistence: true
retain: true
version: '2.0'
input_slider:
alarm_clock_hour:
initial: 6
min: 0
max: 23
step: 1
alarm_clock_minute:
initial: 20
min: 0
max: 55
step: 5
input_boolean:
alarm_clock_status:
initial: off
telegram_bot:
- platform: polling
api_key: 'xx'
allowed_chat_ids:
- 'xx'
# Example configuration.yaml entry for the notifier
notify:
- name: xx
platform: telegram
chat_id: 'xx'
# Locks
lock:
- platform: mqtt
state_topic: "warehouse/lock/status"
command_topic: "warehouse/lock/set"
payload_lock: "LOCK"
payload_unlock: "UNLOCK"
One of my Mysensor nodes:
#include "relay_230V_5V.h"
#include "OneButton.h"
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_NRF24
#define CHILD_ID_JUHA_RELAY 1
#define CHILD_ID_TIINA_RELAY 2
#define CHILD_ID_HEART_RELAY 3
#define CHILD_ID_HUE 4
#include <MyConfig.h>
#include <MySensors.h>
MyMessage MSjuha(CHILD_ID_JUHA_RELAY, V_LIGHT);
MyMessage MStiina(CHILD_ID_TIINA_RELAY, V_LIGHT);
MyMessage MSheart(CHILD_ID_HEART_RELAY, V_LIGHT);
MyMessage MSHueOn(CHILD_ID_HUE, V_SCENE_ON);
MyMessage MSHueOff(CHILD_ID_HUE, V_SCENE_OFF);
//Juha's Nightlight
const int juhaControlPin = 2;
const int juhaButton1Pin = 5;
const int juhaButton2Pin = 6;
bool buttonDefault = LOW;
//Tiina's Nightlight
const int tiinaControlPin = 4;
const int tiinaButton1Pin = 7;
const int tiinaButton2Pin = 8;
//Heart shaped light
const int heartControlPin = 3;
//Init relay controls pins to this state
bool relayDefault = HIGH;
//classes for lights
relay_230V_5V juhaNightlight(juhaControlPin, relayDefault);
relay_230V_5V tiinaNightlight(tiinaControlPin, relayDefault);
relay_230V_5V heartShapedLight(heartControlPin, relayDefault);
//classes for buttons
OneButton juhaButton1(juhaButton1Pin, buttonDefault);
OneButton juhaButton2(juhaButton2Pin, buttonDefault);
OneButton tiinaButton1(tiinaButton1Pin, buttonDefault);
OneButton tiinaButton2(tiinaButton2Pin, buttonDefault);
void presentation()
// Send the sketch version information to the gateway and Controller
sendSketchInfo("bedlights", "1.1", true);
// Register all sensors to gateway (they will be created as child devices)
present(CHILD_ID_JUHA_RELAY, S_LIGHT, "Juha's Nightlight", true);
present(CHILD_ID_TIINA_RELAY, S_LIGHT, "Tiina's Nightlight", true);
present(CHILD_ID_HEART_RELAY, S_LIGHT, "Heart Nightlight", true);
present(CHILD_ID_HUE, S_SCENE_CONTROLLER, "HUE Nightlight", true);
void setup()
// Attach button click functions
juhaButton1.attachClick(juhaClick1);
juhaButton1.attachDoubleClick(juhaDoubleclick1);
juhaButton1.attachLongPressStart(juhaLongPressStart1);
tiinaButton1.attachClick(tiinaClick1);
tiinaButton1.attachDoubleClick(tiinaDoubleclick1);
tiinaButton1.attachLongPressStart(tiinaLongPressStart1);
juhaButton2.attachClick(juhaClick2);
juhaButton2.attachDoubleClick(juhaDoubleclick2);
juhaButton2.attachLongPressStart(juhaLongPressStart2);
tiinaButton2.attachClick(tiinaClick2);
tiinaButton2.attachDoubleClick(tiinaDoubleclick2);
tiinaButton2.attachLongPressStart(tiinaLongPressStart2);
void loop()
juhaButton1.tick();
tiinaButton1.tick();
juhaButton2.tick();
tiinaButton2.tick();
// Functions for acting to button press
void juhaClick1()
juhaNightlight.toggleState();
send(MSjuha.set(!juhaNightlight.getState()));
void juhaClick2()
heartShapedLight.toggleState();
send(MSheart.set(!heartShapedLight.getState()));
void juhaDoubleclick1()
allOff();
void juhaDoubleclick2()
allOff();
hueOff();
void juhaLongPressStart1()
tiinaNightlight.toggleState();
send(MStiina.set(!tiinaNightlight.getState()));
void juhaLongPressStart2()
hueOn();
void tiinaClick1()
void tiinaClick2()
void tiinaDoubleclick1()
allOff();
void tiinaDoubleclick2()
allOff();
hueOff();
void tiinaLongPressStart1()
void tiinaLongPressStart2()
hueOn();
// Turn off all nightlights
void allOff()
juhaNightlight.setState(HIGH);
heartShapedLight.setState(HIGH);
tiinaNightlight.setState(HIGH);
// Turn HUE lights on
void hueOn()
send(MSHueOn.set("Nightlight_on"));
wait(150);
send(MSHueOn.set("idle"));
// Turn all HUE lights off
void hueOff()
send(MSHueOff.set("Nightlight_off"));
wait(150);
send(MSHueOff.set("idle"));
// Message received functions from the central node
void receive(const MyMessage &message)
if (message.type == V_LIGHT)
if (message.sensor == CHILD_ID_JUHA_RELAY)
if (message.getBool()== 1)
juhaNightlight.setState(LOW);
else
if (message.sensor == CHILD_ID_TIINA_RELAY)
tiinaNightlight.setState(LOW);
else
if (message.sensor == CHILD_ID_HEART_RELAY)
heartShapedLight.setState(LOW);
else
